Question about Mackie Music
What causes Mackie 1640i's to crackle while tracking?
Have tried several attempts at live recording 16 track and 32 track and without fail and nasty crackle come in that makes us have to stop. It's an older Macbook so I have my concerns. But it recently worked for 70 minutes without fail in a dress rehearsal, and then crapped out 10 minutes into the actual recording. Fortunately we're running back ups on HD24's. But I shouldn't have to. Thoughts?
5 Suggested Answers
  • 1137 Answers
SOURCE: Problems setting midi channels using KN3000 and Cubase
If you are sequencing midi tracks you can imbed the patch change in the track and the midi channel assignment and when the sequence plays the info will be sent to the keyboard. Do you have it set to receive Omni?
Posted on Apr 25, 2009
  • 4 Answers
SOURCE: Repair a Mackie SRM 450 Speaker
You probably need to replace the diaphragm. The diaphragm is located behind the back cap. Simply remove the back cap, remove the diaphragm, clean the voice coil gap with a piece of masking tape, install a new replacement diaphragm, reinstall the back cap. That it!
You can see videos on how to replace diaphragm at this link.
http://www.soundspeakerrepair.com/speaker-parts-c/INST/Installation+Instructions
You can buy a new Mackie SRM450 diaphragm at this link.
http://www.soundspeakerrepair.com/speaker-parts-cp/SRM450-DIA/DIA-Mackie/Mackie/
Posted on Jul 21, 2009
  • 5603 Answers
SOURCE: Hi. I have a Mackie
Check the settings in your computer in the control panel "sounds and devices" under the "Voice" and "Audio" tabs. Check that all are set to the Mackie instead of the computers default input.
Posted on Jun 10, 2011
  • 5603 Answers
SOURCE: I hooked up my Mackie
It is likely that your compter is running out of time to service the audio interface. You need to turn off wireless connections, turn off all Anti-virus and antispam and anti popup software that might be running. You are probably getting underun errors.
When data is missed due to insufficient processor power/timing, this causes the sound to break up badly.
Posted on Sep 27, 2011
SET UP PROBLEM
SOFTWARE/FIRMWARE required to work.
Drivers
PC: Windows XP SP3 to Windows 8
Mac: OS X 10.5 to OS X 10.10
Have a look here;
Onyx Series Production Mixers Mackie
Jul 15, 2017 | Mackie Onyx 1640i Mixer
CRACKLING SOUND ALSO CUTTING OUT AND IN
This sounds like another case of bad connections or soldering in the amp. If it's not too old take it back to your dealer, they should fix it. These are designed (allegedly) to be used and moved about and should not fail. If it is too old then open it up and with care - and with yourself isolated from earth and wearing insulating gloves wobble connections and components until you find the cause. We have had a couple of this sort of fault with newer mackie stuff and it's not been too hard to track down and fix if you're handy with a soldering iron.
If you have any doubts about being competent to do this sort of thing take it to someone who knows what they are doing, it should be a fairly quick fix.
Nov 07, 2013 | Mackie TH-15A Active DJ Powered THUMP...
Hi. I have a Mackie onyx 1640i. 2 days ago it was working, but now the computer sees only 2 output channels. There was no shock, etc... Thx
Jun 08, 2011 | Mackie Onyx 1640i Mixer
I am trying to record in multi track mode-want to know how to record for example vocals on track one then without erasing the vocals add for example harmony or guitar so i get two things on one track. At...
How multitrack recording works is assigning each recording to a different track. A way around this is to record the vocals to track one, then your harmony to track two. Save that as a single recording, or mixdown, then open that saved mixdown to track one. You may need to be connected to a computer to do this.
I use the same technique when using Cool Edit Pro (outdated, yes, but I've been using it for 4 years, and I know most of the ins and outs), especially on the guitar tracks, where for studio sound, you've gotta use 4 total tracks. Putting two tracks together frees up your processor, and uses less in the way of effects, as well.
Hope that helps!
Feb 07, 2011 | Samson Technology Zoom H4n Handy Recorder
Trying to wright some tracks in song mode to cd so i could listen in the car but it will not let me. Any suggestions?
I have a similar Yamaha that makes me re-record the 16 tracks of the song onto the stereo track (left and right) then save. See if under the record setting if it has an option to "record to stereo track" or something similar. Hope that helps.
Dec 16, 2010 | Roland Mv8800 Production Studio
I can't seem to figure out how to record one track over another without a delay problem? I am using the behringer 1202 mixer into my computer. No problem recording but can't do multiple tracks. I'm new...
This is a common problem with digital recording. Simply put, it takes some time to convert analog (audio) to digital and then more time to convert it back. So, your playback track goes through conversion and introduces some delay. You don't hear this because you have no zero reference. Your recorded sound goes through the A/D converter and also incurs some delay. When you play them back together, you hear the difference in time from one track to another. Most pro recording programs have some method to minimize or cancel the delay like slipping the tracks so they all start together. Pro Tools just introduced a version that automatically does this. They have always had what it called "low latency" monitoring which attempts to keep the "shortest" digital/analog path so overdubs are close enough that we don't hear any issues. So, since you talk about the mixer but not the recording program, I can't tell you specifics but I'd look into the recording program for time alignment settings and options. If you have a manual for the recording program, try to look up latency.
Dec 08, 2010 | Behringer Rx 1202fx 12 Channel Line and...
I hooked up my Mackie MR5 Monitors to my MacBook Pro through an audio interface, I use it to record my band in the studio I use out of my basement. Except everytime I try to use the monitors they give me...
try hooking headphones to the output and see if the crackling is still there.
then, try it with the speakers, at a lower computer voume level and higher speaker volume level. perhaps the headphone output is too loud and distorting in the speaker inputs.
Nov 28, 2010 | Mackie MR5 MR5 Reference Monitor
One of my channels creates a popping noise on my mackie 16 track board. Can I do something or does it need to go in for repairs? BKKirk
Check the possibility of marginal connectors.
You MIGHT try putting a small bit of CRC226 into the fader for that channel if it might be the fader. CRC226 is available in the electrical dept of Home Depot in a small spray can with a tube spout. DO NOT use De-Oxit in the faders. Put the tube into the slot and give a SMALL shot and work the slider. This MIGHT fix your problem. Other than that it is ready to go to the shop.
Aug 08, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
Mackie CR1604 has a consistent click at hi gain
Without hearing the noise or seeing it on a scope, I can't say for sure, but this type of noise can come from a number of sources. If there is a high signal level on one bus, you could be getting some cross-talk from that channel onto the channel with the higher gain setting. Try to track this down a bit by experimentation. For example, do you hear this with NO connections at all, but with the gain turned up on one channel?
Please try a few things to narrow this down a bit and I'll try to provide you with some options.
Thanks,
Dan
Jul 20, 2009 | Mackie 1604 Vlz3 16 Channel Mixer
Music Logo
Top Mackie Music Experts
Matthew Spark
Matthew Spark
Vito Vacirca Jr.
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Are you a Mackie Music Expert? Answer questions, earn points and help others
