Question about Samsung SyncMaster T240 Monitor
Samasung T240 blinking on and off
My Sasmung T240 sundenley started to blink on and off every few seconds. I tried pressing the buttons on the side and noticed that the "Source" button was not responding (it's as if it's constantly pressed). The screen goes off for half a second then back on (as if it's changing input) and sometimes it jumps to a different input. I had the same problem with this screen a year ago but it got fixed under the warranty which is expired now. I don't know what they did but I don't think they opened it. Any ideas?
xCAUSALITYx
  • 210 Answers
SOURCE: Help
Take every single cable out of the unit, now power on the unit.
If the power protection still shows then there is an internal fault, usually a short or a component defect.
If it powers on ok, switch off and insert 1 speaker at a time and power on the unit until the protection mode comes on again, the last speaker you have put in has overloaded it for some reason, also as you are trying each speaker use the volume and bass controls to see if there is an internal overload.
Thats as much as I can offer you until you narrow the fault down to the unit or one of the speakers.
Cheers
Posted on Jun 09, 2008
  • 3 Answers
SOURCE: Protection displayed and shuts off
Hey guys! Im glad you found my solution on my blog, and posted it here. I hope you ccan fix yours, or get it replaced on warranty. Im happy to help you with anything, the capacitors i think was 4,7 uF, 100volt, not sure.
Here is the link to my solution: http://lemurt.wordpress.com/2008/08/18/defenition-of-waranty-void/
:D
/ lemurt
Posted on Sep 22, 2008
oldrogers
  • 53 Answers
SOURCE: Syncmaster 910t blinks image perfectly once and goes back to black
I've had same problem and I fixed it!
With good CCFLs, clean supplying voltages, all good capacitors and resoldered junctions, the backlight still turns on for fraction of second and goes off.
It is in the Power Supply / Inverter board. In the Inverter part there are two dual n/p-MOSFETS U3 and U4 (models STS7C4F30L, SO-8 packages). I've found they both have too high ON-Resistance (perhaps due to age and constant overheating). All you need to do is to replace them. I've checked many models and found closest by Rds and IDcont (continuous drain current) are IRF7389, you can find distributor by findchips.com, but I've bought them at newark.com, they're cheap.
The hardest thing was to unsolder old chips, they are glued to PCB and because of overheated material under them, the copper could easily go apart. Therefore, the best is using fine tips cutters, cut off all legs one by one and then take chip body off the PCB and take legs from pads by iron. That's all you need. After that my monitor started working as new even with old CCFLs. Good Luck!
Posted on Sep 09, 2009
SOURCE: screen goes black
what to do when screen goes black and says analog
Posted on Dec 17, 2009
  • 1684 Answers
SOURCE: green power indicator under on-off button blinks
The Samsung SyncMaster 940MW monitor has an issue with the power supply going out. The flashing power light or slow turning on are the classic symptoms of this issue. Check out our web site at: www.ccl-la.com We have a step by step repair guide posted that will guide to doing the repair yourself. It involves changing a few capacitors on the power supply. If you can solder then you should be able to do the repair yourself. If you don't want to do the repair we do offer a repair service for $35 plus return shipping. If you have any additional questions just let us know at: tech@ccl-la.com
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Jan 19, 2010
How do I fix a whirlpool washing machine with the 'door locked' light blinking?
The door lock needs to be replaced. I would recommend using a technician to replace the part just to be on he safe side.
Sep 28, 2015 | Whirlpool Washing Machines
Power button goes on for a few seconds when clicked and then turns off before picture comes on.
When it shuts down press the menu and Input buttons on the set both in together and hold for 6 seconds the led will then start to blink a two digit blink code which will repeat a few times indicating where the problem is. Let me know the blink code sequence and I will assist you with the problem.
Jun 11, 2011 | Mitsubishi WS-55809 55" Rear Projection...
Printer jamed after putting in more paper and accidently pushed the power button off. Will not respond to anything I have tried.
Reset your Printer by following these steps for your Printer Model:
EPSON Stylus Color 900, 980
Pressing and holding LOAD/EJECT and CLEANING buttons, press POWER button, You will see blinking INK OUT led.
Release all buttons.
In 2-3 seconds time press and hold CLEANING button for 10-12 seconds.
EPSON Stylus Color 3000
Pressing and holding PAUSE, LF/FF and DOWN ARROW buttons turn on printer.
EPSON Stylus Photo 785, 895
Pressing and holding Maintenance and Roll Paper buttons, press POWER button, You will see blinking Error led.
In 2-3 seconds time until led is blinking press and hold for 10-12 seconds Roll Paper button, until all leds will blink.
EPSON Stylus Photo 890, 1280, 1290
Pressing and holding Maintenance and Roll Paper buttons, press POWER button, You will see blinking Power led.
Feb 27, 2011 | Epson Stylus Photo 785EPX InkJet Printer
I have a hyundai radio 5064 and I want to change the time on it?
I have an 02 Santa Fe with 5064 radio. Here is what works for me. Key to ACC.
PWR on radio to OFF (display time only).
Press & hold { 4 D- } & { DISP } button simultaneously for about 3 seconds. Time will blink. If time does not blink, turn key to OFF, back to ACC & start over.
With time blinking....
Press { TUNE/SEEK UP } (double arrows) button to get desired hour.
Press { TUNE/SEEK DOWN } (double arrows) button to get desired minute.
Once set, wait a few seconds for time to stop blinking & your done.
Jul 17, 2010 | 2002 Hyundai Santa Fe
Tony Hawk ride board is not syncing with the console to connect and play the game. It the xbox connect button flashes and then when we press and hold the sync button, nothing happens.
Try to change your batteries even if they are full.
First press the Xbox Guide Button (located on the side of the skateboard) until it lights up and starts blinking. Then press the Sync button on the Xbox console so that the front lights start blinking. Now push the sync button on the skateboard (little button that is to the left of the Back button) until it starts flashing. Both the board lights and the console lights will blink twice when they are synced.
Jul 16, 2010 | Microsoft Xbox 360 Console
Reset radio but can't reset clock
just press the clock button for a few seconds then press it again for few seconds and it should stop blinking once it stops blinking press the clock button down again and hold then once it starts blinking release the clock button and adjust the hours and minutes
Jun 13, 2009 | 2007 Honda Accord Sedan
My Samasung NV3 is not charging and not swtiching on.
My suggestion is to open the battery door on your camera and remove the battery for 60 seconds. Then put the battery back in and close the battery door. Then try charging it and powering it on
May 30, 2009 | Samsung NV3 Digital Camera
Free Pulse
The following procedure will re-establish the communication link between the Headphones and the Wireless adapter, this is called "pairing". Before you start please make sure both the headphones and the wireless adapter are fully charged and turned off.
Note: The headphones and the wireless adapter come pre-paired from the factory.
1. Press and hold the power button on the headphones. See Figure 1.
Figure 1
2. Continue to hold the button down until the LED starts flashing red/blue in an alternating pattern. Release the button when the LED starts flashing red/blue. See Figure 2.
Figure 2
3. Once the headphones LED is flashing red/blue, press and hold the power button on the wireless adapter. See Figure 3.
Figure 3
4. Hold down the button until the LED starts flashing red/blue in an alternating patter. The LED will blink blue, then turn off for a few seconds then blink red/blue. Release the button when the LED starts flashing red/blue. See Figure 4.
Figure 4
5. Once both the headphones LED and the adapter LED is blinking red/blue, press the volume up button once on the headphones. See Figure 5.
Figure 5
Once the headphones is paired with the adapter, the LED on the headphones will blink blue once every two seconds. See Figure 6.
Figure 6
When the adapter is paired the LED will be solid blue. See Figure 7.
Figure 7
The adapter may continue to blink red/blue for a few seconds even after the headphones LED starting blinking blue. This is normal; the adapter may take a few additional seconds before the LED turn solid blue.
Once the headphones and the adapter are paired, it is not necessary to pair them again even if the batteries on both units are completely drained.
Additional Note: Repeated pairing will not improve the sound quality or give the headphones and the adapter a cleaner connection.
Mar 11, 2008 | Logitech FreePulse Wireless Consumer...
The headset keeps blinking a red light
I had this very same issue which was remedied when I unplugged the headset recharging dock for approximately 5 seconds then plugged it back in. After about 10 seconds everything re-synced and was fine after that. -No more blinking.
Sep 02, 2007 | GN Netcom GN 9120 Professional Headset
Samsung SyncMaster T240 Monitor Logo
448 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
