Question about Vodafone Mobile Connect (055270) Wireless Adapter
My mobile connect tells me that "USIM/SIM Card does not exist or unavailable"
I think ive gone to some bad websites. Now i cant connect to my vodafone mobile connect modem. it says that usim/sim card does not exist or unavailable. plz reply me back as soon as possible.
if wanna contact me,
hasan091294@yahoo.com
3 Suggested Answers
  • 31 Answers
SOURCE: want to run - south-african vodacom SIM on Indian vodafone network
you need to contact your nearest vodashop or sp in South Africa to activate international roaming
Posted on May 22, 2009
SOURCE: my vodafone sim is blocked.to unlock my sim card.
MY SIM CARD IS BLOCKED AND IT REQUIRES A PUK CODE SO PLS SEND IT
Posted on Apr 08, 2010
Unlocking the usim and then phone
Better get LG customer service
Oct 02, 2017 | LG KF750 Cellular Phone
What does inactive Usim mean
a usim is like a mini computer sim, it is able to run things like video call and has a large memory capacity for example it can hold alot more phone contacts than the average sim, you could say a usim is like when you upgrade the memory on your pc. If it is inactive , if it was working before you will need to contact your network provider, explain it has gone inaactive and they should be able to sort it over the phone for you. I hope this helps mate
Feb 26, 2011 | LG KP500 Cookie black on T-Mobile U-Fix...
I HAVE LG GW520 ON NETWORK 3 PAY AS U GO PUT MY SIM CARD IN AND IT SAYS INACTIVE USIM. I CALLED AND NETWORK THEY CANT FOUND FAULT, IVE BEEN BACK TO SHOP WHERE I GOT IT AND THEY JUST DIRECT ME BACK TO 3...
Hi,If you are trying to use a SIM card in your phone and getting a message like "Enter Subsidy Code", "Incorrect SIM Card", "SIM not provisioned" or similar messages, then you need an unlock code for your mobile phone. You can get LG GW520 Unlock Code from the network provider, they will verify the account holder information. They will provide you an accurate code with easy to follow instructions on how to unlock your phone. You can check LG Unlock Code site, they can open up all networks for you where you want to use your phone. Once your phone is unlock, it will work with any network worldwide without sticking to one network.
Hope this is helpful.
Thanks.
Feb 04, 2011 | LG GW520 Cell Phone
It wont let me on my phone it has came up Invalid USIM card
This is because you did not insert the correct SIM card. If you were provided with a SIM card when you bought the mobile, you can use only that SIM in the mobile. If you want to use other networks you need to unlock with the current SIM card. Unlocking can be done at www.mobile-unlocker.com within minutes.
Oct 03, 2010 | LG KU990 Viewty
It do tell me insert correct USIM whenever l insert my sim card, Pls l want master unlocking. thanks.
you need to unlock your mobile to the current sim. These can be done using codes. You can get the unlocking codes at www.theunlockspot.com within minutes.
Aug 03, 2010 | Sony Ericsson K530i Cellular Phone
Usim locked?
Enter this site www.unlock-lg-mobile.blogspot.com and unlock your phone in 5 minutes.
Aug 24, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
Ive put my sim card in the phone and it is saying insert usim. how can i sort this out?
This is the problem with either SIM card or battery. If you changed your battery then its sure that the problem is in battery. All you need to do is keep something to tighten the battery in its position. Keep a 2-3mm thick paper behind the battery(opposite to battery's polarity contact to your mobile.) Hope this will solve your problem. If you got solved please rate this!!
Aug 17, 2009 | LG KF700 Triband 3G HSDPA 3MP A2DP Phone...
I need unlocking lg u890
i had a lg u890 mobile phone that i got unlocked but it had the same proble where i swithched on my phone it used to ask for the usim code..my old phone was locked to the 3 nt/wrk i got it unlocked so i could use my 3 nt/wrk sim card or any network simcard but i used vodafone 3g sim card.the code i used with my vodafone 3g network simcard in phone when switched phone on & it asked for usim sim code i inserted code i got & it shut the phone down then on again then it wld work with vodafone no bother at all it even came up with vodafone uk etc.but i had to reconfigure the sms/text telephone number aswell as reconfigure the mms settings & numbers etc aswell as reconfigure wap settings from 3g network to vodaphones.but after i got it all unlocked & settings changed etc & inserted a different 3g network simcard ie vodaphone/orange/o2/3g sim/t-mobile/tesco sim/virgin sims & switched phone on it asked for usim code i tryed the code i have & inserted the same code i have it/they switched phone off & then back on & all network usim card worked with no problems at all.the code i have is.>>> 142358#*# thats 142358# * # all 1 item/action.once you insert that 142358#*# thats it your phone will shut down then restart up & go onto the network usim card you want to use or inserted before using code.but 1 thing tho please remember if u switch off your phone or your phone switches off as batterys run out no power u will need to insert the code again.& another thing code wont work if your phone switches off or you switch it off & plug your mobile battery charger into phone to charge your battery up on the phone & you switch you phone back on when you are charging your phone as the phone will switch on & say insert usim code if you enter the code the phone will switch off & back on again but it will still request usim code.so you will have to wait unto there is plenty of charge in the battery to take phone off charge & swithch your phone on get the usim code message insert code above phone will switch off & straight back on again & then it will go onto your prefured usim card then you can plug your charger into phone again to charge phone up.you can use your phone on charger when u have entered usim code & it switched off & on again & registered with the prefered network.i hope this is of use to you as it is to me.if you try this code & either if it works or not please can you let me knows ty.email watsonwhizzy2001@yahoo.com
Oct 07, 2008 | LG enV VX9900 Cellular Phone
Help!
UPGRADETHE SOFTWARE OR RESET THE PHONE.combine.yavatmal@lgmobiles.com
there, i was wondering whether you can help me. I have recently changed my sim card in my pink lg chocolate phone which was any network, i have tried to change the sim card so i could have a new mobile number but i'm having trouble using the new sim. When i try to ring it tells me its currently unavailable and it wont let me text either. I can remember my ex partner said that he had locked the last sim card to my phone and i couldnt change my number, so i was wondering whether you can tell me how to unlock my phone or the sim so i can use my phone again with my new sim card???
please help! many thanks, stacie x
Jun 19, 2008 | LG KG800 Cellular Phone
Vodafone Mobile Connect (055270) Wireless Adapter Logo
670 people viewed this question
Top Vodafone Computers & Internet Experts
David Payne
David Payne
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Vodafone Computer and Internet Expert? Answer questions, earn points and help others
