I have a vintage Technics SA-5360 receiver and I can't get any sound from it. I have replaced the fuses for the speaker channels, but still no sound no matter what source I try. Any ideas on how
  • 125 Answers
SOURCE: Noisy channel of receiver
Generally, crackling noises come from anyplace there is a mechancial connection for the sound signal. The volume control, main/remote speaker switch and possibly the headphone jack. That is where the contacts must be cleaned, but it requires dissassembly. Try operating the main/remote speaker switches, and plug/unplug a headphone several times. I am assuming there is still audio behind that crackling. Are you using both main and remote speakers simultaneously?
Posted on Apr 09, 2008
SOURCE: Technics sa-g78 no sound from front speakers
This happens on mine also. My theory is a relay. If you turn the volume up (Waaay up) momentarily, you "burn through" the oxidation on the relay and the sound comes back - for awhile. Some day, I'll get in there and replace it with something more robust.
Posted on Sep 30, 2008
SOURCE: Technics sa 400 Receiver
Checked fuses then sprayed contact cleaner on the fuses and the fuse holders. The speakers began to work correctly.
Posted on May 29, 2009
SOURCE: Max. wattage for speakers w/ Technics Receiver SA-GX100?
I too have a Technics SA-GX100 and it's rated at 2 x 40W @ 8 Ohms. I have the Technics SB-2840 floor model speakers hooked to it, which are rated at 200W Music Input - 8 ohms. It sounds very nice just to be a 40W receiver.
Posted on Jun 12, 2009
Sparky2012
  • 102 Answers
SOURCE: My Technics AV Control Receiver SA AX530 is in overload
An amplifier should never be turn on without speakers, it will overload internally.
make sure speakers work and try again.
Posted on Dec 04, 2009
No FM in vintage technics receiver
Connect a long wire/antenna wire to the respected fm antenna screw on the back of the receiver.
Mar 11, 2014 | Panasonic Vintage Technics Stereo Sa-500...
No sound from left channel on my Technics SA-R 230
May just be bad connections on the speaker relay. Flip the main board over, and check those connections. It is pretty common on these older models.
Jan 18, 2013 | Technics Audio Players & Recorders
Technics sa-dx1050 overload
if any one of the channels was shorted out, even momentarily, that channel's output transistors would likely be blown causing it to stay in protection mode. (or overload as you put it). Time to visit the repair shop.
Jul 23, 2012 | Technics SA-DX1050 Receiver
I have a vintage technics receiver, model numbe 5360. i would like to the watts per chanel.
Full specs. But take them with as grain of salt because they don't specify the bandwidth or distortion, plus they use 4-ohms as the load instead of the 8-ohm standard. Avoid driving any amplifier harder than it is designed to go because distortion rises rapidly and it WILL kill itself or the speakers if overdriven.
http://www.classic-audio.com/technics-sa5360-p-357.html
Nov 10, 2011 | Technics Audio Players & Recorders
I have a technics sa-ax7 receiver and have sudenly lost sound on the right hand speakers.can they still be repaired. What could be the problem. Thanks
1). Look for a blown fuse on back - or inside. I had this similar problem with a Technics SA 5060 (vintage) receiver, and there were 2 separate fuses for left and right channels. One may be blown.
2). Try switching speakers (physically switch the left and right input plugs in their jacks - or wires if no jacks. If the left speaker doesn't work now, there is an issue with the speaker that has no sound. Run an ohm meter on these speakers as well to check them. There should be 8 ohms approximately. If no reading, then your apeaker is probably blown. If you can see a short on ohm meter 0 ohms) then you have a short circuit in your speaker.
Fred
Sep 21, 2009 | Technics SA-AX7
No left channel sound
check wiring. if ok, swap speaker channels if ok, swap rca plugs, if ok. Bad channel on amp.
Jun 29, 2009 | Technics SA-DA10N 5.1 Channels Receiver
check inside to see if you have a blown fuse on the left channel
May 27, 2009 | Technics Audio Players & Recorders
Technics SA-DA10 Receiver-no sound
Most of these problems are rooted in a failed power amp module.
I'm working on an older technics unit but with the same troubles.
Aug 08, 2007 | Technics SA-DA10 Receiver
Aug 06, 2007 | Technics SA-AX540 Receiver
162 people viewed this question
 Grubhead
Grubhead
