Question about Canon Photography
How do I rewind the film in a canon sure shot supreme?
  • 28 Answers
I have a cannon sure shot and it is digital and has no film. Open the battery compartment and pull out the sim card.
Posted on Feb 17, 2012
daverh
  • 117 Answers
SOURCE: Canon Sure Shot 105 ZOOM ~TOTALLY LOST ~need any instructions I can get.
The flashing H means hat the camera has detected a hardware fault on starting up. It can also mean that the film has mis-loaded. Try removing the film & then the battery to reset it. Put the battery back & switch on. If it's still doing it then I'm afraid it's got the 'flashing "H" of Doom'. Although this is repairable, it's usually not economically viable.
Posted on Jan 14, 2008
SOURCE: Film advance inoperative
check the polarities of the battery.
Posted on Apr 02, 2008
SOURCE: camera blinks H replaced battery and new film it'll take one pik and then shut down
poor product when it happens to so many cameras. cp
Posted on Jul 12, 2008
  • 185 Answers
SOURCE: Canon AE-1 won't rewind film without tearing it up.
misstigeress,
is the film being ripped along the sprocket holes? if so, the rewind button is not unlocking the drive sprocket. with film removed open the film door and push the rewind button in, the drive sprocket should turn freely. now charge the shutter with the advance lever. the rewind button should pop out and the drive sprocket should not turn freely.
if the sprocket did not turn freely with button pushed in, the camera needs repaired. there are no new parts for this model canon so any parts needed will be good used.
Posted on Dec 10, 2008
SOURCE: Canon Elan rewinds prematurely?? Help!
Im having the same problem-- have you had any luck with this? If so any advice would be greatly appreciated!
Posted on Mar 03, 2010
Can not load film as the flashing 0 keeps flickering.
Hello Linda,
Sorry I am a bit late on your question. Here is the Canon website:
https://support.usa.canon.com/kb/index?page=content&id=ART120513
Notice in their diagram the film must be pulled all the way to the right. If the sensor does not recognize the film in place it will flash 0. If that does not fix it remove the battery press the shutter release a few times, reinsert the battery then the film. If it continues to flash then there is something wrong with the sensor.
Jul 27, 2015 | Canon Vintage 1986 Sure Shot Supreme...
Film rewinds when loaded
Align film leader at mark, then close the camera back for prewind loading. Film rewinds as each shot is exposed. Built-in motor for automatic winding/rewinding. Film advance: Automatic. Single-frame and continuous (1 fps). Automatically rewinds film leader into cartridge when designated number of frames have been exposed (midroll rewind available).
sorce: http://www.canon.com/camera-museum/camera/film/data/1996-2000/1999_eos3000.html?p=2
Canon Camera Museum Camera Hall Film Cameras
good luck
Dec 20, 2014 | Canon EOS-AE-1 35mm SLR Camera
Howw do you rewind the film on a cannon sure shot megazoom 105
Their is a small button on the bottom you push in then rewwind the film to take it out.
Jan 25, 2013 | Canon Cannon "sure Shot" 35mm Flash Camera...
Camera does not rewind after end of film it spins, but does not engage the film. Joe M.
it is likely that this model of camera spins the entire roll onto the take-up spool, and then slowly rewinds one frame at a time until the last picture is taken. Then it has already almost rewound,
This shows up when you load the film. The cameras digital counter counts up to the number of pictures available, and counts downward each picture taken.
Sep 08, 2010 | Canon Sure Shot 80U 35mm Point and Shoot...
My Canon AE-1 Program will not rewind. I shot the whole roll, rewound a little, and then accidentally opened the back cover. The counter reset to S, and the rewind crank just unscrews when I try to...
I think you have already ruined the film except the frames that are rewind back to the film cartridge.
You can take the film out from the camera, push in the rewind button at the bottom, pull out the film from the film take up reel.
On the film cartridge, turn on the long tube in the middle clockwise to wind all the film back into the cartridge.
If you had the back opened briefly, do manual film rewinding in the dark room.
May 21, 2010 | Canon EOS-AE-1 35mm SLR Camera
The films rewinds as soon as I close the lid. It
One reason may be that the film is not pushed far enough to the receiving spool and the camera thinks it's empty thus rewinding the film.
If this is not the case it needs to be repaired.
Nov 19, 2009 | Canon EOS Rebel G 35mm SLR Camera
Why is the film automatically rewinding around 15 shots instead of the end of the 24 shot roll? The batteries are fresh.
the roll sensor is not reading the silver code on the film roll.
Open the camera when you have no film in it.
Clean the film roll slot where the "fingers" are.
These fingers touch the case of the film roll to determine the film type, which includes the number of exposures. You nmay have to "adjust" the fingers so that they make good contact with the film roll case.
Look at different rolls of film, notice the silver blocks are different. If the roll has a "dent" on it, it can't be sensed correctly.
Hope this helps!
Sep 15, 2009 | Canon Sure Shot Classic 120 35mm Point and...
Old sure shot - fixed lens, dropped, won't work, how to get mid roll film out?
wait until nite, then go to a dark room, ( bath room or closet ) no lights. remove film then rewind the film canister manually. turn plastic sprocket to the left untile all film is in the canister.
make sure no light is comming from around door.
Jul 31, 2009 | Canon Photography
Film wound on wrong side of camera
It sounds like you have a jam.  When you have finished taking shots and have used all the film, you must press the film-rewind button on the underside of the camera; this does not rewind the film, but allows you to commence the next step.  Once you have done this, flip up the rewind-crank on the top left hand side of the camera. It is situated on top of the film speed dial. turn this clockwise until all the film is back in its cartridge.  You should now be able to open the back of the camera.
I hope you have fun with your t50!
Dec 11, 2008 | Canon EOS-AE-1 35mm SLR Camera
Instructions
There are two conditions under which a blinking "H" will appear in the
LCD panel: (1) when the film has been loaded incorrectly or (2) when the
camera's self-test process detects an internal malfunction. If a
blinking "H" indication appears, perform the following operations in
attempt to resolve the situation:
1. Rewind and remove the film using the rewind button, then remove the
battery to clear the memory.
2. Clean the contacts at the base of the battery compartment with a
clean pencil eraser to ensure proper contact between the camera and
battery.
3. Replace the battery, power the camera back up1.gif and operate it as if
it had film loaded, pressing the shutter release.
Jan 11, 2008 | Canon Sure Shot 105 Zoom Date 35mm Point...
Photography Logo
146 people viewed this question
Top Canon Photography Experts
old marine
old marine
pontelemon
pontelemon
David Payne
David Payne
Are you a Canon Photography Expert? Answer questions, earn points and help others
