Question about Midland Radio Communications
MIDLAND CB RADIO 5001Z NOT RECEIVING,NOT THE MIC ,
NOT RECEIVING NOT THE MIC, LIKELY CONPONET INSIDE.
  • LEWIS R KING Feb 21, 2012
    Thanks but i have not get around to trying your posible solution. due to some busy days. i would fill u in as things unfold ...
    Genius:
  • 1,212 Answers
The relay may be damaged or severely pitted. The connector may be damaged or it's PC traces may be damaged.
Also check the remote speaker plug- spray it with some contact cleaner from inside to reach the interrupt contacts and plug and unplug a jack into the socket a number of times to clean that contact.
Posted on Feb 19, 2012
Shuttle83
  • 1139 Answers
SOURCE: midland 75-785
Given the fact that when you key up the mic you should not hear any thing because the receiver section is "turned off" (no antenna and the speaker is muted). This would seem to indicate that the switch the headset controls which allow the change over from RX to Tx is bad or that the circuit in the CB unit which the head set plugs into is having a problem. Do you hear the same flutter without the headset? Try to get another headset or test one out just to see if the problem is eliminated by using a known good headset.
Posted on Sep 04, 2007
wyoed1
  • 211 Answers
SOURCE: 75-822 midland radio
You have a bad detector in the radio. Needs serviced. Change the bad detector diode and it should work. Good Luck
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 07, 2008
Mechanic688
  • 204 Answers
SOURCE: look for schematics for a midland cb
daniel, first off, I need a complete model number for the radio info. Midland only made about 40-50 different models over the years. The header calls for a 75-822 and you are asking for a ** 833. The beginning should be a 13 or 75,76,77,78. Let me know the # and i'll be able to get you the proper pinout.
Thanks,,, Mechanic
Posted on Mar 08, 2008
Communicomm
  • 90 Answers
SOURCE: wiring a midland 78/999 cb radio microphone
Pin 1 = white
Pin 2 = shield
Pin 3 = black
Pin 4 = red
Posted on Sep 29, 2008
  • 181 Answers
SOURCE: THE WIRES IN MY DAD'S OLD MIDLAND 77-106 MIC. HAVE BROKEN LOOSE
first check out the front for a circle with 27/81 this is the 40 channel (FM). if you cant find the circle it is (AM) and not used as much in the uk. if it means alot to you and your dad post it to cb communications shildon DL4 1HE and i will will see want i can do.
Posted on Jul 25, 2009
Midland 1001lwx does not transmit any solution
take the little switch on the front and flick it to CB , turn up the mic gain and have at it.
Feb 16, 2013 | Midland 1001LWX CB Radio
What is the dead key adjustment # on a midland 5001z cb ?
amps like the smaller wattage so they can push out more power but some amps like the 3 watt figure so they can push out more power. go to www.cbtricks.com and look up your radio. the schematic is there but I don't remember if there is a service manual for it.
Dec 27, 2012 | Midland 1001Z 40-Channels Base CB Radio
Peak and tune midland 5001z
you cannot do it unless you have the proper equipment.
Jun 16, 2012 | Midland 1001Z 40-Channels Base CB Radio
Brand new Midland 5001z blows fuses immediately after its turned on. I tried the power cord on Cobra 25 that has the identical plug configuration and its Ok. I don't have the receipt as I got it a
bad final also check for any burned resistors in the area. If the final caused the resistor to burn the just replacing the resistor it would burn the new one also.
Feb 05, 2012 | Midland 5001 40-Channels Base CB Radio
I have a 5001z it quit receiving I can turn the squelch all the way off and I dont get any noise at all not sure if its sending since it dont receive
You could have a broken RX wire in the mic cord, or the wire to the jack is broke.
Try another mic. make sure it is wired for midland. Also make sure the RF gain is all the way up. There is really no reason to have it lower then full, unless you want less receive.
Jul 09, 2011 | Radio Communications
Hi i have a midland 98 plus,i have been told that when i talk it have very low volume and people have to turn their set up to full volume to hear me. but the same mic on a different set works fine
Look at Radio Mods or Defcom mods. To clip modulation diode inside radio. Take to Cb shop to Peak&Tune. It may be wound to high in carrier but not audio. Buy you a "Power Mic" at Radio Shack or WWW.COPPERELECTRONICS.COM.
Apr 01, 2011 | Midland 40-Channel CB Radio CB Radio
My mic is a midland mic but is wired for a cobra some wires got mixed up some how in the mic but im not sure which ones go where.
easiest way open mic the coloured wire on the wire at the front of switch is receive, the middle coloured one earth,and end colour transmitt,on the other side of switch is mic colour.find these out first then get back to me.
Sep 14, 2010 | Midland 1001Z 40-Channels Base CB Radio
I cant be heard when i speak through my midland 1001z cb radio?
hello have you checked the swr on the antenna have you checked the output of the radio with a power metre it should be reading 4watts max if yes problem might be the microphone make sure there are no wires shortening in the mic socket entering the radio and check inside the mic aswell
cheers and goodluck
Jun 26, 2010 | Midland 1001Z 40-Channels Base CB Radio
I need to know the wiring diagram for a telex rk56 to a 4 pin on a galaxy 88 radio
1= shield and red
2= white
3= blue
4= black
yellow-N/C
maybe this will help
Oct 02, 2009 | Magnum DeltaForce CB Radio
Radio Communications Logo
172 people viewed this question
Top Midland Radio Communications Experts
AnyMHz.com
AnyMHz.com
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
