Question about Casio Cameras
Charging port does not charge
  • Paul Dicke Feb 17, 2012
    this is a casio Rock cell phone.
  • 734 Answers
Change you battery?
Posted on Feb 18, 2012
Cant findwhere to charge ac
if it is a window unit you are trying to charge - chances are - there are no charging ports. Hardly any window units (that I know of) have charging ports when manufactured. The only time you'd find charging ports on one is if it had been 'charged' at some time in it's past history. Most window units run years and years without needing to be re-charged. Therefore - if you cannot find charging ports it means it's never been charged since being manufactured. Always 'be sure' a unit needs charging before opening the system.
Through the wall units (like in motels) sometimes - comes with charging ports - although not all the time.
Central units all have charging ports and they are located on the condenser (outside unit). Just follow your copper lines (one big one -usually insulated and a smaller one) - into the unit and the charging ports are not easy to miss.
hope this helps.
Jun 18, 2011 | Heating & Cooling
My xperia is nt getting charged
The charging port of your phone should be the cause of the problem. It's either the charger is not contacting the charging port well enough or the charging port might be defective and needs to be replaced.
Use a pin to scratch the surface of the charging port and try again. If that doesn't work, then know for sure that you will have to replace the charging port.
If you feel you can do the replacement yourself let me know when you get a charging port replacement so that I can direct you.
Lastly, try another charger first, before you attempt to replace the charging port..........
Good luck....
Mar 21, 2011 | Sony Ericsson XPERIA X10 Cell Phone
1108notcharging
Hi, when a phone does not charge, Usually is either from the charger or the charging port of the phone that is bad.
Use the charger on another nokia phone to see if it will charge. If it does charge on another phone, that means the charger is working,but the charging port is not.The charging port is located below the phone where the charger is been inserted.
It"s very easy to replace.when you unscrew the phone,remove the phone board,the charging port is removable,just buy another charging port,and replace and you are done.
Take care.
Oct 05, 2010 | Nokia 1100
1600 not chargieg
If your phone is not charging, try use a similar charger to charge to see if it is charger problem, if the similar charger did not charge your phone, it means the problem is the charging port on your phone.
The charging port of your phone is bad and will need to be replace. Replace the charging port on your phone to solve the problem of your phone not charging.
Once the charging port is replaced, the not charging problem with your phone solve.
Take care.
Jul 23, 2010 | Nokia 1600 Cellular Phone
My phone is not charging
Take care.
Jul 23, 2010 | Sony Ericsson Walkman® W880i Cellular...
Notcharging
Try use a similar charger to charge it, if it does not still charge it, it means the charger is not the problem, the problem is the charging port.
The problem with your phone is the charging port, all you need to do is to change the charging port of your phone and you will see that your phone will charge.
Replace the charging port as advice and you see that your phone will charge.
Take care.
May 26, 2010 | Motorola Mobility W220 Cellular Phone
Not charging
Have try to use another similar charger to charge it to see if it will charge? If you have and yet it did not charge, it means the charger is not the problem.
The problem is the the charging port, the charging port of your phone is bad that is why it is not charging, all you need do is to change the charging port of your phone and you will see that your phone will charge.
Replace the charging port and you will see that the phone will charge.
Take care.
May 20, 2010 | Nokia 1209 Cell Phone
Not charging
Have you try to use another charger to charge it to see if it will charge, because it could be that your charger is bad, if you have and it did not charge, no problem.
It means the charging port of your phone is bad that is why your phone is not charging.
All you need to do is to change the charging port of your phone, changing the charging port of your phone will make your phone charge because the one there at the moment is bad.
Change the charging port and you will see that your phone will charge.
Take care.
May 02, 2010 | Nokia 2600
Phone not holding charge with new battery
Have you try to use another charger to charge and it doesn't hold charge? if yes., no problem because it be that your charger is bad. But since it does not charge with another charger, it means the charging port is bad.
The problem with the phone is the charging port, the charging port of your phone is not charging the phone that is why it doesn't hold any charge,
All you need to do is to change the charging port of your phone and you will see that your phone will hold charge.
Take care.
Apr 28, 2010 | Motorola Mobility SLVR L7 Cellular Phone
Cameras Logo
15 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
mohamed salim shaikh
Are you a Casio Camera Expert? Answer questions, earn points and help others
