Colman gas furnace ignitor does not always come on
Ignitor does not always come on
  • Heating & Co... Master
  • 2,514 Answers
Ignitor could be breaking down and need replacing or it could be your pressure switch ,
Posted on Feb 18, 2012
Buffalo12980
  • 625 Answers
SOURCE: colman furnace
look on your burner control relay - look for terminals marked T and TH.  connect up a honeywell thermostat here.
Posted on Oct 15, 2007
Therinnaiguy
  • 1420 Answers
SOURCE: my fan is always on on my colman model eb12a
If the room air fan is always on you could have the thermostat in the On position rather than in the Auto position, You could have a bad fan relay or the furnace is a "Lock-out" mode. A Lock-out occurs when the furnace attempted to start but could not for some reason. The computer board logs an error code and blinks a number of times. There should be an error code chart where ever the wiring diagram is located in the furnace. It may give you an idea where to start looking if in Lock-out. Good luck.
Posted on Dec 03, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: lennox diplomat furnace will not always ignite.
Maybe, look for bad wiring connections and retighten the ground wires from circuit board to cabinet. Take a can of air and clean the burner tubes being careful not to blow on the igniter. Are ther any error codes blinking when it does not light? Read on for some more tips.
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Posted on Dec 29, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: I have aGibsonGMPN 060-3 gas furnace. The ignitor
May have a dirty flame rod. Look in the burner box at either the far right or far left for a probe that sticks in the flame of a burner. There will be only one wire going to it. This rod is a safety sensor that shuts off the gas if it does not sense flame within a few seconds. If you brush off the rod with a toothbrush or Scotch Brite pad it may take care of your problem. If not, make sure the flame travels from burner to burner quickly. The burner tray may need to be brushed off.
Posted on Jan 06, 2010
  • 2514 Answers
SOURCE: My friend's Colman Furnace Model number
check air filter is clean and all floor vents are open and not blocked see what room stat is set at this could not be working at the temp you need , furnace might need servicing
Posted on Nov 27, 2010
I have a 1984 Colman propane furnace that is short cycling
Why does the gas furnace short cycle - YouTube
? 11:07
https://www.youtube.com/watch?v=3LBut8fWcw8
Apr 23, 2012 - Uploaded by grayfurnaceman
When the gas furnace short cycles, and it does not bring the structure up ... have a frazier Johnson furnace with 9 blinks on diagnostic light. just ...
Mobile Home Furnace Troubleshooting - Mobile Home Repair
www.mobilehomerepair.com/articlefurnace.php
Jan 17, 2016 | Heating & Cooling
Colman gas furnace wont light
Is it natural gas or propane? If propane, make sure you are not out of gas. Does it have electronic ignition or a manual pilot? if pilot, make sure the pilot flame is still lit and the control knob is turned to the "On" position. If it has electronic ignition, shut off the power to the furnace and then turn it back on and see if resets and lights.
Feb 16, 2015 | Coleman 7990-319p Evcon Gas Furnace...
Intertherm furnace ignitor will not kick on
furnace operation= call for heat- inducer blower motor energizes- pressure switch makes- after a few seconds ignitor activates.
If this series of processes is not whats happening the furnace may be going into a code safety. Call to discuss further=913-557-9111
Feb 25, 2014 | Intertherm 56000 Btu Gas Furnace
How to install a spark ignitor in a gas furnace?
How to install a spark ignitor in a gas furnace? - Fixya
www.fixya.com/support/t15727344-install_spark_ignitor_in_gas_furnace
Jan 8, 2013 - How do I connect the high voltage wire to the Model 990-516 spark - Air ... SOURCE: Goodman furnace wont light, ignitor suspected. Notice.
carrier igniter
Jan 08, 2013 | Heating & Cooling
Amana furnace. The furnace goes through the cycle but wont ignite. I have already checked the ignitor.
Try blowing out the jet Burners with compressed air especially the one nearest the Ignitor. Right through where the gas comes in. These can get dusty and cause ignition failures. Also check to see if the Ignitor is in the path of the burner and has not somehow gotten bent. 100 or so ohms on the Ignitor should be good.
Oct 10, 2012 | Amana GMVC80905CX Gas Furnace
Why heater coils glow?
It sounds like you're describing one of two things. The hot surface ignitor in a gas-fired furnace, or the resistive heat strips in an electric furnace.
The hot surface ignitor in a gas-fired furnace lights the burners. This ignitor in modern furnaces serves the same purpose as the standing pilot flame did in older furnaces. It provides the required heat to ignite the gas at the burners. Without an ignition source, a gas-fired furnace cannot provide heat. When the ignitor is activated it will glow bright orange or yellow.
The resistive heat strips in an electric furnace actually provide the heat to a home or building. When the furnace turns on, the heat strips are activated and usually glow orange when they reach peak temperature. In almost all cases, the heat strips are not easily seen or accessed without removing covers or panels inside the furnace.
Feb 28, 2011 | Heating & Cooling
My friend's Colman Furnace Model number DGAA90BDTA, runs and lights but doesn't get warm enough? It's a gas furnace with an electric igniter. Any help is appreciated.
Nov 27, 2010 | Coleman Heating & Cooling
My fan is always on on my colman model eb12a furnace and i dont have much heat comeing out of the vents
Dec 02, 2009 | Coleman Heating & Cooling
Heating & Cooling Logo
53 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
