Question about Motorola Mobility H681 Bluetooth Headset
What is the passkey for motorola h681 bluetooth?
How do i pair my Samsung Eternity to a Motorola H681
first turn on your bluetooth visability an make sure the motorola h681 is turned on then click add devices on the phone
Aug 17, 2011 | Samsung Eternity SGHA867 3G NEW
My phone is saying that my H681 is undiscoverable and I have a solid blue light on the headset.
The solid blue light is pairing mode, so you are doing it right. Try shutting both the phone and the H681 off, and turning them back on. We had a similar problem with my girlfriend's new motorolla headset while pairing it to a samsung vibraint. It worked for us after we did that.
May 09, 2011 | Motorola Mobility H681 Bluetooth Headset
Whats the pass key
Thanks for using FixYa.
The passkey is 0000 (four zeros)
For more details, download and refer to the manual in PDF format by clicking this link.
Please note: Adobe PDF Reader is required to view this manual. Click here to download the latest version of Adobe Reader.
Feb 07, 2011 | Motorola Mobility H681 Bluetooth Headset
H681 wont' pair with iphone
Select YES to pair. Enter the passkey 0000 and select OK.
if you have any OTHER devices paired remove them.
1 reset network settings on iphone
2 power off blue tooth device
3 power cycle iPhone
4 attempt to re-pair
Jan 09, 2011 | Motorola Mobility H681 Bluetooth Headset
Misplaced manual for bluetooth Motorola h681 need the passkey
Your headset's passkey is '0000' (four zeros). I couldn't find its user guide, but the one for the H680, which happens to be very close to yours, can be found here.
Hope you are able to sort your problems out soon.
Regards, Carlos
Aug 18, 2010 | Motorola Mobility H681 Bluetooth Headset
I need the passkey to install the bluetooth to my new phone, motorola H681
the default passkey for every bluetooth device is usually 1234. try it and let me know if it works. u have to pair it and enter the same passkey with your mobile/celfone.
Aug 07, 2010 | Motorola Mobility H550 - Bluetooth Headset...
Need passcode to link H681 bluetooth with blackberry
The passkey is 0000 (4-Zeros)
Here's the link for the manual:
http://dl.owneriq.net/f/f149aef3-3f56-4562-b997-6b6674c6caed.pdf
It's in PDF format. If you need Adobe reader to view it, you can download it free from here:
http://get.adobe.com/reader/
If you found this information helpful, please give me a big thumbs up when you rate my answer. Thanks!
Jan 07, 2010 | Motorola Mobility H681 Bluetooth Headset
Can't find my Motorola H681 numeric passkey for connecting it
The default is usually 0000 on most bluetooth headsets, try to find the manual for your bluetooth device, it should say.
Jan 08, 2009 | AT&T Blackberry Curve 8300 Smartphone
Motorola Mobility H681 Bluetooth Headset Logo
50 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
