Question about HP Audio Players & Recorders
Hp g72-260us suddenly shuts down on battery power only
The battery meter will show between 20 -50% power when it happens....no warning.....started about 2 weeks ago...shut down at 18%....then shut down next time at 28%.....then 40%....then 50%....works fine when plugged in
    Master:
  • 551 Answers
Your power setting is not work perfectly going to your battery option and click that then you setting power capability.
Posted on Mar 26, 2013
  • 11 Answers
SOURCE: My ipod stopped working
Yes, it is possible for a battery to die, though 2 or 3 months is a bit short. If you have some way of proving the date of purchase you should be able to take the iPod to an Apple store and talk to one of the "Genius" guys. If it is a battery it should still be covered under warranty. If it isn't covered under warranty, they will be able to get a replacement battery for you which would be cheaper than buying a new one. Hope that helps!
Posted on May 31, 2007
ThaMp3Doctor
  • 8596 Answers
SOURCE: Phillips GoGear SA5125/37 wont power up
The freezing at 87% suggests hardware malfunction, but you can try all of the "soft" fixes to be sure -
Triple Reset for GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player.
Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Posted on Jun 12, 2008
Petryxa
  • 40 Answers
SOURCE: Keeps shutting down.
The solution is found! There's no need to format your HDD
So.
- Unplug the battery;
- Press and hold the reset button for 20-25 sec;
- Put the battery back to it's place;
- Charge your device (when you plug the cable in, it turns on (note that a blinking lightning icon appears on the charging indicator), then it turns off with it's "shutting down" message, dont pay attention on this, just let it charge for about 10-15 minutes (note that the CHG bulb won't be lit));
- Turn on your device. The CHG bulb is lit, Archos doesn't shut down
- Enjoy
Posted on Jul 22, 2008
  • 22 Answers
SOURCE: Archos 605 shut down
Does it have power? If the battery is drained, it will NOT boot straight up when you plug it into your pc or docking station.
You need to plug it in for a good hour before trying to boot it up.
Once you've managed to boot it up, give it a full reboot by pushing a pin in the tiny hole at the bottom.
Posted on Mar 06, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: Opal MC4004A shutting down
Here is the user manual - it will show you a picture of where the hold switch is:
http://www.rcaopal.com/pdf/M40xx_IB.pdf
Posted on Mar 31, 2009
Battery in compaq nc6210 saying not present
How old is the battery and did the problem happen sudenly. If the unit has been left in power down i.e. the lid just shut and you left it for a while i.e days/weeks before trying it again then the battery maybe too low to register so the laptop does not try to charge as it thinks there is no battery.
Jan 15, 2014 | HP Computers & Internet
I have a hp g60, i have a really weird issue. Some times my laptop stops charging suddenly and the small led next to my charging input slot does not show any light. I checked my charger its showing...
Kind of vague. It could be the port on your laptop where the charger plugs into. It could be bad, or could have a bad connection to the motherboard due to use or manufacturing defect. When the charger stops charging then it has to use the battery power. This morning the battery may have had a low charge causing the laptop to shut down. Did you notice the battery's power level before it shut down? If you are wiggling the end of the charger that is plugged into your laptop to get it to start charging again, then that is most likely your problem. Do not wiggle it , for it could fry your motherboard. If that is the case then that port needs to be re-soldered.
Jan 24, 2011 | HP G60-230US Notebook
My battery light notifies my the battery is low so I plug in to the AC power and it still shuts off.
How long between plugging in and shut down? Many times what happens is it has already initiated the shut down sequence before you plug it in.
To prevent this, keep an eye on the power meter (put it in the systray if not already there) and proactively plug in the AC before it warns you. e.g. if it warns you at 10% when you see it reach 15% plug it in.
Mar 24, 2010 | Gateway 3520GZ PC Notebook
I put a new battery in it still doesn't work, charger doesn't work either
Well sounds like the charger doesn't work......A new battery can't work without a charger....
Oct 26, 2009 | HP Pavilion dv6000z Notebook
DELL D520 LAPTOP
Problem cause:
Do diagnose your Laptop try to change your battery or adapter if you have some backup device
Sep 22, 2008 | Dell Computers & Internet
No power on
cheak the all battery points.
Jun 10, 2008 | Compaq Evo N610C Notebook
Startup shutdown
a new battery tried yet, battery tests , with a volt meter
only show if cells are shorted, or low charge state (SOC)
only load tests on battery show weak cells.
the top failure on something like this is the battery.
unless dropped.(and any fail possible)
HP has a real forum. why not ask there.
but battery, is top suspect
https://h30434.www3.hp.com/
Jul 14, 2017 | HP iPAQ H2215 Pocket PC
Nc6320 Laptop power
hello the first thing to make sure of is that the ac adaptor cable is not having any partial contacts ofany kind whereby power gets into the laptop irregularly.this could have adverse effect on the circuitry. it is not enough just checking the output of the ac adapter by a meter.try straighten the cable from the adapter and check the meter for voltage fluctuations. if the above is okay then the problem could be on board leve.
Aug 10, 2007 | HP Compaq nc6320 Notebook
False battery power alarm shut down
Ive had a look at the manufacturer web site but ther doesn't seem to be any driver for your model. You should be able to turn the battery warning alarm off in the management settings
Feb 03, 2007 | Balance CN6555 Notebook
96 people viewed this question
Top HP Audio Players & Recorders Experts
Lawrence Oravetz
richie46
Are you a HP Audio Player and Recorder Expert? Answer questions, earn points and help others
