Question about E-Machines (T2958) PC Desktop
T2958 motherboard connections
My son swapped out the hard drive to test it in another machine, (a different problem). When he reinstalled it the computer would not power up. Power is getting to the mother board because a little led lights up on it. However, no light on the power switch and no fans run when I press the power button. I took off the front panel to see if the power switch is mechanically working (a problem I once had with another emachines). I pulled the wires from the power switch, HDD led, and power led off the motherboard all at one time thinking they were one plastic connector. To my surprise, they are separate. Can you help with pin location and polarity for replacement?
  • 1 more comment
  • carlb Jan 06, 2008
    exactly the same problem! I thought the connectors were one as well
  • Anonymous Feb 09, 2008
    same problem, replaced power supply and no luck. I unplugged the power switch from the motherboard(black & white) and used a jumper but that didn't work either.
  • Anonymous Dec 28, 2008
    Yup, same thing here...and the replacement cost of a new mobo is $189!!! that's about how much the PC cost!!!
Guest Solution #5
You are also an apprentice speller I see. I'll never know how you can just go online and display your illiteracy like that. Five spelling errors in one sentence. Didn't go to school or didn't pay attention did you? How can you expect to fix your computer?
Posted on Feb 24, 2010
I replaced my mobo in an emachine t2958 yesterday, today it doesnt power on so im off to get a power supply as well *should have read the board first*
my question is that i have the 2 optical drives set up as master slave.
i have the HD plugged to a pci slot since the board I am using doesnt have 3 IDE ports
the only other power plug that is left over (no idea what its for) is labeled P7 from the original powersupply
if I manage to find a setting for P7 and the supply fires up then i have saved myself having to replace the power supply, correct?
Sara
Posted on Sep 30, 2008
Lol dear guest the other 1% is the MB, Ram, HD , and or anything else
Posted on Jul 09, 2008
GOD DAMN!!!
oh im of no help hear but ive had it with people saying
"blah blah sounds like a power supply problem"
i mother **** switched my power supply, bought a new front
panle and still nothing, sry for the agrovation
but if you gona be all like "99% of the time its the power supply"
then for the love of god WHATS THE OTHER 1%!!
Posted on Jun 26, 2008
  • 29 Answers
Sounds like a power supply problem, I would check out a power supply tester, usually about 19 bucks, but now adays you can buy a decent power supply for 20 bucks, but before you can and spend money, be sure that everything is connected properly. im searching google now for the pin locations, but if you know what type of motherboard, it will make my search so much easier. ***reply to your other post*** all you need to do to get the hard drive to work in another machine is format the Master Boot Record
Posted on Aug 20, 2006
  • Bret Lovell Aug 20, 2006
    re-reading my post before, the master boot record is just the part of the hard drives software that tells what to boot to, when you change computers, it usually doesnt work, to format the master boot record simply get a windows 98 start up disk, and type fdisk /mbr
  • 3 Answers
Concerning the pin locations and polarity they are printed on the motherboard close to the pins. Also, your power supply is failing. I have a customer with the same problem, the power supply needed to be replaced and also the motherboard because it would not even boot to post.
My emachine model t2958 won't turn on.
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle of restarting or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive power and data cables IDE SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your dvd\cd floppy drives have secure connections and are not faulty or just replace them they could be faulty
computers need power and data to travel through every working device to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty electrical or fan lead can cause you problems
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
check you CPU central processing unit make sure its securely seated and has thermal paste it might be getting to hot the thermal paste will help disperse the heat
Thermal compound is a sticky paste that is placed directly onto the CPU.
Allowing for a more direct heat transfer between the CPU and HEAT SINK and preventing air gaps from forming between the CPU and heat sink.
hope this helps
Sep 06, 2012 | E-Machines (T2958) PC Desktop
Computer dosen't turn on. i ran the hard disk test it says "hard disk not exist"
There could be two possible problems here: A bad cable or a bad hard drive.
If you have a desktop computer, you could try swapping the cables over from your CD drive with your hard drive.
Failing that you need to get a replacement hard drive.
If you have a desktop computer, you need to check the connections on the existing drive or motherboard to see if you have a ribbon cable that connects to the drive and the drive has lots of pins to connect it, (IDE or PATA) or a narrow red or yellow (SATA) cable. You will need to get a 3.5" hard drive.
If you have a laptop computer, you also need to check the connections on the existing drive, if it has pins (IDE or PATA) 2.5" drive or if it has L shaped connections (SATA)
You will also need to reinstall the operating system from its installation CDs or backup disks. If you don't have them, you will need to obtain them from your manufacturer.
Jul 22, 2011 | Computers & Internet
I swapped hard drives between Miltopes, now I cant get them to boot up. What must be done for them to boot properly ...or did I just destroy my hard drives?
It happens because the hard drives come from two different machines. Basically even it's the same operating system, each machine apart has a different configuration.
Reinstall everything with the hard drive attached to the desired machine.
Mar 02, 2011 | Miltope TSC-750M Notebook
Yesterday my computer stopped booting. Now all it does is give a long beep tone every 3 to 4 seconds. I've swapped known working memory, replaced cables to my drives , removed and reinstalled the CPU,...
make sure the RAM is seated properly
Test or Replace your PSU then test all leads that are attached to your hard drive sounds like a faulty lead of some sorts then
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your
(motherboard to hard drive)
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty because a computer has to have an end to the circuit any fulty leads will lead to no boot up
hope this helps
Nov 11, 2010 | Biostar K8M800 Micro AM2 Motherboard
It wont show up
Have you tried alternate usb cables and usb ports on your system? have you tried a different system? If that doesn't resolve the issue- you have a dead external drive- if swapping the cables works, you have a dead cable. If swapping the port that you are connecting to- it could be the port is bad, or the port is a low power port. If swapping to a second system works- and none of the ports on the other system works- then the system will need service- either for reinstalling windows, or a replacement motherboard since the USB has failed.
I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
Oct 03, 2010 | Western Digital My Book Essential 1TB...
Emachine T2958, tested power supply (good). Green
Is your PC making any beep sounds, anything at all on monitor? if nothing try removing cpu then re-install cpu?
Feb 09, 2010 | E-Machines (T2958) PC Desktop
Emachine D2880-No Power
Probably yes, the poiwer-source may be delivering "dirty" power (happens also when using a back-up generator, as in the power in the building goes out, or when used in an old RV, and the back-up kicks in) <--- is a safety feature to protect the CPU. Try also a different powerstrip, or head off to the neighbors and try their plug before swapping out the power supply.
In the end, you may wish purchase an inexpensive clone-tower, swap out the HD and processor (if you are spending too much time and money trying to band-aid the old one)
Hope this helps!
-- RT
Sep 03, 2009 | E-Machines eMachines Desktop PC
Emachine t5026 boots only with os disk in drive
Emachines don't use the cable select properties very well. Change your drive to Master, reformat and reinstall the operatiing system.
Apr 10, 2009 | E-Machines (T2958) PC Desktop
Swapped hard drive into new casw and now it wont boot up
This is due to a hardware conflict.
The system drivers on the hard drive are for the old mother board and devices,You will have to reinstall OS while it is install on the new mother board,The computer cannot boot to a drive that is loaded to another system unless all the devices and drive are identical.
Please rate this a fixya
Feb 13, 2009 | EliteGroup 848P-A Motherboard
T2958 continuous startup cycle
It sounds like there may be an issue with the memory chips. If available, take a memory stick that matches the type of memory you need for your computer. Take out all memory sticks on the motherboard and try the new memory stick in the first memory slot and see if you get the error. If so, then try it in the second memory slot.
Aug 20, 2006 | E-Machines (T2958) PC Desktop
E-Machines (T2958) PC Desktop Logo
982 people viewed this question
Top E-Machines Computers & Internet Experts
Steve Allison
Steve Allison
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
