Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
1988 springer softtail
My ignition will not start. I push the start button and all I hear is ONE click and nothing else. If I jump the across the coil with a screwdriver or push the bike I can start it. How do I fix this problem?
  • ravenclaw65 Oct 30, 2008
    thank you Yes I could use the help in wiring and locating the relay
I don't know if you got this problem fixed but sounds like you just need to replace the starter relay. The wire is not too thin, it is from the factory. The starter relay is normaly just behind the starter on the left side of the bike.
Posted on Nov 01, 2008
Sounds like you have a voltage drop (that is a loss of power between the start button and the starter solenoid) the wiring on that circuit may be too thin. to remedy this problem you need to put a relay in the circuit. let me know if you want to know the details of how to wire the relay up.
Posted on Oct 26, 2008
Why am I not getting fuel to carb? New fuel pump, filter, relay, fuses. Van was running, shut off for a half hour, but will not start. Not getting fuel, replaced relay again, checked fuses again. Jumped...
Are you getting the ignition activated voltage to the relay? If you are, and you can jump across the relay to turn on the pump, I would say your relay is defective. If you know the relay pins for the ignition input and ground, you should be able to test it outside its plug in socket. You should hear it click when +12V and ground are applied to the proper pins/connectors for the ignition voltage. An ohm meter could be put across the supply +12V and fuel pump pins/connectors to really check the operation. If you think your relay is good. I would start checking for a bad +12V connection for your ignition supply, as well as the +12V that is switched through the relay. And the grounds to all. Use some contact cleaner on relay pins and socket. Ignition switch contacts can cause issues too. If it stays broke at least it should be easier to find than something that is intermittent. Based on what you stated, most of your troubleshooting should be at the relay socket (knowing which connectors do what) to isolate the issue to the relay, your ignition voltage, or your fuel pump voltage. After that it is knowing which step to take next.
Mar 02, 2015 | 1988 GMC Safari
Drove my 2002 softtail springer 396 miles and no fire to clyinders all of a sudden
Hi, Anonymous and the usual suspects are:
1. Fouled spark plugs.
2. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and module.
5. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose check for spark leakage in the dark.
6. Faulty ignition coil or electronic control module.
7. Faulty CKP, CMP, or BAS sensor.
8. Faulty ignition switch.
9. Tilt sensor needs a reset.
10. Security alarm failing to disarm needs reset
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have a nice day.
Harley Davidson Manuals Mark Workshop
http://www.stcharlesharleydavidson.com/OEMpartfinder.htm
https://serviceinfo.harley-davidson.com/sip/index
Instant Tech Relief A must have !!! only $6 a month "CHEAP"
Apr 08, 2014 | 2002 Harley Davidson FXSTS Springer...
My 2001 Yamaha R1 has an issue. I put the key in and turn it on, everything lights up fine, but when I press the start button nothing happens.
If you push the starter button and hear a click the starter button is good. If you do not hear a click, put power to the two skinny solenoid activation wires(+ and -), if you hear a click now you have a bad starter button. Clean or replace the switch. Follow the positive battery cable to the solenoid, short across the battery power cable and the starter power cable. If the starter works you need a new solenoid. If you tap on the starter with a plastic hammer while holding the starter button, and it works, you need new starter brushes.If you take the starter apart and the coils are burnt or the armature is shorted you need a new starter.
Sep 03, 2010 | Yamaha YZF-R1 SP Motorcycles
WILL NOT START 94 SOFTTAIL
You need three things for an engine to run, compression, spark, and fuel. I'm going to assume that nothing drastic happened to cause you to lose compression. So, that leaves fuel and spark. Usually, if your engine quits getting fuel, it will spit or cough a time or two before it dies. If it loses spark, it simply dies, quickly.
I'm also going to assume the "run/stop" switch in not the problem. Check to see if you have voltage at the coil. Turn the ignition switch on and test the white wire going to the coil. If you have voltage there but no spark, check the resistance of the primary side of the coil.
Using a DVOM (digital volt ohm meter) put one lead of the meter on each of the small terminals of the coil, makes no difference which lead goes to which terminal. Make sure you take the wires off of the terminals. With the meter in the "R X 1" range, the resistance of the primary side of the coil should be between 3-5 ohms. Any higher or lower than that, the coil is bad.
If you have voltage and still no spark, I would suspect the something is wrong with the pickup in the "nosecone" on the right side of the engine. If you take the timing plate out, make sure that your mark it first so that you can replace it in exactly the same position.
If you don't have voltage, go to the circuit breaker for the ignition circuit. See if the circuit breaker is tripped. If so, you have a short somewhere between the circuit breaker and the coil.
Good Luck
Steve
Jun 09, 2010 | Harley Davidson FXSTS Springer Softail...
Harley won't start ... starter not working custom softail ... 80 ci v twin engine... nothing happens when I push the starter button.... battery is fine and all lights work... clicking sound under seat...
That clicking sound you are hearing may be a circuit breaker tripping indicating a short circuit somewhere. I think the starter circuit is powered by the ignition circuit. If you have a short circuit in your ignition system the breaker will trip killing power to your ignition, thus the engine dying, and preventing power for the starter circuit preventing the bike from being restarted.
On your bike, I believe there is a chrome coil cover over the coil on the left side of the bike. Check and see if this cover has come loose. I've seen them come loose and fall down on the coil connector on top of the coil shorting it out. If that ain't it, just keep looking, there's a short somewhere. Good Luck
Mar 30, 2010 | 2005 Harley Davidson FLSTF - FLSTFI Fat...
88 mustang wont start, was running, replaced batt,starter,relay. relay clicks alot and batt is being drained.
did you try the ignition coil or try the fuel cut off switch in the trunk on the left side if the red button poped push it back in
Oct 11, 2009 | 1988 Ford Mustang
I have a 1988 suzuki katana i have bought a starter relay for it and the bike has power to starter and ignition switch but when i push the start button nothing it want do anything i tryed to straght wire...
it could be your clutch safety switch.follow the wires from your clutch lever till you find a connecter. unplug and put a jump wire on the bike side. make sure you are in neutral .pull in clutch and try.if starts replace the sw
Sep 19, 2009 | 1988 Suzuki GSX 600 F (Katana)
How do you keep the speedo gear on 1988-95
if the speedo gear is on front wheel it shloud have a tab that locks into the hub thats what spinns not the whole unit. if the while unit is trying to spin check to see if its frozen
Sep 01, 2009 | Harley Davidson FXSTS Springer Softail...
First problem won't start unless I jump across
Okay I want to say get an ignition switch for the starting problem. The wire that makes the solenoid work comes from the s terminal on the ignition switch. The ignition (i) side of the ignition switch goes to the coil. The running and dying could be the coil. Both wires start at the ignition switch. Check those two wires for connections. Take out the switch and see if the (i) and (s) terminals do anything when you turn the key.
Jun 30, 2009 | 1987 Ford Ranger
Lands Phones Logo
237 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
