Question about Briggs & Stratton Briggs Stratton Vanguard V - Twin Vertical Ohv Engine with Electric Start 23 Hp, 1" X 3 5/32" Shaft, ModelNo. 386777 - 0036 - E1
18hp briggs keeps shorting voltage regulators. alt output is 30vac@3600rpm. engine is 356777 0115-e1 05110841. have no idea what is wrong.
Have installed new regulator. have checked for shorts and bare wires. this is the fourth regulator installed.
3 Suggested Answers
miket756
  • 2702 Answers
SOURCE: Briggs and Stratton Vanguard 23Hp starter issues
take the starter off and give the bendix a realy good clean up and then splash some oil on it,,,they get very dry and sticky at times,,,you can test the starter uasing some jump leads stand on it though, dont hold it in your hands as it will spin out of your grip
hook the black lead to the caseing and tuch the red lead on the starter battery stud,,,it should spin up and strow the bendix out as soon as you take the lead off the bendix should slid back in if it dont oil it till dose also check the starter relay it could be sticking on holding the starter in
Posted on Jun 06, 2010
Testimonial: "Thank you miket756. Brand new starter that 100% bench checked. Cannot understand what problem is, I appreciate your time and efforts. Tim"
  • 4088 Answers
The starter may need shims between the engine and starter to permit the relative gears to release. Compare the two starters, if you still have the old one, for shaft length and bendix construction. Hope this helps!
Testimonial: "drallim, Everything checks out, cannot believe I've received 2 bad solenoids from NAPA. I had bought a new one and exchanged it because it seemed the switch was sticking. Still have not solved problem. Thank you for your time and efforts. Tim"
Having SDMO genset V250 volvo engine with Leroy Somer Alt 60 hz.Having problem that engine Shut Down with the message Min U Alt. Can anybody help me to solve this problem
Min U is minimum voltage output. If it occurs when under load, check load types and for shorts. If it happens during no load, check voltage regulator and exciter, and diodes
Aug 17, 2014 | Electrical Supplies
Briggs and stratton 8000 watts generator, the output of the 120 is only 102. How do I adjust the output?
Voltage is adjusted by increasing rpm of engine. Use meter with Hz setting and try to adjust to 60 cycles and check voltage to be at about 115-120. If engine is turning 3600rpm/60 cycles and voltage is very low, then problem is most likely with brushes/ commutator rings, or voltage regulator. Some voltage regulators have an adjustment screw to bring voltage up/down (adjust to proper rpm/cycles first). Good luck
Sep 09, 2010 | Briggs & Stratton Electrical Supplies
I have an older yardpro riding lawnmower with a 18hp kolher when i turn the deck on it starts to discharge & will kill the battery eventally, if i shut the deck off it will charge, looking for ideas to...
Faulty voltage regulator. Insufficiant output to operate the PTO clutch and charge the battery.
If the battery charges without the PTO clutch 'IN', then this proves all the wiring, so this has to be the answer.
I suppose there is a remote possibility that the holding coil in the clutch is partially shorted, but it's unlikely.
May 08, 2010 | Garden
Not geting a charge back 2 my batterie
Hi and welcome to FixYa,
No charge to the battery could be caused by:
  • faulty / loose / corroded / burned terminals / connectors from stator to regulator (most likely);
  • faulty rectifier / regulator combo (likely);
  • faulty stator (least likely).
To determine which, initially visually inspect the wiring and its connectors from the stator to the rectifier/regulator combo. Thereafter, a DVM/VOM is required to measure the AC voltage output of the stator (~30VAC), the DC voltage output of the regulator (~14.5VDC @ 4000RPM) and engine off battery voltage of ~12.5VDC. It maybe to your advantage to have the battery load tested as well.
Good luck and thank you for asking FixYa.
Nov 08, 2009 | 1996 Yamaha YZF 600 R thunder cat
20 hP briggs engine keeps burning up the altenator under flywheel. Checked amperage and doesn't seem to be high.After the engine runs a few minutes it melts the alternator and it grounds out. When the...
Yes it sounds like the voltage regulator is shorted.The 30 ac volts is correct for the alternator output.The yellow leads on the regulator shouldn't read ohms between each other or to the aluminum case.The red lead shouldn't read ohms to the aluminum case.If you do a diode test between either of the yellow wires to the red wire it should read one way only. If it reads both ways in a diode test it is bad.Voltage regulators are cheap on ebay
Aug 01, 2009 | Garden
Alternator keeps blowing out
The only thing that controls the alt. is the alt itself. It has an internal regulator that controls the output voltage. I am not sure when you say the alt "shorts out" Need more info. Moe
Jun 11, 2009 | 1993 Saturn SL
Low voltage out of replaced alternator
Possible to have bought a bad alternator.... Try another one..Take advantage of the warranty the bad one came with....But have them check the voltage output on the new one so you KNOW for sure....Also consider issues with your voltage regulator and the possibility of needing a replacement. They are relatively inexpensive so that is the good news....More serious issue that could be addressed is a short somewhere in the harness. I would recommend a full electrical diagnostic to make sure there is not a bad ground....If you'd rather not spend a lot, just check all the wires you can visually.....But keep in mind that the voltage regulator is key and you do not want to spike the computer with inconsistent power levels and surges.
May 13, 2009 | 1999 Mercury Sable
93 Ford F250 5.8 L No Charge
not cpu.
Do not field out the field wire.
Is the alternator ight coming on?
If you rev engine, does charging system start working?
There is a resister wire that provides voltage to the field circuit. If the resister is bad, you will only get voltage to the field through the dash alt. light bulb when you push enough voltage through it.
I don''t have 1993, but here is 96:
Generator with Integral Rear Mount Regulator, Internal Fan Type With the key in the RUN position, voltage is applied through the charge indicator lamp I circuit to the voltage regulator. This turns the voltage regulator on, allowing current to flow from the battery sense A circuit to the generator field coil. When the engine (6007) is started, the generator (GEN) (10346) begins to generate alternating (AC) current which is converted to direct (DC) current by the rectifier internal to the generator. This current is then supplied to the vehicle's electrical system through the battery positive voltage (B+) terminal located on the rear of the generator. Once the generator begins generating current, a voltage signal is taken from the stator and fed back to the voltage regulator S circuit, turning off the charge indicator/lamp. With the system functioning normally, the generator output current is determined by the voltage at the A circuit. This voltage is compared to a set voltage internal to the voltage regulator, and the voltage regulator controls the generator field current to maintain proper generator output. The set voltage will vary with temperature and is typically higher in the winter than in the summer, allowing for better battery recharge. With the system functioning normally, the generator output current is determined by the voltage of the A circuit (battery sense voltage). The A circuit voltage is compared to a set voltage internal to the voltage regulator, which controls the generator field current to maintain proper output. The set voltage will vary with temperature and is typically higher in the winter than in the summer, allowing for better battery recharge in the winter and reducing the chance of overcharging the battery in the summer. A fuse link is included in the charging system wiring on all models. The fuse link is used to prevent damage to the wiring harness and generator if the wiring harness should become grounded, or if a booster battery with the wrong polarity is connected to the charging system.
  • System Does Not Charge
  • Loose or worn drive belt.
  • Open/voltage drop in Circuit 38 (BK/O).
  • Open/voltage drop in Circuit 36 (Y/W).
  • Open/high resistance in Circuit 904 (LG/R).
  • Damaged regulator.
  • Damaged generator battery
Apr 13, 2009 | 1995 Pontiac Sunfire
Briggs & Stratton Briggs Stratton Vanguard V - Twin Vertical Ohv Engine with Electric Start 23 Hp, 1" X 3 5/32" Shaft, ModelNo. 386777 - 0036 - E1 Logo
258 people viewed this question
Top Briggs & Stratton Tools & Hardware - Others Experts
Randy Schumann
Randy Schumann
Bill Boyd
nirodacyar
Are you a Briggs & Stratton Tool and Hardware - Other Expert? Answer questions, earn points and help others
