Question about Samsung Computers & Internet
Samsung hard disk component broke
My Samsung hard disk hd204UI does not mount any more but clicks. When I examined the printed circuit board I found a broken component with the letters 1R2S. Can I replace it so that I could back up my data? Thanks in advance!
  • Matti Kontio Feb 18, 2012
    Thanks Jeff! How can I find out what component this 1R2S is? I have done lots of soldering in the good old analog days. I do have another HD204UI, three months older, with minor differences. Do you think I can swith the pcb:s ? Best regards Matti
  • Jeff Parker Feb 18, 2012
    As long as it is the same model and the connections between the pcb and the internal components are the same then it should work. I am not sure what it is, that naming does not match up with any of the standard naming. Next to the component there should be something that tells you what it is(R for resistor, C for capacitor, L for inductor, D for diode, Q for transistor
    Scholar:
  • 99 Answers
The component can be replaced if you can find an equivalent part and have experience soldering, or know someone who can solder. It would normally be easier to find someone who has the same drive or to buy another drive of the same model and just move the circuit board from the working drive to the not working drive, copy the data off of it, then move the circuit board back. Or you can just keep the working circuit board on the drive and continue using it as you did before.
Posted on Feb 17, 2012
Testimonial: "Exchanging the circuit board enabled me to rescue the data. Thanks! Now if I only could find out what the defective component 1R2S on the board is so I could replace it."
  • tom_kaller
    tom_kaller Jul 21, 2012
    normally a 1R2 stands for 1.2 ohms. i do not know meaning of S. tomkaller
Samsung pn64h5000af plasma, no power, no standby, no standby light
First i suggest you check the wall outlet by plugging something else into it and making it's working. Now that you determined the plug has power unplug the plasma, open it up and look at the capacitors, most are probably blue and look like small standing up tubes, compare the tops of them with the rest, if they all look the same, none are swollen up or dark, then look for any black marks on the circuit boards, if you find a burnt spot, if you have some advanced repair skills and a solder gun, you can remove the bad component and search ebay or other online places and solder in a new one or replace the bad circuit that you found, if you cant find the burnt spot, then u may need to remove more screws and examine the back sides of the boards. If not advanced to do a solder repair, you can probably find that panel or bad circuit and replace it at a little more cost then only replacing a bad relay, capacitor, etc. its not hard and you have nothing to loose by soldering in a new part to fix yourself.
Oct 28, 2016 | Samsung Televison & Video
How do i find the value of a burnt component on a circuit board from a samsung tv?
JAMES THERE SHOULD BE A SITE ON THE INTERNET WHERE YOU COULD CALL SANSUNG CUSTOMER SUPPORT TAKE A LOOK!
Jan 24, 2016 | Samsung Televison & Video
Are sceptre x505bv-fmdr and x505bv-fmqr circuit boards interchangeable?
Sceptre X505BV IR Sensor Board Please Read The Note ...
www.ebay.com > ... > TV Boards, Parts & Components eBayThey are not interchangeable. ... Sceptre X505BV IR Sensor Board - Please Read the Note C2050C .... $6.89 Buy It Now or Best offer Free shipping; Sceptre X505BV-FMQRIR Sensor Board $6.89 ... Sceptre X505BV-FMDR, IR. ..... For Samsung Galaxy Note II,; Cell Phone Printed Circuit Board For Samsung Galaxy Note ...
Sceptre X505BV All in One IR Sensor Board 142011100011 ...
eBaySceptre X505BV All In One IR Sensor Board - 142011100011 - Please Read the Note in ... offer Free shipping; Sceptre X505BV-FMDR IR Sensor Board 142011100011 ...Sceptre X505BV-FMQR IR Sensor Board. ... They are not interchangeable. .... PrintedCircuit Board for Galaxy Note 3,; Printed Circuit Board for Samsung ...
Dec 26, 2015 | Sceptre Televison & Video
I have a 42" Vizio
The components that are most likely to produce such a sound will also leave visible traces behind. The most likely is a capacitor but these are used in many different packages and can be cylindrical with axial leads mounted parallel to the board, may be vertically mounted or with smaller values, surface mounted. When these fail, they can cause the case to burst or chemical deposits to leak onto the board surface. The other device may be a power semiconductor, most often in black epoxy packages mounted with or without a heatsink and when they catastrophically fail, may have a jagged crater in the epoxy. You should have a good light source to examine the boards. While doing so, look for any signs of an 'arc-over' such as burn traces between the printed circuit runs.
The most likely place for a failure of this kind is not on the largest of the boards but on smaller, separate boards on which the power supply is normally found.
Before invading the innards, pull the AC plug for at least several hours and preferably overnight to avoid the chance of getting a painful shock from exposed component leads since some components can store a charge for hours.
Jun 24, 2011 | Vizio 42 in. LCD TV
Its a Toshiba RD-XV49DT DVD/DivX/VHS Player/Recorder Combo, replaced power supply board as was blowing fuses found components have shorten out and now after replaced board, video works and i think hard...
The controller circuit (usually a small board connected directly to DVD drive - it is either part of the drive or a sub-assembly which is attached - and contains several ICs and small capacitors and a lot of surface-mounted components on its copper side) is probably faulty, possibly due to the original bad PSU (which you have since replaced), chances are the original faulty PSU has damaged this circuit - usually DVD drives operate around 12V DC or so. The digital controller circuit/board not only has the EEPROM/CPU etc. on it, but also has a servo supply - for the DVD (the VCR servo supply is on the motherboard). This powers the disc tray and traverse unit. The controller is not serviceable at component level; it must be replaced and in some cases, the DVD drive must also be replaced where the board is not separate to the drive. This may not be economical.
It may just be a simple case of a blown digital controller circuit - but be warned, this board is not cheap - it is part of a 'module' (the disc drive and controller together = DVD module), and you may not be able to obtain the board without a new DVD drive. Up to you what you do from here, and you might be lucky in terms of the motherboard and HDD - no damage there.
Apr 11, 2011 | Toshiba Televison & Video
I have an apple cinema display 23 which is over 2 years old connected to a Power PC G4 tower with ATI video card. Last week it would not wake up from sleep. Little light gives 3 blinks, short long short....
drtech572, Did you see any solder joints that looked "Frosty" compared to what I call "mirror finish" ? All solder joints should have "mirror finish".Also examine all the "through hole mounted" components that are mounted (soldered) to the board for what is known as "thermal overstress fractures". You will need large magnifying glass or better still, a 10x-20x inspection microscope to do this. Examine the larger and more weighty components first and then move on to the smaller ones. You will be looking for a circular "hairline" thin crack around a components lead where it is soldered to the board. There are two causes for this. 1. Shipping & Handling. 2. Thermal shock--cold to hot to cold to hot etc. On some printed circuit boards you will see "globs" of hot-melt glue that might have been spilled onto the board. No! No! No! The glue was put there for cause #1. You should also inspect for any solid state devices (transistors, integrated circuits, rectifiers, opto couplers) that may have "cracked" bodies or leads that are not soldere properly. Also check the bottoms of electrolytic filter capacitors. sometimes they won't "DOME" the top of the aluminum "can" housing. They will "vent" from the bottom pushing the rubber seal plug out towards the board where they are mounted. I hope this has been of some help to you. please rate this response on fixya. I'm louie12fix on fixya or lmistyrel @aol Bye for now.
Oct 09, 2009 | Apple Computers & Internet
The HDMI connector broke loose from its mounting inside the tv.
hi there, you can just re solder the points onto the board once more without buying a completely new board. just remove the board and solder the contact point back on the board itself.that should fix it up for ya. thx for using fixya:)
Feb 08, 2009 | Samsung LNR269D 26 in. LCD Television
One more question
The electronic control board will have to be replaced. You can search online or call Sears (they can order just about any type of part for any type of product for you) with a model and serial number. Generally, the electronic control board is not that difficult to replace.
Jun 09, 2008 | Ovens
Samsung 160gig hard drive printed circuit board
try ebay with the same model number. You can transfer the circuit boards, retrieve the data, then you have a spare backup. Otherwise you can try to identify the component and check if digikey or mouser has a replacement. Sometimes if you're lucky the component is a bias diode that is designed to burn out with reversed power. Sometimes the visible damage may not be the only damage and other parts have fried. Touch a grounded object (like the case of your computer that's plugged in) before touching the components, and retouch it frequently, or wear static dissipative wrist strap
http://www.digikey.com/
http://www.mouser.com/index.cfm?handler=home
Nov 30, 2007 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Computers & Internet Logo
1,182 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
