Back to:
Tags:
E-Machines PC Desktop
T2958 continuous startup cycle
posted by harv on Aug 20, 2006
Recently, when trying to start the machine, it developed this problem: During booting it would flash this statement on the screen: autocheck missing. The machine would then restart and continuously repeat this cycle. Tech support suggested I place the harddrive into another machine and download files if I want to save them before using the restore disk. My son swapped it into another emachines but, of course, since the software on the 2958 harddrive is the problem, it remained. While replacing the harddrive back into the 2958, the power problem developed (see my other posting). Any thoughts?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 23, 2006
FixYa! (100)
habib_101
Rank:Wiz Wiz
Rating: 81%, 424 votes
It sounds like there may be an issue with the memory chips. If available, take a memory stick that matches the type of memory you need for your computer. Take out all memory sticks on the motherboard and try the new memory stick in the first memory slot and see if you get the error. If so, then try it in the second memory slot.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on t2958 continuous startup cycle:
I don't want to Accept this solution
Can you Help with these PC Desktops problems?
PC Desktops
.failed to find an appropriate PIXELFORMAT ...restoring...
PC Desktops
I am editing video with HD Writer 2.5E and an error has...
PC Desktops
Hi!  probably a really noob question, but I'm going...
PC Desktops
How to replace Amilo L7310 screen
PC Desktops
I have lost Microsoft Office - can I down load the...
Loading problems.
Repair Service
Find PC Desktop Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
