Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Kenmore 25376879506. Evaporator is freezing up causing poor cooling to the refrigerator.
I suspect a bad heating element but I need the specs for this system. What should the voltage be to the element and what should the resistance of the element be?
    President:
  • 2,468 Answers
Voltage=120vac,resistance= appx. 20-40 ohms as every defrost heating element has some different ohms, as long as its close to this youll be o.k. make sure to check the defrost terminator in series,and check it when its cold or it will read open,also,if the voltage isnt at 120vac on the element or shows low its because the terminator is open,and your showing a "ghost" voltage,also if no voltage anywhere in these areas it can be the defrost timer or A.D.C. thats bad
Posted on Feb 18, 2012
22yooper
  • 828 Answers
SOURCE: Kenmore 596.72913200 Refrigerator is Warm,and freezer is not freezing
If your evaporator is still frozen over after turning the screw twice you problem is in the heater circuit. Defrost heater could be open or the defrost thermostat.
Posted on Jun 08, 2008
22yooper
  • 828 Answers
SOURCE: Kenmore side by side
Unplug the wires from the motor and check the voltage differential cross the two wires. If you have 120 Volts or in that area the motor should run. Try moving the fan shaft up and down. If you have any play in this the motor bearing are bad. Replace the motor.
Posted on Jun 20, 2008
  • 958 Answers
SOURCE: Kenmore Refrigerator 596.72913200 refrigerator is cold and freezer is cold but nothing is frozen
hi lussed,
your problem is still poping up even though it was resolve already. i guessed you should rate a technician in this form as to delete the work from the list of jobs to do.. i am on the way to solve it but you had it solve with a real technician.
can you just rate me?...thanxs...
drcool299
Posted on Jun 25, 2008
  • 906 Answers
SOURCE: Kenmore 596.72913200 refrigerator cold, freezer cold but not freezing
good day,
hope this link below will solve your problem.
ref
Posted on Aug 03, 2010
heatman101
  • 43501 Answers
SOURCE: Kenmore refrigerator 106-54606300 that has
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Sep 20, 2011
Fridge is warm freezer is cold
Hello Abo Karin,
You are likely experiencing a DEFROST failure
(most commonly a defrost PCB failure)...
part number 67006740 item 5 on your exploded
case view (top center as viewed from the front).
There are typically only three (3) elements to a DEFROST
power control circuit:
- Defrost Printed Circuit Board ( PCB as noted above)
- Heater element to WARM the EVAPORATOR
- DEFROST thermostat... inhibit excess heat
(closed circuit at freezing - Opens at room temperature)
Check your defrost pan...
there should be water there DAILY...
IF not: you are assured that your DEFROST fails.
Per your DESCRIPTION...
You need to look for a SUDDEN REASON (huge air leak)
why FROST would form so quickly...
USUALLY a big pizza box... BUT ANYTHING blocking a
TIGHT DOOR SEAL will cause massive frosting.
It is taking moisture from the WARM ROOM AIR and blocking your evaporator...
a PROPERLY functioning defrost circuit would remove that frost
at least DAILY... and the EVAPORATOR fan would properly chill the refrigerated side blowing cold air from the FREEZER.
Yes ... all INTERIOR panels must be in place for the refrigerator to function properly.
Hope this helps
Your part... (see video instructions)
http://www.appliancepartspros.com/whirlpool-board-jazz-wpw10503278-ap6022400.html
Sears... (I don't USUALLY recommend for purchase)
http://www.searspartsdirect.com
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Refrigerator-Parts/Repair-Maintenance/Questions-Answers/location-of-defrost-timer-on-sears-fridg/Model-59665932402/0582/0161000/338616?modelNumber=59665932402
also see other .com retailers
partsselect,
PartSelect Appliance Parts and Repair Help
repairclinic
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Apr 19, 2017 | Kenmore Refrigerators
Refrigerator not cooling.
No the evaporator fan not running has nothing to do with the compressor. I would suspect that you are freezing up over the evaporator because the fan is not running and when it ices up the air can not flow through properly therefore causing the refrigerator side to get warmer. Replace the fan and you should be fine. Take the back panel inside the freezer off and see if you are all iced up. If you bare then I would replace the fan . You also said the defrost heater did not come on. That will also cause a freeze up. Possible replacement of the defrost heater may be needed. Good Luck!
Jul 25, 2015 | Amana Refrigerators
Kenmore side by side freezes up about every two weeks. I replaced thermostat and was told that I need a timer. What is a timer and is that what I need?
A DEFORST TIMER IS RESPONSIBLE FOR DEFROSTING THE EVAPORATOR .THIS PROCESS TAKES PLACE EVERY 7 TO 8 HOURS..THERE IS A HEATING ELEMENT THAT IS PLACED BESIDE THE EVAPORATOR THE DEFROST TIMER CAUSES THE HEATING ELEMENT TO BECOME RED HOT AND IT IS THIS HEAT THAT MELTS THE FROST IN THE FREEZER COMPARTMENT.
Oct 27, 2012 | Refrigerators
Freezer is very cold refrigerator is not cold as it should be
Check your temperature control (Thermostat) settings. If it is not on high/max cool then set it just less than the maximum. If it still does not cool then I am afraid the problem is of less cooling gas. You have to ask a technician to check and refill.
Feb 23, 2011 | Kenmore 74209 Top Freezer Refrigerator
My freezer is cooling but my refrigerator is not. Help!! Thank you.
The evaporator fan may be defective. Check and confirm that there is no ice building up in the freezer compartment. If there is , your defrost heating element and defrost thermostat may be bad. From the little details that you provided, I would recommend that you check and confirm the operation of the evaporator fan before checking anything else.
Dec 29, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
Are the coils in the freezer supposed to get frozen right away?
A heating element is usually a metal piece of hard steel that gets hot when 120v is applied to it. Some refrigerators use glass heating elements. Every 6 -8 hours the timer will go into defrost and melt any ice build up on the evaporator coil. Without the heating element the coil will freeze up and the cooling will not be sufficent.
Mar 24, 2010 | Maytag MSD2351HE Side by Side Refrigerator
Refrgerator is not cooling
Hi there
I have some stuff for you to read hope this helps you.
Cooling is poor For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas: Evaporator coils Condenser Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt. Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets. The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited. Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system: The defrost timer The defrost thermostat (also called the bi-metal switch) The defrost heater If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem Thank you for writing to fix ya.
Best Regards Richard
Dec 27, 2009 | Refrigerators
Blowing out air but not cooling or freezing /kenmore coldspot
see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts.
Jun 10, 2009 | Kenmore 60721 Refrigerator
Poor cooling in the refrigerator but the freezing is working fine.
unplug the refrigerator, remove the back panel inside the freezer, plug it back on, see if the freezer fan is working, if not replace it. if fan is working but there's a block of ice on the evaporator, replace the defrost timer located next to the thermostat, the defrost thermostat located on the evaporator and test the defrost heater element with a multi-meter.
Jun 07, 2009 | Frigidaire FRT17G4B Top Freezer...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
78 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
