Question about Jensen Car Audio & Video
How do I install a jensen uv10 phase linear series in my 1998 jeep grand Cherokee where the touch screen will not hit my dash where it over hangs
  • 909 Answers
SOURCE: I bought a Phase Linear uv9 and it say the front
It's a very common cable, there are many on e-bay under computer-accesories-cables. Also available at local PC shop.
Posted on Jun 03, 2009
  • 4 Answers
SOURCE: i need a remote for my jensen phase linear uv8
Get one off of ebay. Just received one for bout 30.00 Good luck
Posted on Jun 08, 2009
  • 3 Answers
SOURCE: have a jensen linear phase car receiver , there is
The pink wire is the safety wire so that you can not watch the screen (during a video) unless your car is in park. You can either connect it to a ground or completely bypass it by typing the code 543210 in the menu screen and turning the safety feature off.
Posted on Jan 11, 2010
supertech6
  • 513 Answers
SOURCE: wiring harness
You can try these people.
I have not dealt with them. You can contact Jensen directly. Be aware these harnesses are not cheap.
Posted on Apr 16, 2010
jdvillanueva
  • 2098 Answers
SOURCE: I have a jensen uv10 phase linear in-dash dvd
No disc error can be a DIY like the following steps.
Assuming that the disc is good.
1.Cleaning the lens. - Sometimes because of dust the lens can't read any disc.
Try clean the lens by soft cotton buds. Be careful while doing this.
2.Replacing the ribbon - Check the ribbon connected to the lens from the main board for scratch, damage. Once it has an open line then of course the lens can't read the disc. Also try to erase the contact by pencil eraser.
If you've done the steps above and the symptoms still there then the next step requires you a little knowledge in soldering technique and reading the ohmmeter.
3.Checked the motor - Check the motor that spin the disc with an ohmmeter. You can test it using the ohmmeter (x1) even it is connected on the lens assembly.
Good motor - reading should be fairly high and it will spin.
Bad motor - reading will drop to low resistance and will not spin.
Hint : 50% of my repaired unit the above parts are commonly caused of the problem.
If you confirmed that you have a defective motor then replace it with a new one. Before replacing the new motor you have to check the clearance of the disc holder with the old one. The clearance should be the same as the old because if not the lens will not read the disc if it is too far or too close.
If you already cleaned the lens, and confirmed that the ribbon is good as well as the motor then I've advice you to send it to repair shop because the next step should be done with an expert because it is quite technical diagnosing the fault between the pick-up lens and the main board.
Thanks for using fixya.
Please rate my help.
Posted on Jan 25, 2011
How do I remove heater blower motor?
1998 ATC Jeep Grand Cherokee Blower Resistor connector ...
? 0:55
www.youtube.com/watch?v=sDFLuenx9aw
Nov 14, 2012 - Uploaded by Freedomautomotive1
1998 ATC Jeep Grand Cherokee Blower Resistor connector Repair Kit (RARE 1/2 Year) ... How to Fix a Chrysler Blower FanThat Only Works on High - Duration: 16:51. ... JEEP2001 FIXING THE HEATER BLOWER CONTROL. ... Jeep Grand CherokeeCenter and Lower Dash Removal - Auto Repair Series ...
Sep 30, 2015 | 1998 Jeep Grand Cherokee
How do you switch the am/fm on the Jensen Phase Linear UV10 Flip Out MultiMedia Receiver with 7-Inch Touch Screen with no remote?
touch source button in the upper left corner until the tuner options are on, or until you see the stations,m then hit seek or tune to get the station you wish to play.
Nov 21, 2014 | Jensen Car Audio & Video
How do you switch the am and fm on the Jensen Phase Linear UV10 Flip Out MultiMedia Receiver with 7-Inch Touch Screen
touch the source button in the upper left hand corner until you see radio, then hit tune or seek to get the stations you wish.
Nov 21, 2014 | Car Audio & Video
Jensen uv10 wiring plug on each row what goes where
I would just look to see where there is a picture of the wire harness on line and check the wire colors with the manual.
Sep 23, 2014 | Jensen Uv10 7" Lcd In Dash Car Dvd Monitor...
Screen is black but touch still wrks on jensen UV10
i really dont think you have the bypass connected right cause your still being blocked on your screen... re check your wiring maybe something connected wrong or bypass is defective...
radiorepair@windowtintingin239.com
Oct 28, 2013 | Audiovox Jensen Uv10 Dvd Video Bypass Hack...
Looking to buy touch screen faceplate
Try audiovox.com. You should be able to find a way to contact them there. Audiovox now owns Jensen.
Oct 04, 2012 | Jensen Uv10 7" Lcd In Dash Car Dvd Monitor...
Where to buy a Replacement TouchScreen for my Jensen UV10
You can try going to audiovox.com and see if you can contact them that way. Jensen is now owned by audiovox.
Aug 31, 2012 | Jensen Uv10 7" Lcd In Dash Car Dvd Monitor...
Wiring harness
wiring pin layout ginseng UV chan DVD iPod USB navigator and Bluetooth ready he's being good receiver 7 inch TFT 1200
Apr 16, 2010 | Phase Linear UDV9010 Car DVD Player
Jensen Phase Linear uv10 dvd wont play while driving
When You installed it the pink wire that said to brake did you put it to an actual ground instead of the barking brake?
Jan 03, 2010 | Jensen Televison & Video
Phase Linear UV8
go to setup hit 543210 but hold 0 then turn the bake override on and then hit the X
Dec 11, 2007 | Jensen VM9510 Car DVD Player
Car Audio & Video Logo
32 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
