Question about Canon PIXMA MX700 All-In-One InkJet Printer
Print head is stuck on the right side of the MX700 Canon printer. All attempts to get rid of the 6A80 error message by holding down buttons has failed. It always puts me into fax mode no matter how
Printer head is stuck to the right and lights are flashing with 6A80 error message. I have already attempted several times to hold the buttons down to get rid of the error message. Doesn't work - only puts you into fax mode. Help!
SOURCE: Canon Pixma MX700
I had the same problem. Solution? I will sound stupid, but it worked for me. Check every phone cable. Unplug and replug it. I solved my problem by making my connections simpler. I think, one of my splitter was faulty.
I still not understand why. I tried to fax without any phones plug-on and it was not working neither.
I'm with "videotron.ca" for my phone line and I unplugged the line from the modem too, then replug it. Maybe it was just that!
A lot of people seem to have this problem. I called Canon twice and they made me change some setting in my printer but their solutions was not working. I put all the setting back to what they was and it still working now.
Posted on Nov 20, 2008
debroy
  • 174 Answers
SOURCE: Cannon Mx700 error code 6a80.
It is because of Purge unit can be damaged or stuck. Probably you have to pulled apart the printer and check the purge unit.
Posted on Nov 27, 2008
  • 32 Answers
SOURCE: error 6A80
Error 6A80 indicates that "an error occurred in the APP motor
during purging operation". Either the sheet feed unit, purge unit, or logic board could be at fault.
I'd recommend bringing the unit into your local canon authorized service facility for complete diagnostic and repair.
Posted on May 28, 2009
micromaster
  • 3614 Answers
SOURCE: MX700 ERROR 6A80
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Error 6A80 – means “AP position error”- indicates that "an error occurred in the APP motor during purging operation". Either the sheet feed unit, purge unit, or logic board could be at fault.
Hope this helps
Posted on Aug 08, 2009
  • 8 Answers
SOURCE: Error Code 6A80 on the Canon MX700
Supply Guy,
Here is the solution.
I am going to describe 4 buttons on your printer. Then, I will tell you what to do with these buttons to resolve this error.
1. Look for the Black & White selection button (large white button w/ black diamond on it).
2. Look for small pink button (bottom left corner of your printer control panel).
3. Look for the OK button (big button in middle).
4. Look for the On/Off button (top left).
OK - here we go. With the printer turned off, do this:
1. Using four fingers, one on each of the four buttons, press them all and hold them down for 10 seconds.
2. Release the On/Off button - but keep holding the other 3.
3. After a few more seconds the printer will turn on. When it does this, you can release the other three buttons.
So, to summarize, you press all 4 buttons for 10 seconds, release the power button and wait for the printer to turn on. After it is on, let go the other 3.
Your error message should go away. If you don't hold the buttons all down simultaneously, the printer could go into Fax mode; just turn it off and try again.
Posted on Dec 29, 2009
My Canon MP520 has a 6A80 error and now the printer head is also stuck on the far right side.
6A80 error is an APP position error caused by the APP motor during the purging operation as the printer starts up. Canon states that one of three components is likely to have failed, the sheet feed unit, purge unit or logic board. All of these will be almost impossible to get as a spare part. The only thing worth trying is an EEPROM reset that can be done using the service manual. Get a copy here: http://www.tradebit.com/filedetail.php/4981053-canon-pixma-mp520-printer-service-manual
Feb 03, 2011 | Canon PIXMA MX700 All-In-One InkJet...
I have a Canon MP550 and after pressing ON button in few seconfs appeares message: ERROR CODE 6A80
[6A80] & Light Blinking 12 times = APP Position Error. An error occurred in the APP motor. Maybe foreign material or paper debris around the PURGE UNIT (at the printer most right hand side) or Auto Sheet Feed area.
May 24, 2010 | Canon PIXMA MX700 All-In-One InkJet...
I received an error code 6A80
Solution:
  • Switch the printer OFF
  • Press buttons 1 + 2 + 3 and 4 (simultaneously using four fingers)
  • Keep pressing this four buttons for 10 seconds
  • Release the On/Off button (number 4) (Keeping pressing the others)
  • After a few seconds (when the printer go ON), release buttons 1, 2, 3
Jan 31, 2010 | Canon PIXMA MX700 All-In-One InkJet...
Supply Guy,
Dec 24, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Error message 6a80 mx700 printer canon what is this?
Hello
Ok, the error code you are getting refers to a paper jam, which the paper is usually torn from the big piece and stuck, you need to have a good lok to find it.
Most probably the paper was ripped inside, and one piece is stuck somewhere on a sensor. Usualy is the purge unit that clean up the print head, and it's located inside on the right side (printhead parking place).
Take a torch, lift up the scanner unit, with the unit ON, wait for the print head to come in the middle, move it to left to make more room, and check the right side, inside the unit.
Kind regards
Andrea
Dec 13, 2009 | Canon PIXMA MX700 All-In-One InkJet...
What does 6A60 error message indicate and how do I resolve on my Canon MX700 all in one machine.
6A60 error is an APP (Application Printer) position error. It means that an error has occurred when the motor was running during the purging operation on start up.Check the sheet feeder and purge unit.Sometimes pieces of paper stuck in purge unit.
Thank you!
Nov 02, 2009 | Canon PIXMA MX700 All-In-One InkJet...
How do I re-set error 6A80? on my Canon PIXMA MX700 lcd display?
6A80 is APP position error.First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output)
is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.Check the sheet feeder.If this not help your printer need service.
Nov 01, 2009 | Canon PIXMA MX700 All-In-One InkJet...
My Canon Pixma Printer MX700 is near new and the screen is showing Error Code 6A80...and the alarm light is flashing.. Does anyone know what the problem is?
According to Canon there is a way to reset the printer.
Just go to this link and this should help.
http://fix-your-printer.blogspot.com/2009/06/error-code-6a80-on-canon-printers.html
If you need further assistace, please respond to this post and I will help you.
Thanks for using FixYa
asnowman
Error 6A80
May 22, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Error 6a80
Error 6A80
I had this error and a Canon engineer showed me how to deal with this.
Basically there is an "App Sensor" which is reporting the issue in my case the problem was with the "Purge unit".
(a) Left up the cover to reveal the ink cartridges
(b) Move the ink / print head to the left hand side
(c) Look to the right under the flap where the ink would sit when printer is powered off
(d) underneath there is something in white that is flat - this is called a wiper.
(e) push this wiper with your fingers - pushing in the direction toward the front of the printer - you may need to do this a few times.
(f) power off and then power on (using button on the front and NOT by pulling the power out of the back)
Hopefully error should go after you attempt this a few times!
Feb 20, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Canon PIXMA MX700 All-In-One InkJet Printer Logo
74 people viewed this question
old marine
old marine
