Question about HP Photosmart Premium C309A All-In-One Printer
HP Photosmart Premium C309g All-In-One Printer paper mismatch
I am trying print on 5.5 X 7.5 and will not let me! Regardless of the size specifications I have entered.
  • 154 Answers
SOURCE: Hp Photosmart C5280 error message "wrong paper size or type"
set it on control panel of printer
Posted on Apr 24, 2009
SOURCE: Paper Mismatch
I had this problem on the 6300 and was able to fix it by doing the following:
After selecting print, select preferences.
Select the Features tab.
Under Resizing Options, select "Custom" from the drop down menu.
Put in the custom dimensions of the paper on which you are printing.
Save it under a new name (e.g., "Invitation")
When it is time to print,
Select "More" from the drop down tab under Resizing Options.
At the bottom of the list of those options, you will see your custom sized saved.
Select it, and happy printing.
Posted on May 04, 2009
  • 6 Answers
SOURCE: Can't Print Invitations
There is a workaround for this problem by tricking the printer.
The paper sensor, on my printer model hp4500 seems to only sense the paper at the beggining of the print job.
What I did to trick the printer to print on odd size paper is slide the paper adjuster to 8.5 and put a regular white sheet in. Then put your odd size paper under it. When you print your document set the number of copies to 2 and print. The printer is going to sense that the paper is correct, and start the job.
Here is the tricky part... once the first 8.5x11 sheet is almost all the way through quickly slide the paper adjuster over to match the size of your odd width paper. The printer should pick up the odd paper and print the second copy. Fool you printa! You should be able to do batches of odd paper size under the first 8.5X11. I hope this helps.
Deny
Posted on Jun 27, 2009
sgoswami
  • 114 Answers
SOURCE: HP Photosmart Premium c309a series will not print
Try This :
Try printing from micrsoft word; Click on tools;
Click on Envelopes and Labels
Click on "OPTION"
Under the TAB Envelope Option you will get Evelope Size;
Scroll Down to the bottom you will get an option "Custom Size " Select it;
Set the accurate size of the envelope;
Click on Printing Options
Select the Feed method and make sure you do it the same way;
And then try to print this should resolve your Issue
otherwise let me know
Regards Soumajit
Posted on Sep 21, 2009
Testimonial: "Still not working. Great idea, tho."
  • 159 Answers
SOURCE: Ink Failure on HP photosmart premium C309g printer
Turn off the machine, unplug the power cord from the back of the machine, remove the ink cartridges (lift the lid up at the base of the control panel), wait 2 min, plug the power cord back in, press the on button, wait until the printer prompts that the ink cartridges are missing, then replace the ink cartridges. If this doesn't fix the problem you may have to re-prime the ink lines to clear the error. You can find instructions for this at http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-1/.
Posted on Mar 15, 2010
Message is- alignment failed
try resetting your printer. test print out and alignment. make sure it is as a default printer on your computer.
Oct 11, 2014 | HP Photosmart C309g Premium All-in-one...
HpC309g printer keeps gaming -reason Wrong size paper but it is not
The document you are trying to print is set to a different paper size than the printer has. It is looking for paper of the correct size to be installed so it can print the document.
Aug 28, 2014 | HP Photosmart C309g Premium All-in-one...
I replaced all the ink carts in my hp photosmart premium c309g printer know the blak wont print at all and all the color prints faded. What do i do?
The ink may not reach the printhead completely.
You could wait at least 1 hour before printing.
Also do a ink cleaning cycle.
Feb 03, 2011 | HP Photosmart Premium C309g multifunction...
Hp photosmart premium model c309g. paper is being turned crooked after the printer initiates to print. wont print bc of this
you likely have a small piece of paper in the paper path, or a small object. Some of the paper path cannot be seen without dismantling (which I don't recommend)
It can be difficult to find someone to repair it, and HP's solution is to convince you to 'upgrade`
Sep 20, 2010 | HP Photosmart Premium C309A All-In-One...
HP Photosmart Premium c309a series will not print envelopes. I keep getting an error message that says paper mismatch. It doesn't matter what size envelope I put in, it always gives me an error message....
Try This :
Click on "OPTION"
Regards Soumajit
Sep 21, 2009 | HP Photosmart Premium C309A All-In-One...
HP Photosmart Premium C309A  All-In-One Printer Logo
233 people viewed this question
Seeker5211
Seeker5211
