Question about HP Computers & Internet
I get one long beep and one extra long beep on startup. Computer just beeps and nothing else.
    Genius:
  • 1,124 Answers
The computer POST (Power On Self Test) tests the computer, insuring that it meets the necessary system requirements and that all hardware is working properly before starting the remainder of the boot process. If the computer passes the POST the computer will have a single beep (with some computer BIOS manufacturers it may beep twice) as the computer starts and the computer will continue to start normally. However, if the computer fails the POST, the computer will either not beep at all or will generate a beep code, which tells the user the source of the problem.
This issue can be caused by any of the below situations.
  1. New hardware conflicting with old hardware.
  2. Bad or failing hardware device.
  3. Connections not connected or connected properly.
  4. Recent electrical storm that caused a surge that damaged computer.
  5. Other hardware issue.
you can determine the meaning of your beeps finding out with your BIOS System installed on your machine.
Usually you probably have some memory problem.
Posted on Oct 26, 2008
I have a P5K Deluxe asus mother board error beeps no visuals
Two beeps is usually the video card.
Do you have a spare video card to change out?
This is why people keep obsolete PCI video cards for just such tests.
Dec 05, 2015 | ASUS P5k Deluxe Socket 775 Motherboard
My acer aspire starts z5700 starts beeping when i push power button, nothing else happens, the screen is black and computer is working
You have to count the beeps to determine what work. Overall if the system beeps on startup it sounds like the memory (RAM) is not working. My suggesting to either buy new RAM or reseat the existing memory by taking about and put back in.
Oct 12, 2014 | Acer Aspire Z5700 PC Desktop
Sony vaio beeps on startup then beeps once every three seconds
Could be a problem with the RAM. You can do a boot-up RAM test with a CD-ROM or USB stick using Memtest
Memtest86 Advanced Memory Diagnostic Tool
Jan 11, 2014 | HP Compaq DC5800 Small Form Factor PC...
My Dell Poweredge 1550 won't connect to the screen. It also constantly beeps upon startup
Is it in a 1, 3, 2 beep pattern (beep....beep, beep, beep........beep, beep)? If so, the memory is either not seated well or may be bad. Try reseating your memory. If it continues, try with one stick at a time just to see if it will boot up with a display.
Thanks,
--Brian
Nov 02, 2013 | Dell PowerEdge Computers & Internet
On startup there is 4 beeps then 2 then nothing. The laptop belongs to my grandouther.the power coard was frade,so my guess is that's where the problem started.
Beep codes are used by the BIOS during the POST to report certain initial system errors.
If you're hearing beep codes after you turn your computer on, it typically means that the system has encountered some kind of problem before it was able to display any kind of error information on the monitor.
Follow the steps below to determine what system problem the beep code is representing.
Difficulty: Average Time Required: Anywhere from 10 minutes to a few hours depending on the cause of the beep code Here's How:
  1. Power on the computer or restart it if it's already on.
  2. Listen very carefully to the beep codes that sound when the computer begins to boot.
    Restart your computer if you need to hear the beeping again. You're not likely to make whatever problem you have worse by restarting a few times.
  3. Write down, in whatever way makes sense to you, how the beeps sound.
    Important: Pay close attention to the number of beeps, if the beeps are long or short and if the beeping repeats or not. There is a big difference between a "beep-beep-beep" beep code and a "beep-beep" beep code.
    This is all important information that will help determine what issue the beep codes are representing.
  4. What steps you take to solve a particular beep code will differ depending on the BIOS manufacturer.
    Choose the correct beep code troubleshooting guide below based on your motherboard's BIOS manufacturer:
    Tip: Not sure what brand of BIOS is on your motherboard? See this How to Determine Your Motherboard BIOS Manufacturer guide for some helpful advice.
Aug 07, 2011 | Everex StepNote® VA4103M PC Notebook
My computer keeps recylcling through the start up and I originally thought it was a bad hard drive but I took it apart and found that my fan was running and the hard drive seemed to be spinning. The...
Exactly how far does your computer get before it restarts? there is normally a short beep during the startup phase, do you hear the short beep, or is it a long beep or a combination of different beeps?
I am not saying that it cannot be the power supply but usually problems of this sort are a faulty graphic card or faulty RAM, worst case senario is a faulty motherboard. The first two you can test by adding an extra graphic card or replacing the RAM (or taking one out and then the other if you have more than one RAM) - BE AWARE that you can damage your computer or the RAM itself if you touch the wrong things and you are have a static charge.
Oct 20, 2010 | Bestec (ATX-250-12E) 250-Watt Power Supply
Dell Dimension 9200 beeps on startup, with nothing...
A beep code of 3-3-4= Video Memory(RAM) Test Failure that would explain why you get nothing on your screen the first thing you would need to do is disconnect your monitor and try it on another computer. if it works fine then the problem is your video card. If that the case and the video card is intergrated with the motherboard, you will need to repalce the motherboard --- Sorry-- Please vote me a 10 when this works
May 20, 2010 | Dell Dimension 9200 PC Desktop
Singer FUTURA CE-250 beeping at startup.
you have a bit of cotton blocking a sensor or lever. normally the one that tells you ran out of cotton.
Oct 03, 2009 | Sewing Machines
Computer beeps and won't startup
try to open your cpu, and fix some hardware inside, maybe theres something lose there like video card or your RAM, i encountered also that problem. try to do this.maybe it can help.
Jan 21, 2009 | Computers & Internet
Copier beeps after scanning
Is this connected to a Vista computer? There might be a few extra things that need to be turned off permanently in the computers admin settings.
Nov 21, 2008 | Xerox Office Equipment & Supplies
Computers & Internet Logo
272 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
