Question about Ebara Plumbing
ESR80WN How does the ESR80WN compares to the Leybold 100P and the Edwards ODP 80 series.
What new dryer is comparable to the 80 series Kenmore dryer?
I would say for sure that it is the Roper Dryer which is made by Whirlpool..
Dec 08, 2015 | Kenmore Dryers
Can a Hayward s 166 t Hi rate sand filter be rebuilt
Parts can be replaced sure, but will it be worth it compared to buying a replacement or even upgrading. Laterals (if broken sand gets in pool) can be replaced on this unit from 48 off amazon and is cheaper than buying a new unit, same with leaking rings or seals. but if a part of the tank is cracked or something like that you might up spending almost as much to replace a piece of the unit as it would be buy a whole new unit. Amazon has this model for 180$ if repairs would cost more than 80 I would say replace it, these things dont last forever, especially if you live in a cold place that freezes in the winter and it sits in the sun all summer.
Hayward S166T Pro Series 16 Inch Top Mount Pool Sand Filter Hayward SX164DA Lateral Assembly with Center Pipe Replacement for Hayward...
Hayward SP0714T Pro Series Vari Flo Top Mount Control Valve
Hayward SX164AA1 16 Inch Filter Body with Skirt Replacement for Select...
There was also a couple smaller parts on amazon but you should check it out and also compare them to some other places.
Aug 09, 2015 | Hayward Pool & Spa
I have a 80 series 1997 land cruiser 1hz motor has been rebuid 12 mounths a go and after market turbo and inter/cooler fitted plus a bigger rad/fitted it still over heats going up hills even on 22degs
Does it act like it is overheated? Could be the gauge or coolant sensor. I am assuming the coolant sensor has been replaced. So what really needs done is put the vehicle on a scanner, Read the ECM and compare it to the gauge reading.
Jan 13, 2015 | Cars & Trucks
Where to find manual for nwt 100p
The NUWELD NWT-100P is a Chinese MIG welder sold primarily through Australian weld suppliers and they do not post any instructions on-line at the wholesale or retail sites. I would reassure you that the manual will be almost worthless at any rate since it will be written by Chinese college students who are interns at the factory. The likelihood is that this welder is exactly what the dials and switches look like. Post a photo and anyone here will be able to guide you to the correct settings for your application. Be sure to include the weld wire information, shielding gas or flux, and the target application (gauge of sheet metal, thickness of steel stock, etc.).
Sep 14, 2014 | Welding Tools
How can I start my 2008 Chevy trailblazer 4.2 v6?
Ho It would have nothing to do with the starting. Does it crank over?.. Is there Gas?.. and is there spark?. a 2008 will have fuel injection so the best answer would be a diagnostic.. Try getting an ODP reader and plug it into the connector.. The ODP reads the onboard diagnostic codes. Is your check engine light on?.. do you hear the fuel pump?.. Probably knowing chev.. and my knowledge on them.. I will hedge bets on fuel pump. Answer back with - does it crank...does the engine "kick and try to start?.." or is it just turning over with no life. No life.. I would say fuel pump .
Sep 02, 2014 | 2008 Chevrolet Trailblazer
WHY ARE EDWARDS BPS6A FUSES NOT REPLACEABLE
As much as I would like to say that it is because they want you to buy a new panel, it is required to obtain their UL listing.
May 27, 2014 | Edwards Furniture Edwards Est Remote...
Bedlocker won't open
I read on another forum where they had a problem with some of their Brake Mechanisms failing.
"Easy fix. Just take 3 screws out from the side of the motor and the unit comes right off. The brake is added so that the bedlocker stays locked in-place once the pressure sensor shuts off the motor. Without it, the cover may activate with vibration of the moving vehicle."
You could also contact Pace Edwards at
http://www.pace-edwards.com/site/?d=123&dt=36
& see what help they could offer.
Apr 22, 2014 | BL2028: BedLocker Tonneau Canisters
The fuse blew on the board. The tech said it was because the battery was connected before the main A/C power breaker was turned on. Is this true or does it matter which power A/C or D/C is energized...
Primary power should always be applied before batteries are attached. Voltage spikes that can occur when primary power is applied can blow the fuses. The most common cause of the battery circuit fuse blowing is that the batteries were not connected properly.
Aug 16, 2013 | Edwards Furniture Edwards Est Remote...
Infinity TSS1200, sub woofer
Check ebay - Edwards Electronics - fixes Infinity and JBL amps :) including the tss series
Mar 16, 2013 | Infinity Audio Players & Recorders
Is a patriot heater comparable to a goodman heater
The Patriot 80 is an oil furnace made by heat controller, To my knowledge Goodman (aka AMANA) does not make an oil furnace.
Feb 23, 2009 | Goodman GMS90703BXA Heater
Plumbing Logo
Top Ebara Plumbing Experts
Donni Steen
Tom Chichester
Are you an Ebara Plumbing Expert? Answer questions, earn points and help others
