Question about Mitsubishi WT-46809 46" Rear Projection Television
I have a 2-2 error code and tv shuts off after a couple seconds any ideas?
  • Mitsubishi Master
  • 8,617 Answers
Thats almost always caused by a shorted convergence circuit. Installing a convergence repair kit will usually solve that issue. You can get the convergence repair kit for that model which contains the parts and the CD with repair instructions from www.tvrepairworld.com
Posted on Feb 18, 2012
2 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: Mitsubishi WS-55819 Won't turn on
If F9A04 and F9A05 are open the convergence ICs will need to be replaced as well as the two pico fuses. You will need two STK392-570 Convergence ICs and two 5 amp pico fuses. You ca get the replacement parts at the following link with free installation instructions. heres thelink.
http://servicemanuals.vstore.ca/
Posted on Jan 22, 2009
My T.V. Will power on for a couple seconds then immediately turn off! Please help!
Unplug the unit from the outlet for at least 1 hour and check if the symptoms persists. If yes, check if the unit can give an error code by following the steps below.
- Power on the unit and wait until the initialization takes place.
- Press the front panel "Input" and "Menu" buttons at the same time and hold it for 5 seconds, it will activate the error code mode. LED flashes a two digit error code. Example, if the error code is "22" the LED will flashes two times pause and then flashes two times and will repeat the error code for 5 times.
"12" means no error has occured.
Please let me know what will be the result to assist you further.
Regards,jimvincentvillanueva@yahoo.com
Mar 07, 2012 | Mitsubishi WS-55313 55" Rear Projection...
I have a Mitsubishi tv ws 65413 that when you turn it on 5 sec later it shuts off, I called a tech today he said the tv is shot and do not make parts any ideas??
yes, if set comes on and shortly after shuts down do this:
On front of set press and hold both the menu and input (some may call latter device) for five seconds and release.
Watch power light which should blink two digit error code:
2 blinks, 2 blinks a pause and then repeat is the most common.
What is error code?
This is a self check feature built into the set to see where problem is.
Steve, SD TECH
Oct 22, 2011 | Televison & Video
My tv shuts off every 30 min after will reseting it makes a difference if it does where is the reset button
when the set shuts off on the front of the set press and hold input and menu buttons at same time for at least five seconds and let both go.
Power light will blink an error code like two blinks, two blinks, a pause and repeat it several times; error code will give some idea where problem is, 1,2 blinks is no error found.
SD TECH
May 18, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Tv shuts itself off the standby light wiil flash a few times and then shut off , you can hear it for a few seconds before it shuts off but you can't see picture
If you count the flashes, that is an error code and a Sony dealer or us can tell you the area of the fault. From that you may get a good idea as to how expensive the repair might be.
Hope this helps.
Nov 09, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
I was watching TV and suddenly the screen went black. No picture, no sound. On/off timer LED on TV started blinking. I could not turn it on (or off) with remote or ON switch on TV. I found that if I...
The television is shutting itself off to protect itself. The blinking light is a code pattern. The specific code determines whether or not you need an LCD Controller Unit, Main Board, power supply or something else. You would need the service manual. There are parts distributors you can get it from and the parts as well. If soldering and tv repair is not something you are entirely familiar you may want to seek a tv repair person. The manufacturer's support may walk you through the service menus to complete a factory reset depending upon the symptoms.
Sep 28, 2010 | Televison & Video
Sharp LC-26D43U TV. After power is turned on the power light comes on for a couple of seconds and then there is a click and the power light blinks 4 times then pauses and repeats the 4 blink sequence......
Power board is detecting an 'over-or-under-voltage' condition from other circuits. Could also be high dc volt shut-down. In either case, the tv is in protection mode to stop further damage this is why it flash an error code 4 times. Each number flash intervals tells the tv-technician what area the fault may potentially be. take it back if its under warranty, or have a repair shop near you fix it.
Nov 20, 2009 | Sharp LC-26D43U Television
Power up
the error code will be a blink code from the led it should blink a couple times vbriefly pause and then blink again. Count the blinking led in between the slight pause.
Aug 03, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WT-46809 46" Rear Projection Television Logo
168 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
