Question about JBL Audio Players & Recorders
JBL Basswave Sub - Volume EXTREMELY Low
My Basswave subwoofer recently stopped functioning correctly. It will turn on, but the sound is so quiet that it can only be heard if I turn off all the other speakers and put my ear right next to it. It was a gradual process, and it just started getting quieter and quieter until it got to this point..I think one (or more) of the electrical components went out (a capacitor or something), but I'm not skilled enough to do all the necessary tests. I do have some electronics experience though, and could fix it if I knew what to replace. Please help. The service manual can be found here: http://www.diysubwoofers.org/projects/other/basswave/BASSWAVE.pdf Thanks in advance to anyone who helps.
bluenadas
  • 203 Answers
SOURCE: SubWoofer
Sounds like your original and this sub have bad amps. The amp for the sub is not the same as the amp for the other speakers. The old unit has a dead amp and this new one is on the way out. (Pulling too much current on high bass)
Posted on Jun 15, 2007
simplemitch
  • 752 Answers
SOURCE: subwoofer works at high volume, doesnt work at low volume
You had the settings set incorrectly and overdrove it. The voice coil leads are burn't open. If you look at the little flexible braids by the terminals I'll bet they are black/brown and maybe even burn't in half. It's toast.
Posted on Sep 22, 2007
  • 2336 Answers
SOURCE: JBL sub PSW-D110 hums, and the fuse is blown
Here is the value of C24 >>> 330nf 100V 80/-20% mono-ceramic axial.
Posted on Mar 25, 2008
  • 125 Answers
SOURCE: Sub now very quiet
It sounds like your sub may have died ,get hold of a mulitimeter and check the impedance it should be 2 or 4 oms depending on the sub.
Posted on Apr 20, 2008
  • 99 Answers
SOURCE: Gigaworks S750 Sub - Pops and Cuts Out
There is obviously a problem on the amp board with 3 STA575 amplifiers. It may be that one of the diodes is shorted or one of the capacitors has dried up or shorted. For more information I have posted a link to a forum thread that contains all of the information you would need to fix the Gigaworks S750 system. If the information has not already been posted there then you can ask on there and the people there will point you in the right direction.
http://forums.creative.com/creativelabs/board/message?board.id=speakers&thread.id=8037&view=by_date_ascending&page=1
Posted on Jan 04, 2009
Sony CMT-GP5 subwoofer output very quiet
From the description the subwoofer is the problem, since the item is new return it to the place of purchase, this is a manufacture issue.
Aug 13, 2012 | Sony CMT-GP5 CD Shelf System
When I turn the volume control on my home powered subwoofer, it makes a humming sound, then it stop working
check your connections, RCA, Speaker wires, maybe there is grounded. try other wires which you think in good condition..
Aug 10, 2012 | JBL Audio Players & Recorders
I purchased a JBL PB12 (120v) subwoofer from a friend. It worked excellent for a month or so, but completely went on the fritz yesterday. Whenever I turn it on, I get a loud whining noise, that starts high...
It sounds like something on your main board of your amp is going out. It is most likely the finals, or as you said a capacitor. Test the port with another speaker, if al is well then the wooferis bad. if not you will have to go inside the amp for repair. Depending on the brand it can be a little complicated. Try and narror it down to the proper componet, post back the results and we will go from there. Also is this sound comming from all channels or just the woofer?
Sep 28, 2009 | JBL PB12 Subwoofer
Amp is on, but sub wont produce any bass
Make sure the subwoofer is set to low frequency, make sure subwoofer and bass are enabled on the headdeck. Make sure the gain is turned up on the amp, make sure the rcas haven't come out of the back of the head deck.
Aug 04, 2009 | JBL GTO14001 Car Amp
JBL Subwoofer - Intermittent operation
Sometimes bad caps show a lifting or rounding of the top of the cap, sometimes this top will split from heat and pressure and sometimes it will not show any sign of damage but will be dry inside and its capacitance value will drop to a very low value. Replace the big power supply caps and test again. Get the same size, value and voltage rating. You can go higher on voltage rating and a bit on value. Getting a similar size or something that will fit in the same space is important also.
Jul 20, 2009 | JBL PB10 Subwoofer
Buzzing sound coming from my jbl creature speakers no music
Try this Double click on the volume control icon in the system tray.Click on "options"--"Properties".Select Line-in and Mic.Mute them. I hope this solves your problem.
May 14, 2009 | JBL CREATURE II Computer Speakers
Pb12 makes thumping sound after warming up
Hello there..Thats normal only if your sub volume and the pre amp is turned up..Your amp is the cause of the speaker jump..Turn amp volume sub level down a few and check your wire from sub to amp..If all of that is good is a normal operation for pre amp warm up in sub if level is turn to max..Try unplugging amp freom sub then turn sub on stand alone(just sub outlet plugged in and no wires from base amp plugged in..If sub stops the its the amp making the problem..If it still is there then the pre amp is either dusty on inside or the outlet plug that it is plugged in doesnt have a good ground..Hope these help to solve your problem..Have a great day...
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_a3369546f8067589
Apr 02, 2009 | JBL PB12 Subwoofer
Connection a JBL surround cinema speakers with sub to a Yamaha
if you do not have the digital hook up from the tv to the reciever
304c659.gif then you will not get the subwoofer sounds or the dolby digital sounds
if you don't have this on your tv then just turn off the dolby digital when watching the tv , and you should be able to hear the subwoofer thru the virtual surround sound
hope this info is worth a fixya and if you need other help then just ask me and
i'll be glad to help
electech
Nov 23, 2008 | Yamaha HTR-5850 Receiver
Subwoofer Wont Work
If the connections are correct...?
then it doesn't sound like theres a problem with the amp.
make sure the amp is not to powerful for the sub?
eg: 1000w amp, 500w sub.
Sounds stupid but it happens.
make sure the gain / volume is not too high!
if your BMW has a totally sealed, metal boot area this doesn't help.
Dec 11, 2007 | Sony XM-2150GSX Car Audio Amplifier
Subwoofer works at high volume, doesnt work at low volume
Sep 17, 2007 | Kicker 02S10L74 Car Subwoofer
228 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
