Question about Husqvarna Garden
Husqvarna 340 will not idle
I have a Husqvarna 340 that I can't get to idle. It was drained before it was put up, and I have fresh fuel (straight gas - not ethanol) and using Husq. oil for the mix. It starts up OK, but won't idle when the choke disengages. I can work the choke manually to keep it running for about 15 - 30 seconds, but then it cuts out. Not sure if the needle valve adjustment screws need to be adjusted, since the weather is quite a bit colder now than when I used it last? I've played around with them without being able to get it right. Any tips on checking setting the H and L jet adjustment screws and the T Idling adjustment screw might be a big help!
    An expert who has answered 20 or more questions within one hour.
  • 66 Answers
To set the H and L adjustments, screw them in until they lightly seat. Then back both out 1 1/2 turns. This will get you in the ballpark. They will still need to be fine tuned for proper settings.
Posted on Apr 07, 2017
SOURCE: Cant get clutch cover off new Husqvarna 235e chain saw
Mine did this when nearly brand new. You likely have a nasty jam of oil and sawdust stuck between the chain brake and the flywheel. It can be loosened by either careful prying of the case or precise shots of carb cleaner up in the housing. While you are in there look for a buildup of oil around the chain brake connection to the kickback paddle.
Posted on Dec 31, 2008
  • 58 Answers
SOURCE: Husqvarna 350 wont stay running?
ok,  The choke is used to change the air/fuel mixture by "choking" off the air that goes to the carburator.  The choke is only used to get the motor running in cold temperatures.  Once the motor is started, the choke must be opened or the motor will flood and stall when you open the throttle.    I hope this solves your problem.  Best wishes, Michael Mittelsdorf
Posted on Jan 10, 2009
  • 87 Answers
SOURCE: can i ajust chain oil flow rate, to lubricate bar,
No. It is an automatic oiler.
Posted on Apr 10, 2009
  • 41 Answers
SOURCE: I have a husqvarna 340 chainsaw and it will not
Turn the screw labled T in a little. This will raise the idle setting. Heres a link to the manual. Look on page 29 of the .pdf
Posted on Aug 02, 2009
  • 2220 Answers
SOURCE: 25 yr old Husqvarna 266. starts fine, lots power, but won't idle.
I think you have exceded our level of help. Please try here. Chainsaw thread (free to join)
You might read this thread
I searched for "Husky 266" and got many positive hits. She is a respected machine.
Posted on Oct 16, 2009
Where to find vent line on 359 husqvarna
Husqvarna chainsaw fuel line check and replace - YouTube
? 3:44
Feb 6, 2012 - Uploaded by mweba1
359. ... Husqvarna chainsaw fuel line check and replace. mweba1. SubscribeSubscribed .... You will want to inspect the tank vent and fuel line.
Husqvarna common air leak - YouTube
? 1:51
Apr 11, 2012 - Uploaded by mweba1
Husqvarna common air leak ... Husqvarna 136 ChainsawCarburetor Rebuild & Fuel Line Repair - Duration: 22:39. by donyboy73 59,377 views.
Husqvarna 359 Professional Chain Saw Review
Dec 14, 2015 | Husqvarna Garden
Why does husqvarna 123hd60 bogs on revs
Mix up some "carburetor & fuel injector cleaner" in a batch of fuel, Nathan, at the rate specified on the bottle of cleaner. Run it through the hedge trimmer just like normal fuel. For right NOW, you can use the choke to keep the trimmer running. As the cleaner works, you should need less & less choke to keep it going.
It may take a while.
Next time you store that trimmer for winter, drain it fully and run it until it dies from lack of fuel. Then it won't form varnish on the carburetor jets over the winter - that varnish is what's causing your problems now.
Aug 04, 2014 | Husqvarna 123hd60 Handheld Dual Sided...
Husqvarna lawnmower will not start after sittling idle for winter. Bought new last fall.
I fear this is stale fuel in both carb and tank, drain the tank, if the carb has a float bowl remove it and empty the contents, refill with fresh fuel and pull until it fires up.
Mar 09, 2013 | Garden
340 husqvarna wont run
Carburetor, compression or fuel problem.
Apr 21, 2012 | Husqvarna Garden
I took my husqvarna 340 apart and need a diagram to put it back together
I'm having difficult time aligning the throttle arm any secreats
May 17, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I'm working on a Husqvarna backpack style blower and it starts great but when you give it gas it rev's up then dies, it will set and idle for ever but hit the trigger and it dies,
not getting enough fuel, start with the filter then fresh gas, then I would check the exhaust screen and muffler making sure they are't plugged, then remove your carb. and dissasemble it and clean /or put kit in it
Apr 21, 2011 | Husqvarna Garden
What is the gas to oil mixture for the Husqvarna 340 Chainsaw
The fuel to oil ratio is 50:1. Be sure to use a modern synthetic saw oil available from home centers, hardware stores, and saw dealers. Premix in it's own container with fresh fuel and be sure to shake the container thoroughly just before you fill the tank each time to prevent oil starvation. Hope this helps!
Dec 22, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna 340 chainsaw will only run for a few seconds on choke, tried cleaning carb, carb adjustments do not help. will not run at all with choke off.
Check the fuel filter, air cleaner, and muffler for plugging. Check the fuel lines for decay or other problems. Make sure that you have fresh fuel mix in the tank (50:1 ratio). Mix the fuel/oil in it's own container and shake the container thoroughly just before adding to the tank each time to prevent oil starvation. When you were cleaning the carburetor, did you check the condition of the lower diaphragm for flexibility with no holes or cracks? Turn both jet screws CW to stops (lightly), then back each out CCW 1-1/2 turns. Start the engine and allow to warm up, then pull the throttle full on. Adjust the H jet needle CW until the engine starts to speed up. Proper adjustment is when the engine 4-strokes unloaded, but immediately 2-strokes when cutting. Release the throttle and adjust L jet needle CW for better idle, but allows the engine to 'follow the throttle'. Hope this helps!
Nov 07, 2010 | Husqvarna Chain Saw 20" Bar
Garden Logo
122 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
