Question about Freezers
Refrigerator whirlpool model wrx38rwh6
Water has started to drip from a vent located at the upper front part of the fridge compartment...please advise as to the cause and remedy to this problem
  • Anonymous Mar 21, 2014
    Whirlpool Fridge Freezer ARC4170 has water dripping from the air intake located between the freezer and fridge compartments. What is the fix?
    President:
  • Freezers Master
  • 2,651 Answers
Sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Posted on Oct 26, 2008
I have a bottom freezer on fridge that leeks water in the freezer. Is there something clogged? How do I fix.
Some fridges have a drain that has a rubber valve in the hose that can get plugged up and then the water backs up instead of draining. You may have to take the back off the fridge (metal panel held on with a handful if screws), and I'd suggest go ogling the model and symptom to find a picture of the valve.
Jan 08, 2015 | Whirlpool Replacement Refrigerator...
How do i replace the cracked drip pan in the french door refigerator
  • Unplug the refrigerator from the power source and remove the decorative vent cover at the bottom of the fridge under the door. Some vent covers are screwed on but many just snap onto clip that hold them in place.
  • Pull gently on the exposed front edge of the drip pan and ease it out towards you. The drip pan slides on runners on each side of the bottom of the refrigerator. It may be full of liquid or debris so go slow and steady and then discard it.
  • Line up the new drip pan with the two side guides beneath the refrigerator and slide into place. Use the flashlight if to make sure the drip pan is in the groove on each side.
  • Clean and replace the vent cover by clipping or screwing it into place. Plug the refrigerator back into the power outlet
  • Dec 15, 2013 | Freezers
    Frozen water on bottom of whirlpool model evl181nxtq01
    I assume that the water is on the bottom of the fridge compartment? It could be that the drain trough has blocked and every time the fridge does an auto defrost, water runs out onto the floor of the fridge rather than down the drain. Once the defrost finishes, the water will stay on the floor of the fridge. Cold air falls to the bottom so its possible to get a sheet of ice in the bottom of the fridge. Locate the drain trough in the back wall of the fridge. See if you can visually locate any blockages or carefully dribble warm water down the drain to clear it.
    Oct 19, 2013 | Whirlpool Freezers
    Vents in the bottom compartment getting block ice
    Check out these tips...they can help you figure out what is going wrong withyour refrigerator
    Refrigeratornot Cooling or Fridge not Cooling
    How to Defrost Refrigerator DefrostTimer Problem
    WaterRunning in refrigerator from Freezer
    Refrigeratoror Freezer not Cooling or Getting Cold
    heatman101
    Jun 25, 2011 | Whirlpool Upright Freezer EV161NZRQ
    FREEZER MAKING ICE, BUT FOOD IS THAWING
    If you have a Freezer on the top model Kenmore, with warm temps in the fridge, AND water dripping onto the top shelf of the lower fresh food compartment (FFC), this is usually caused by a clogged defrost drain. Since Kenmore is not an actual manufacturer of anything, they take other brands, i.e. Kitchenaid, GE, Frigidaire, etc., take their names off and put on a shiny Kenmore nametag. This is a common problem with Kitchenaid refrigerators. You can determine if your Kenmore is made by kitchenaid by looking at the model # tag. the first three digits will indicate the manufacturer, Kitchenaids begin with the sequence, 106.*.If this is indeed how your model # begins, keep reading. Since the water cant go down the drain tubing to the pan at the bottom of the unit, it builds up on the freezer floor, eventually blocking the air return vents from the fridge to the freezer, and the vent from the freezer to the fridge. YOu can check this very easily. Look at the ceiling of your FFC, near the back. toward the sides you will see two square holes, about 2" square, stick your finger and feel around the inside of those holes, do you feel any ice/frost, or do you just feel styrofoam, you might even see frost/ice below the level of your ceiling? This drain usually gets clogged with defrost water that does not completely drain, then of course it freezes, eventually plugging up the drian hole located at the level of your freezer floor, behind the back wall. The water keeps accumulating, and freezing, on the freezer floor, eventually filling in and clogging the air vents..no air flow , the fridge wont cool. The easiest way to resolve this, empty out all contents and store someplace cold for 24 hours...a 2nd fridge, outside in a cooler if its cold like here in chicago. After its empty, unplug, open both doors and blow a fan for 24 hours. Prepare for an abundance of water due to melting ice.
    After you defrost, you can plug it back in and it will be fine, HOWEVER, I suggest you take the back freezer wall off, you might have to take a floor cover off first, likely 2-4 screws in both the floor and the back wall. When you have the evaporator exposed, you will see a black cal rod defrost heater underneath the evaporator, as well as your drain hole just to the right of center underneath both heater and evaporator. Take a piece of 12-14 gauge solid, not stranded wire, removing the insulation and exposing the entire 6-8" piece of copper wire. wrap the wire around the diameter of the cal rod heater, 3-4 turns should be sufficient, and stick the other end of the wire down that drain hole. This will melt any ice that will build up in the future, everytime your unit goes into defrost cycle, so this wont happen again.
    If air vents are clear of frost/ice, next thing to check is the back wall of your freezer, does there appear to be frost/ice/snow on the back wall? If so, your unit is not defrosting. On most Kenmores, this is usually caused by your defrost timer, located in the canopy mounted at the top of the FFC on Top freezer models, or your defrost thermostat, which is clipped onto the evaporator coil inside your freezer. Again, if its a 106 model Kenmore, this thermostat will have a pink and a brown wire coming into/out of it. My suggestion, if it isnt defrosting, change both. tjhe defrost control will connect with a plug, but you will have to hard wire the thermostat, ( cut wires from old, strip wire, and connect using wire nuts and electrical tape.)
    Since y ou mentioned the water accumulation, more water recently, my diagnosis would be the former versus the latter, as the lack of actual defrosting coincides with lack of defrost water, however I'll never say never.
    If your unit is a side by side model, check for ice on freezer floor...clogged drain. Check again for frost/ice on back wall, not defrosting, check same two parts, (the heaters rarely go bad on Kitchenaids, but never say never) You should also check for air flow into fridge, even if no frost / ice visible on back wall. Open the FFC door, and locate the air vent near the top, back of the fridge, on the left wall. While depressing the door switch, AND WITH THE FREEZER door closed, put your finger/hand near that vent. Do you feel any cold air? If you dont, you could have a bad door damper, not uncommon, or a bad damper control--> the temperature control WITHOUT the off or "0" position.
    If any of this seems a bit overwhelming, I suggest you have a reputable repair technician check your fridge.
    Oh, and lastly, you WILL NOT have two compressors, one for each compartment, nor will you have two sets of defrost heating elements, one for each half.
    ALL cooling for 99% of refrigerators made in last 25 years takes place in the freezer, with the fridge being an empty box, except for an air intake vent, and an air exhaust vent which leads directly back into the freezer. When a refrigerator unit seems to still be cold in the freezer, but not cold enough or not cold at all in the FFC, its ALWAYS going to be caused by lack of air flow. But as you can see, there are a few things that can cause that lack of air flow.
    Apr 05, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
    Constant Defrost causing water accumulation problems
    Yes! look under you fridge for the consendate drain hose *(usually dangling right over the catch tray) and using a long piece of slightly heavy guage wire snake up the drain hose and see if it's blocked.
    If it isn't blocked you might have a crack somewhere in the fridges interior near the fridge/freezer interface. That might be a bit harder to spot since it would most likely be under cover.
    Good luck and be careful.
    Dec 29, 2009 | Whirlpool Freezers
    New whirlpool refrig. freezer ok at 0 but refrig
    The freezer get the first crack at cooling and combination units have a fan and adjustable vents to steal some of the cooling capacity for the refrigerator. The vent are normally located in the back of the refrigerator compartment and with these, you can balance the cooling capacity between freezer and fridge. I recommend you swap your thermometer back and forth until you get the balance you want; typically the freezer should be at 5 degrees F or below and the fridge at 35-40 degrees F. Adjusting the control for temperature and having the vents set to supply the cold air you want in each compartment should give you the range you want in each.
    Sep 09, 2009 | Whirlpool Freezers
    Refrigerator
    hi thanks for the question it looks like you have a drain problem the drain tube goes to the back of the fridge by the compressor it is clogged up clean tube thanks te appliance doc
    Sep 26, 2008 | Freezers
    Fridge compartment
    Check the drain line on the back and under the refrigerator. I think you will find out that it is clogged up.
    You didn't give a model number ao I can't tell you where to pinpoint the blockage.
    There may be a drip catch at the top of the refrigerator that you can pull out, no tools needed on the drip catch.
    Jan 24, 2008 | Freezers
    Freezers Logo
    185 people viewed this question
    Top Freezers Experts
    Dennis Boxerman
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
    Are you a Freezer Expert? Answer questions, earn points and help others
