Question about Garden
Re linkages i removed the carby but i don't remember how the linkages fit
  • 1 more comment
  • lazarou Nov 17, 2008
    thanks Joe i fixed the problem
  • lazarou Feb 11, 2009
    thank you .but i found the problem myself,it took to long to answer. regards
  • joethefixr May 11, 2010
    what type of engine?
TC'' On 2-cycle Husky rototiller Engine Family: WTPX.049EA. Neighbor took off carb spring and need diagram to see how to re-attach it.
Hi type in Google search. husky rotiller engine carby linkage photo. There r some photo's on carby linkage & springs. Good luck
Apr 05, 2016 | Garden
Hi my 25cc weed trimmer is not starting unless i take off the gas hose from the carbreraator an then it start an the plug keep flodding when the gas line is on ..what can be the problem ?
have the carby removed and properly cleaned out
if there is a needle in the carby ,remove it and blow out with compressed air
fit new carby kit
Nov 30, 2015 | Garden
How do In remove carbie from 13hp briggs and stratton
Correct! work your way down to the carburetor, careful not to tear any seals or hoses. once you get the shroud off, mark the throttle and governor linkage and be careful not to bend them. From there on out it should be 2-4 bolts or screws holding it on to the manifold. replacement is reverse of tear down. Model and serial numbers would help me to help you further, if any is needed! Good Luck to ya!
Dec 15, 2014 | Briggs & Stratton Briggs and Stratton...
If I pour gas into carbarater it will run but if u try to start it the regular way it doesnt
Can be several things . By pouring fuel into the carby it is going into the inlet manifold making a rich mixture . check the gas has not leaked from the carby. over night, Check the choke flap is closed before starting with the engine cold. Check the carby.accelerator gas pump is working. by working the linkage you will see a spray of gas injected into the carby. throat. If not the remove and repair.
Sep 04, 2014 | Cars & Trucks
Twin hs2 su carb linkage diagram
YOU dont need a diagram for twin carbys as put them on the manifold back off all throttle linkage and adjustment screws make sure thay are all down, and turn both screws down till they touch, now back off the jets nuts under the carbys and then undo them 2 turns only[thats the ones the choke move up and down] now HB on out of gear a little choke start engine adjust 2 screws 1 more turn each and choke in
make sure you have very thin oil in pistons, then when running adjust jets 1flat at a time when it runs smooth lock up the linkage and adjust screws till idle at 600 RPM.
Aug 15, 2012 | Austin-Healey SPRITE Cars & Trucks
75 hp 2 stroke outboard motor stays choked after starting the engine. how can i get the choke to release? engine always flooded after a day or two of not using the motor
Check choke linkage OMC engines use a fair bit of plastic in and around the carby.
Flooding, Remove your carby and clean it out , you could replace the needle and seat , but they are not hard to remove so I would just clean it then replace it after if you are still having the same problem.
Aug 07, 2010 | RTO Oar Sockets
Johnson 2 cyl 50 hp gearbox removal help!
Look on the side, of the lower end, (dirveshaft housing) for a small cover, with usually two screws holding it on. Then underneath the cover there is a fitting that connects the linkage. Put a mark with a magic marker on the linkage rod to remember where they line up. Put the motor in neuteral, (not running) and loosen the fitting, it should all seperate after that.
Apr 21, 2010 | Boating
My yamaha xt600e starts to to choke/stall like if iit lacks gasoline every time i pass 5k rpm in 2nd,3rd,4th or 5th gear. What could it be?
You may very likely have an issue with your carbies. The jets may be gumming up with sediment over time or secondary carby needle is worn or sticking. A carby cleaning execise may be a cure or a service at your bike dealer if your not mechanically minded. The carbies are a little more complicated than the normal single carby and have more jets and slides, as well as a delayed secondary carby linkage.
Try the site below for a free download of your bikes manual which will have some troubleshooting tips and some service for the carby's.
Cheers!
http://www.yamahaownershandbook.com.au/index.php?BRSR=20
Feb 05, 2010 | 2002 Yamaha XT 600 E
Windshield motor make noise but the wiper don't move
Remove the wiper blades then remove the cover and you will find that the linkage has come off the motor.Replace the linkage or fit a new one.Hope that was helpfull.
Aug 07, 2009 | 1996 Acura TL Series
Lpg
if the fitting is brass or alumonium, the fitting is probably corroded in, and removal will probably snapit. good luck !
Jun 12, 2008 | 1983 Ford Fairmont
Garden Logo
66 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
