ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000 Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile. send the IMEI no to me and i will reply you with unlocking code. IF Problem not Solved So Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator Enter The Puk code and Yes Enter The pin code and Yes So Puk code Open and Problem will Quickly Solved
Your problem is basically related to network. Firstly change your sim in that set if there occurs same result then you need to update you full application. Visit the nearest center and update your handset Nicce to help you Anytime
PUK code are unlike security codes that are handset dependent. PUK codes are sim card dependent. You can get the PUK code from the sim package, on the card where you took the sim card. If you dont have this any longer, I suggest that you call your service provider.
PUK code is asked by the SIM/UIM card and not by the phone. It is generally asked by entering wrong PIN code more than three times. So you need to call your network provider's customer care to know the PUK code.
Hope This Will Help...cheers:))
To unblock you sim you will need a PUK code.
Only your Sim issuer (Operator/Provider) can provide you with this as all handsets are different.
Phone up your provider and tell them you blocked your sim and require a PUK code. They will tell you it when you give them the IMEI number of the handset you locked it in. Look under the battery or type *#06# into the handset to find it.
If your handset asks for PUK code, you need to contact the service provider and provide them 20 digit sim number for the PUK code .
Service provider numbers will be toll free.
Once you get the PUK code, enter it . And then it will ask for new PIN number, you need to enter 0000 twice.
Hope I helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sorry its a long list , but have included everything.Just pick out what you need...The default security code for Nokia is 12345. SIM pin code: This is a pin code that locks the sim card until you enter the correct code. This protects your account, even if your sim is put into another handset. To reset it you need the PUK code... Pin Unlock Code (PUK) If you miss keyed (or forget) your SIM PIN code, and enter the wrong one 3-5 times in a row, the sim will lock up, and you'll need to enter the unlock code to release it. You should ask your Network Service Provider for this code when you need it. Don't try to guess it, because after a few wrong guesses, the SIM card will be permanently disabled. The PUK code was printed on the plastic card that your SIM card was attached to. Phone Security Code: This locks the handset, as opposed to the sim card. You can also set some handsets to only accept a "new" sim if the phone security code is entered. Master Reset Code Sometimes known as the Master Code, this allows you to unlock a handset if you have entered the Security Code wrongly too many times. Which is the one that you want?
SIM pin code: This is a pin code that locks the sim card until you enter the correct code. This protects your account, even if your sim is put into another handset. To reset it, you need the PUK code: Pin Unlock Code (PUK) If you miss key (or forget) your SIM pin code, and enter the wrong one 3-5 times in a row, the SIM will lock up, and you’ll need to enter the PUK unlock code to release it. You should ask your Network Service Provider for this code when you need it. Don’t try to guess it, because after a few wrong guesses, the SIM card will be permanently disabled. Phone Security Code: This locks the handset, as opposed to the sim card. You can also set some handsets to only accept a “new” sim if the phone security code is entered. To reset it, you need the Master code code: Master Reset Code
Sometimes known as the Master Code, this allows you to unlock a handset if you have entered the Security Code wrongly too many times. Which is the one that you want? The default security code for Nokia is 12345
