Question about HP Photosmart C6180 All-In-One InkJet Printer
HP photosmart c7280 error Oxc18a0301 - HP Photosmart C6180 All-In-One InkJet Printer
  • 685 Answers
SOURCE: HP Photosmart C7280 Paper Jams
It isn't always about the paper. The video shows a few other things to check.
Posted on Jun 17, 2009
  • 54 Answers
SOURCE: HP PHOTOSMART C7280 ERROR 0xc18a0001
Follow the steps carefully from the front panel of the All-in-One.
1. Get the unit into the “Support Menu” by following the steps given below.
A. - Press and hold the “*” key.
B. - Press the “#” key and release both keys.
Now Display should say “Enter Special Key Combo”
C. - Press and release in sequence the “1”, “2” and “3” buttons.
Now the Display should say “Support” and display the FW rev (something like R0631R)
2. Press and release the right arrow button until the display says “System Configuration Menu”.
3. Press and release the “OK” button.
4. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
5. Press and release the “OK” button.
6. Display should say “Hardware failure status: Clear. Press OK to clear”.
7. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
8. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
9. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
10. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
11.Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. The Printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
12.To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
Posted on Sep 12, 2009
SOURCE: HP Photosmart C5180 All-in-one error Oxc18a0301
I tried everything mentioned above and the printer still does not work - the printer is about three years old but rarely used... is this just a faulty product from HP?
Posted on Dec 30, 2009
  • 1382 Answers
SOURCE: error message Oxc18a0301
The "Oxc18" series errors can be removed by resetting the printer. Unplug the USB cable from the printer, remove the ink cartridges. When the "Insert ink cartridges" message appears unplug the power cord from the printer. Wait 1 minute (at least), then reconnect the power cord and turn on the printer if it didn't come on by itself. Reinsert the ink, close the unit and print a calibration page if prompted to do so. Finally reconnect the USB cable to the printer. If this doesn't work, the unit needs service (or replacement if the service call will cost more than a new printer).
Thank you!!
Posted on Jul 17, 2010
  • 30 Answers
SOURCE: How do i repair: hp Photosmart C7280 Printer ink
Try holding down the ok -- cancel -- black -- color buttons with 4 fingers while at the same time powering the unit off. Keep them held down till it is off. Then turn it back on normally & it should try to do "Maintenance" & you hear a whirling noise --- that is the ink pump spinning to try & pump in ink to the print head.
Here are the details. Got the Ink System Failure message. The error code shows was '0xc18a0005'. The tech had me press and hold the '*' key on the key pad, then press the '#' key and release them both. Then he had me enter '123' to enter maintenance mode. He then had me press the right arrow (beside the OK button) until System Config. menu appeared on panel. Then pressed OK two times to clear the error condition, then cancel two or three times to return to the top menu. Then powered off and back on, printed a test page just fine, copied a document fine.
Posted on Jul 26, 2010
Oxc18a0206 hp photosmart c7280
Unplug power cord from printer and electrical outlet wait 30 seconds and hold in help and OK buttons while reconnecting power cord. continue holding buttons until screen turns black turn printer on and continue this helped me.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Feb 13, 2013 | HP Photosmart C7280 Printer
ERROR OXC18A0301 HOE DO YOU FIX IT?
look solutions on
http://h30434.www3.hp.com/t5/Other-printing-questions/C6100-All-in-One-message-Ink-System-has-failed-Error-Oxc18a0301/td-p/25751
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 20, 2011 | HP Photosmart 3210 Printer
Error 0xc05d1281 in HP photosmart C7280
hi............
pls click here for solution
thank you.........
Jul 29, 2011 | HP Photosmart C7280 Printer
HP C7280 printer: "Pump motor stalled" error
This means there's a failure in your printer's pump motor.
If you are still under warranty, contact HP's Customer Service here : http://welcome.hp.com/country/us/en/wwcontact_us.html
If not, you can try your local computer store for a check-up but they'll probably suggest a new printer.
Hope this helped.
Please rate :)
Mar 04, 2011 | HP Photosmart C7280 Printer
HP Photosmart c7280 all in one can't be found
Assuming its all connected and powered up, try re-installing the drivers.
Jul 21, 2010 | HP Office Equipment & Supplies
Oxc18a0301
Paul, Please reinstall drivers for it following the link below Installing Devices on PCs and Laptops
May 17, 2010 | HP PhotoSmart C5150 All-In-One InkJet...
Run out ink error warning message
are using a refilled cartridge?
if yes, install an actual brand new one.
are you using an official cartridge that you've had laying around for a while?
the cartridges expire so check if your cartridge has expired and replaced accordingly.
Mar 29, 2010 | HP Photosmart C7280 Laser Printer
HP Photosmart C5180 All-in-one error Oxc18a0301 I replaced 2 ink cat with proper ink. Now I get error oxc18a0301
Perform the normal assert troubleshooting:
-turn ON the printer
-disconnect the usb cable from both ends of the printer and pc if printer is connected with USB cable
-open the cartridge door and remove all the ink cartridges
-close everything without installing the cartridge
-disconnect the power cable from the back of the printer without turning off the power
-wait for 30 secs
-plug the power cable back in and install all the ink cartridges if the printer turns on
-wait the printer to initialize and stop making noises
**don't attempt to print this time
-turn off the printer by disconnecting the power cable from the back
-wait another 30 secs
-plug the power cable back in and if the printer is ready to go
-try printing a test page
Get back to me if it doesn't work.
May 31, 2009 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
