Question about Singer Confidence 7469 Mechanical Sewing Machine
Do you have a diagram on the Singer 7469 for repair
I would like to do a bobbin winder repair on the machine and need a diagram .
2 Suggested Answers
  • 980 Answers
SOURCE: singer 328k bobbin winder replacement
Follow these instructions, undo the 2 screws on the right hand side plate where the balance wheel is and take the plate off, undo the screw on the chrome stop motion wheel, undo the stop motion and take it off, take off the 2 pronged washer and notice which way it goes on, not a problem if you can't remember, you should be able to pull the balance wheel back so you can get to the screws on the winder, if you can.t and if you have a problem getting the balance wheel all the way then go the very bottom of the machine and you will see 2 big holes and one of the holes will lead you to a big screw and nylon adjuster, slacken the screw and move the nylon adjust so the belt goes slack, you can not take the balance wheel all the way off to get to the screws on the winder, take the old one off and screw the new one on, whilst you have the balance wheel off it would be wise to put some thin oil on the shaft before you put the balance wheel back on, when you have the balance wheel on and the and the belt round the pulley turn the nylon adjuster so the belt is tight and tighten up the screw, put the side plate back on, put the 3 pronged washer back on, put the stop motion wheel back on and just tighten finger tight then tighten the small screw.
Posted on Nov 22, 2009
How do I repair a Singer 7469 that won't catch bobbin thread?
Try a brand new needle.
If that doesn't work, it's possible the machine is out of time. Search for sewing machine timing or take it for service.
Nov 21, 2017 | Singer Sewing Machines
Just received a singer futura II model 920 which seems to sew just right. When I tried to wind a bobbin, I just can't get it done.
If it is a new machine, take it for warranty service. Sounds like perhaps something is misaligned with the release lever. In the meantime, a standalone bobbin winder can be purchased at JoAnn's, Hancocks, or Amazon.com for about $35 (helps reduce wear & tear on your machine).
It's very difficult to say whether it is worth the price of repair. On the other hand, what would you do with a machine that doesn't work? It could be something very simple that can be repaired for a small price, or it could be something expensive. (However, since you indicate it is only the bobbin winder that is faulty, otherwise the machine works with that one exception, you can save up to get the bobbin winder fixed.) FWIW, a standard check, clean & oil could cost around $100 (based on what I currently pay for my machines). However, you could ask what it would cost to fix the bobbin winder only.
From a search on eBay:
http://www.ebay.com/sch/i.html?_nkw=singer+futura+920
You can track similar machines and their sales prices to determine if it would be worth fixing your machine. Even if you don't, you can still purchase the standalone bobbin winder and continue to use the machine anyway. A working machine is better than none at all.
Feb 02, 2016 | Singer Sewing Machines
Singer confidence sewing machine won't pickup bobbin thread
Make sure the bobbin is inserted into the bobbin case spinning the correct direction and rethread and try.
Oct 03, 2014 | Singer Confidence 7469 Mechanical Sewing...
I have a Singer Confidence 7469 and was sewing and the machine just stopped. I cannot lower the needle or turn the wheel, it just beeps.
Check to see that all of the thread is out from under and around the bobbin. You may have to take the thing off that the bobbin fits into. Sometimes lint and excess thread pieces will build up under there. Did you check to make sure the wheel that you turn when you wind the bobbin is snug?
Apr 05, 2014 | Singer Confidence 7469 Mechanical Sewing...
Singer 7469 clicking sound
You've either got a bent needle or your machine is slightly out of time. Take it in to have it serviced.
Jul 24, 2013 | Singer Confidence 7469 Mechanical Sewing...
I have a singer confidence 7469 quilter, the upper thread keeps bunching up in the bobbin case. I've tried re threading numerous times with no luck.
try changing the needle
make sure the bobbin is turned the correct way in the bobbin case
make sure the thread has not come off the thread take up lever
clean under the needle plate and in the bobbin area for lint
Jan 29, 2013 | Singer Confidence 7469 Mechanical Sewing...
How to repair the bobbin winder on the singer cg550
if you have a top bobbin winder that is jammed the only way to f ix it if you can't replace it is to put some WD40 on the spindle and let it soak down then put an electric drill over the spindle and switch on slowly and it should free off, if it just not catching to wind a bobbin you may need to replace the winder rubber which means getting inside the machine
Sep 05, 2011 | Singer CG550 Mechanical Sewing Machine
We have 2 singer 7442 machines and they will no longer wind the bobbin. Up to this point we followed the instructions the manual gave on how to thread and wind the bobbin. How do we fix?
If you have followed the instructions and the winders do not work, the machines will need to be repaired, or you could purchase a Sidewinder Bobbin Winder and forgo the expense of having the machines repaired.
Mar 08, 2010 | Singer 7442 Mechanical Sewing Machine
I have a singer 503A. The bobbin winder will not
When you have the winder rubber on try and turn the winder by hand, if it does not move the chances are the winder has seized, if the winder wheel is moving but not the spindle then the grip (thread) has worn, if you cannot move the whole winder by hand and it has seized you need to get some WD40 and spray a few drops down the spindle, take an electric drill and put it over the top of the spindle and switch it on slowly and it will probably free it off, be aware of oil splashing out.
you mighjt get a digram from www.tandtrepair.com
Feb 24, 2010 | Singer Sewing Machines
I have a Singer Confidence 7469. It has only been
The bobbin case is not supposed to move. It should only have a little bit of wiggle room so there is enough clearence for the thread.
Feb 18, 2010 | Sewing Machines
Singer Confidence 7469 Mechanical Sewing Machine Logo
37 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
