Question about Pioneer DEH-P690UB CD Player
Screen flashing The screen on my deck is flashing to a bright blue after about every 30 seconds and I do not have a manual and cant seem to figure out how to turn it off. It doesn't bother me during the day but at night it bugs me to have a flashing deck. Can anyone help?
1 Press SOURCE and hold until the unit
turns off.
2 Press MULTI-CONTROL and hold until
Language select appears in the display.
3 Turn MULTI-CONTROL to select one of
the initial settings.
Switching the reverse mode
If you do not perform an operation within
about 30 seconds, screen indications start to
reverse, and then continue reversing every 10
seconds.
1 Use MULTI-CONTROL to select
Reverse mode.
2 Press MULTI-CONTROL to turn the reverse
mode on.
# To turn the reverse mode off, press
MULTI-CONTROL again.
Note
You can also turn on or off reverse mode by pressing
BAND while this unit is turned off.
Posted on May 24, 2009
Bush tv 3 weeks old, tried turn it on but just a black screen,standby light turns blue as if it's on also if I press any buttons on it the blue light flashes like working but just a black screen
Here goes:
#Press and hold the on/ off button...
#Whilst holding unplug the plug from the wall...
#Continue holding for 30 seconds...
#Plug in the plug whilst continuing to hold the on/ off button...
#Continue to hold for a further 30 seconds...
And the screen should come back on!
Jul 23, 2016 | Bush Televison & Video
Projector image switches off when image gets super bright
Hi , what type of cable are you using for the video input source ? HDMI or RCA ? it very much sounds like a faulty cable or lose connection , would try that avenue first before anything else,
Mar 20, 2014 | Office Equipment & Supplies
Sony KP-57WV700
Hi. It seems that the g2 voltage of the picture tube is too high, resulting in a white screen, often with white horizontal lines. The g2 (= second grid) voltage is derived from the flyback high voltage. The voltage divider is mostly integrated in the flyback trafo housing.(including the adjustment knobs). A failure in this divider may lead to this defect. The static you hear may come from sparking in the divider. The flyback trafo is soldered onto the main printed cirrcuit board. Sometimes, one of the pins sits loose in the soldering pads.
Turn on the set and observe for any sparking around the entire flyback circuitry, and, or the flyback trafo itself
The screen turns black after a while, as a too high beamcurrent is detected. The set disables the flyback. Stand-by blinks meaning that there is a fault condition.
Be carefull with the high voltages. The flyback voltage is very high (20-30 Kilovolts !) and may be lethal !!
Jul 02, 2012 | Sony KP-57WV600 57" Rear Projection...
Hi..have a sony kp57hw40 after about 30 seconds on, the screen turns all blue..what would this be..??
most likely the blue gun is shorting out, or the ic on the neck board is defective,
or u can try turninr down the screen control for the blue gun
the controls access via the front panel,pull speaker grill off screws on sides or at bottom of grill
remove plate togain access to block of 6 controls, 3 are focus and 3 are screen brightness
center up/dwn are green
left up/dwn are red
right are blue
Apr 01, 2011 | Sony KP-57HW40 57" Rear Projection...
TV screen Flashes blue and then shuts off.
When it flashes blue, are the flashes bright blue lines going across the screen with the picture in the background, if so, It sounds like the Blue tube or blue driver circuit is breaking down after a short period of time. If this is the case, the uPC that controls the set is detecting a large current drain on and is shutting the set off for protection, An engineers expert eye is required I`m afraid. Ian.
Jul 24, 2009 | Sony KP-65WS500 65" Rear Projection...
Blue screen with alpine DVE-5207
there is a ground wire off of the back of the deck find it using intall manual the screen is blue because this wire isnt hooked up and set properly this is a safety switch so the driver cant operate the vehicle and try to watch a movie at the same time
Jan 26, 2009 | Car Audio & Video
Screen Brightness Plugged in Vs. unplugged
Well sir its very easy , did you read your manual.
Increase your birgtness with the proper way. Everyhting is there.
Your set up is rprobably set to be dimms after 10 or 30 seconds.
I set mine to off . And no dimms.
Read the manual carefully and you will love your unit 660.
----> http://www8.garmin.com/manuals/1262_OwnersManual.pdf
Best regards
Jan 05, 2008 | Garmin Nuvi 660 GPS Receiver
Pioneer DEH-P6900UB problem.
It's called Reverse. Just set it to No.
Oct 14, 2007 | Pioneer DEH-P6900UB CD Player
DEH-P670MP Display goes from regular to extra bright, then back
Your deck has "reverse mode" activated. To turn it off, just turn off the power by holding the source button. The press the preset "5" button. When you turn the deck back on, reverse mode should be disabled. (If this doesn't work, try the same procedure with button "6". One's for reverse mode, the other for demo mode, but I'm not sure I remember which is which).
Jul 01, 2007 | Pioneer Premier DEH-P670MP CD Player
Pioneer DEH-P690UB CD Player Logo
211 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
