Main module unrepairable
Reairman told me the main module was unreapirable after i brought it in to have the on switch repaired
  • 6,771 Answers
If the switch is a two point contact, then the points can be solded together and a line switch put on the cord to get more mileage out of the unit.
Posted on Mar 05, 2012
My samsung fronload dryer will not spin. There is no error code. Someone came out and told me that I need a belt. The belt was replaced but the tech now says he
see this causes and fix it. God bless you
Belt
The belt may have come off or broke. If you hear the motor running but nothings moving the problem is likely the belt. This is easy to check and replace. .
Door Switch
This can cause the washer to not agitate or go into the spin cycle. You will need to remove the door switch to check it. You will perform an ohm reading on the bottom terminals. The reading varies from manufacturers most Frigidaires is around 1500 ohms others like the whirlpool duet is checked at the main control board with the door closed should be around zero ohms. You will need to refer to the tech sheet or service manual for the proper reading.
Main Control Module / CCU
The main control unit is the circuit board located behind the console. If the door switch tests good the main control is usually the problem. Check all connections for a goood tight fit. You will need to refer to the tech sheet or service manual to check this further. The main control is easy to replace
Motor Control Module
The motor Control Module is located inside the cabinet down near the motor. This recieves the signals from the main control module then relays this information to the motor. Check all connections sometimes a communcation problem is just a loose connection. The Motor Control Module is esasy to replace .. To check this further you will need to refer to your tech sheet or service manual.
Oct 17, 2012 | Dryers
Where is headlight module located on 1997 buick century
I know of no module called the headlight module. Do the basic tests of the main head light switch for proper power and grounds at the connector.
Aug 07, 2012 | 1997 Buick Century
Where can i get a plexiglass screen?
I have a P46921 46 in rear projection television. I brought it in and they told me it was the processor board (main control board with programming) that wasn't letting the TV turn on and was quite an expensive repair. I now have the parts back and was wondering if someone could use them. I know that some people were looking for the actual screen found behind the plexiglass or what looks like plexiglass. I have all the parts and was told that it worked beautifully until it decided it wouldn't turn on again. Anyone interested, please drop me an email at jforest7@gmail.com.
Thanks.
Oct 11, 2010 | RCA P46921 46" Rear Projection Television
May 13, 2010. Had the tranny rebuilt ($2,200) on my 99 S80 T6 Nov of '09 (received a 12 month 12,000 mile warranty as well). Since then, nothing but trouble. Within 2 days after the tranny was rebuilt, the...
wow!!!!, this would drive me nuts,i would take it back to the dealer and tell them that i was told the problem was the module and they even made me buy theres, you paid them,they didnt diagnose the problem correctly,theres a problem with the abs,wiring or sensor or something, the point is you are having the exact same problem you paid for!! they need to repair this car even if they have to remove the module they put in that didnt repair it! talk to the owner this should not cost you anymore $,smiple they charged you and installed a part that did not fix the car,simple! if all fails file complaint with dmv and also advise them you will do so. good luck, let me know what happens, this is crazy the dealer cant fix there own make of car.
May 13, 2010 | 1999 Volvo S80
When TV off and switch on the volume button goes to 250
they are right, it should have a reset option. You might want to check that the volume button in the set is not stuck in anyway. shy of that, turn the speakers off in the audio options in the set and use external speakers.
May 04, 2010 | LG 42LG50 42 in. LCD HDTV
My 42 inch plasma tv model 12PF/S20010 is switching itself off just seconds when put on. I was told by a technician that it needs a new power supply unit which unfortunately has been discontinued by Philip...
Try this website: tristatemodule.com, they list partnumbers for the modules they have available and for sale, if you can not find what you need, contact them with the complete make, model number and the part number for the power supply, they might rebuild it for you. There are other outfits outhere that do the rebuilding, one of them should be able to help you.
Jan 15, 2010 | Televison & Video
Both doors on right hand side won't open anymore (manually or with remote control) How can I open them? Fuse is OK
You have 4 doors with 4 electronic modules. Front doors have "master" modules and rear doors have "slave" modules. Master modules are called DDM and PDM - Driver Door Module and Passenger Door Module. These modules communicate directly to the main computer via CAN bus.
But module in the rear door communicates only with the module in the front toor on the same side of the car via LIN bus.
So if the CAN communication channel is broken (wires may get broken where the doors are attached) then on that side of the car doors will not lock/unlock anymore, interior lights will not turn on, windows can't be opened and closed anymore from the remote control on that side of the vehicle. You may just repair the wires.
The other, expensive option is, that DDM or PDM electronic module is dead. Then take it to the shop for repair with the new module...
Aug 13, 2009 | 2006 Volvo V50
Radio goes off & on at will when gears are switched
yes you can change it yourself and it is the same as an F150 and here is a website junkyarddog.com and try autozone.com or your local library for diagrams pictures and step by step instructions
Mar 19, 2009 | 2000 Ford Expedition
Neff combination microwave oven
We have had NEFF repair man out again and he replaced the door switchs and this time it is OK.He did say if it was a problem again it will be classed as unrepairable because he thinks it is shorting out on an internal rivet on the bodywork which is inaccesable. fingers crossed it was the door switchs and it dosent blow the main fuse again .thanks for your responce. Simon.
Jul 23, 2008 | Microwave Ovens
37 people viewed this question
 Grubhead
Grubhead
