Question about Dryers
Wiring a xpelair dx100
As 2 wires l and n and i want to wire it to pull light switch
  • 79 Answers
SOURCE: Fan switch broken, wires out when opened
I googled Hampton Bay Manufacturing and this is what I found:
Hampton Bay fans are manufactured by "King of Fans Manufacturing, FL". The contact number for them is 800-330-3267. ...
Maybe they can supply you with a wiring diagram.
Posted on Jun 11, 2008
The Duff Man
  • 3 Answers
SOURCE: ceiling fan pull chain switch replacement
Just take either one of the black wires from the switch and connect it to the group of black wires. Then take the remaining black wire from the switch and connect it to the single black wire coming into the light kit. Finally check the bulbs to be sure they're not burned out.
Thanks and good luck
Posted on Jan 24, 2009
SOURCE: pull switch wiring schmetic
Call an electrician
Posted on Feb 12, 2009
  • 63 Answers
SOURCE: Wiring to a 3 single pole combination switch
run 14-2 wire to power switches, then run one 14-3 wire and one 14-2 up to fixture..you will have an extra neutral but its okay... just tie all nuetrals together....this gives you the needed 3 hot wires!
Posted on Apr 05, 2009
cj2176
  • 520 Answers
SOURCE: Wiring Door jamb switch
I'm going to guide you on how to create what is known as a "switch leg".
1- run a 12-2 w/ground wire to the light fixture from new switch.
2- connect black wire "hot wire" to the shiny bronze tinted terminal on switch.
3- connect the white wire " neutral " to the silver connection on switch.
4- connect the naked copper wire " ground " to the ground terminal on switch
5- Disconnect the two white wires in the junction box from each other.
6- Connect the ground to ground in j-box
7- Connect the black to one of the whites in j-box
8- connect the white to the other white in j-box
9- wire nut and tape all connections
Oh and be sure that you turn off the breaker before you start. Hope this helps. Good luck.
Posted on Jun 15, 2009
I have three wires, yellow, blue and red which operated a fan which I am replacing. The new fan has a small cable junction with three marking, L, N and T. Which wire to which letter is my problem. I
I'd be willing to bet the yellow wire is really white just discolored and if so the that would be N for neutral the white wire, blue has been for the fan light ( L ) on the ones I've done so that would leave the red and T.
Mar 02, 2014 | Hand Tools
I did not make a diagram when replacing the light switch
Red from switch goes to two blacks, blue from switch goes to two blacks and the black wire goes thru top of light and attaches to blue fan light wire. If you want a good fan, look for blade pitch(13 degree or higher)Or CFM's above 5500 on high.
Oct 02, 2013 | Hampton Bay 24002 Ceiling Fan
Wiring placement inside housing on ceiling fan
Is this a small fan around 120mm square, if so you need to ensure that the wiring is run in from the correct wiring inlet, there is usually a small spigot the wiring has to go round too, otherwise cover catches wiring. This is general on Xpelair, Vent Axia and GET fans.
If this doersnt help, let me know what the fan is, ie; model No
Feb 17, 2012 | Dryers
I understand that the black and blue wire can be connected to the black wire in my ceiling. ok fair enough. However, in my new bedroom, there is 2 switches on the wall that apparently control two black...
A ceiling fan requires a neutral wire (white), a ground wire (green), a hot wire for the fan (black), and on fans with light kits a hot wire for the lights (blue). These examples will assume that a lighting kit is going to be used, but if it is not terminations to the blue wire are not required and the circuit is greatly simplified The ceiling fan and light can also be wired through switches. When a single switch is used to connect to the ceiling fan and light the ceiling fan (black) and light (blue) would both be connected to the switched black wire. In this configuration turning the switch on would power both the light and ceiling fan. In order to turn just one off, the pull strings would have to be used. The problem with this approach, is that when the pull strings have been used to turn the light or ceiling fan off, turning the switch back on will not work until the pull string is pulled again .
The ceiling fan and light can also be wired through two switches. This would generally be two separate switches, one for the fan and one for the light. This would generally be a 3 conductor w/ground coming from the switch box. The ceiling fan (black) wire would connect to the switched black wire from the ceiling fan switch, the light wire (blue) would connect to the switched red wire from the light switch and the neutral (white) and ground (bare) would connect to the their associated wires..
Jul 07, 2011 | Heritage (5BFW52NK4KG) 52'' Ceiling Fan
I have a 3 way fan light switch but wires don't match the colors on my hamton bay fan what wires go where i have a black wire and a brown wire and a grey wire on the switch in the hamton bay i bought...
It takes 2 testers.
699b7e0.jpg regular tester
Continuity tester has battery and light bulb.
Use regular tester to find Hot wire that feeds old-switch.
Remove old-switch from fan
Strip back wires
Separate wires so they can be tested.
Turn on power.
Test each wire to bare copper wire -or- to green wire -or- to metal part of fan
One of the fan wires will light up tester.
This is the Hot wire.
Mark Hot wire.
Mark which color wire on old-switch went to the hot wire.
Use continuity tester on old-switch.
You know which wire is hot-on-old-switch
Pull chain and test hot-on-old-switch to both of the other wires.
When tester lights up, mark this wire.
Pull chain again and test hot-on-old-switch to both of the other wires.
At some point when you pull the chain, the tester will light up both the other wires.
This is the high speed.
Use continuity tester on new-switch.
Repeat the test for old-switch.
Identify which wire will be the Hot wire by process of elimination.
Mark this wire.
Identify high-speed wire.
Pull chain again, and tester lights up on medium speed.
Pull chain again, and tester lights up on low speed
Identify these wires and match pattern to the old-switch
If you need more help, add a comment, and I will answer
Oct 29, 2010 | Westinghouse Electric Ceiling Fan 3-way...
Need a replacement, where do I get one?
If I understand correctly you have a 3-speed fan.
And you need a 3-speed replacement pull-chain-type switch
Lowes carries 3 speed fan switches in the light fixture department.
These switches have multiple wires.
At any given time, there is one-and-only-one wire that connects to power from wall switch.
Lets call this the Power wire.
As you pull the chain, the power passes through the switch and goes to one-and-only-one of the other wires.
The other wires connect to windings in the motor.
The different motor windings control fan speed.
The key to replacing the switch is recording where each wire went before you disconnect old switch.
Once you know which of these wires is the Power wire, then you can test other wires with a continuity tester.
You also know the pull-chain sequence is OFF - HIGH - Medium - Low
Mark wires in fan and mark wires on old switch.
Pull out old switch.
Use regular electrical tester to find which wire in the fan is the power wire (separate wires, turn on power and test each wire to metal part of fan)
Now test the switch wires.
The switch is out of the fan.
You marked the wires so you know which wire is power wire.
Put the continuity tester on the power wire.
Test power wire to each of the other wires.
Click the switch and test to each of the other wires. Mark which wire lights up continuity tester.
Click the switch and test again. Mark which wire lights up continuity tester.
Click again, until each wire is marked in the sequence.
When you click the switch and no wire lights up, then that is the Switch OFF position.
Do the same test on the new pull-chain switch.
Connect the wires to match your testing.
Oct 25, 2010 | Westinghouse Electric Westinghouse...
In replacing a broken pull chain (no 3-way power here: simple pull-on/pull-off) on the 3-bulb light fixture of my fan/light combo ceiling appliance, I lost track of how to re-attach the two black wires...
I assume the switch operates the lights only. Besides the ground (green or bare) and the neutrals (4 white wires all connected together), the only wires of interest should be 4 wires (black) from the fixture and the 2 wires on your switch. Of the 4 black wires, one of them is the hot wire and the other 3 connect to the three bulbs. Connect the hot wire to either one of your switch leads and connect the other 3 wires to the other switch lead.
If you don't know which of the 4 black wires is hot you can find it by the process of elimination as follows---- connect any three of the black wires together (then supply power), if nothing lights, then the 4th wire is hot. Otherwise 2 bulbs should light. Remove one wire from this trio. If nothing lights, the wire you just removed is the hot wire. Otherwise, one bulb should light and one of these two remaining wires is the hot wire. Take one of those last two wires and connect it to one of the other bulbs. If it lights, then the wire you just moved is hot. Otherwise the one you left behind is hot. I hope this is helpful. Good luck. Be safe! Al K
Aug 03, 2010 | Westinghouse Electric Ceiling Fan 3-way...
Pull switch wiring
What you have is a switch for a ceiling fan/light combination.
Black wire from your light is power, White is Neutral (do not connect this to switch or dead short).
Apr 17, 2009 | Refrigerators
2-wire pull chain switch wiring in a ceiling fan light kit
If you removed a switch there should be two wires. Connect one of the wires to each of the switch wires or screws. good luck
Jan 21, 2009 | Solar 2-wire Pull Chain Light Switch For...
Dryers Logo
37 people viewed this question
Top Dryers Experts
