Question about Mitsubishi WT-46809 46" Rear Projection Television
Color Gun Help?
How can i adjust/fix the color guns
on my Mitsubishi WT-46809?
  • 4 more comments
  • 7funnies Oct 26, 2008
    well we are having a weird problem with the conv. it is doing a 3d effect only in the
    corners of the tv though.. and we were told that it was with the color guns... does this sound right? any other advice? thanks.
  • jeffbrock190 Nov 09, 2008
    The convergence goes out on all four corners, and then a normal picture will come back. Sometimes it will stay out of convergence for several minutes longer. This problem only recently started within the the last 3-4 weeks.
  • j2bl4 Feb 10, 2009
    Same problem, but it is transient. Will go out of whack for a few seconds or minutes then return to normal. Can also get to return to normal after a sharp rap on the top of the cabinet. Seems like a weak connection somewhere.
  • jason May 11, 2010
    this may need a conversion or just some resistors replaced. can you test components or are you going to need a repair technician?
    does it have three color CRT's or is it lamp projected thru a block?
    what is it not doing?
  • 905 Answers
This tv will need some testing to determine the exact cause but most likely it will need a conversion done, you will need to call your local repair shop to come out and fix the problem
sorry about your tv
electech
Posted on Oct 26, 2008
No red color on screen
there are three basic color controlled by electronic circuit, in picture tube gun,one of them not working properly.needs detail analysis
Dec 04, 2011 | Mitsubishi WT-42311 42" Rear Projection...
The set has a bowed appearance and the 3 colors have seperated. I imagine the bulb(s) are going as it's a old set.
The arching of color can be adjusted on the color gun by slighty turning the screw on the gun Blue, Green, Red. This fixes the arching and or fade-blinking in and out of color. The gun on my 65" sony is inthe front of the set. Removing the front panel grants me access to this. You may have to access it from the back on your model. Looks like a small box with 3 screws ont he front. Hope that helps...
Jun 30, 2010 | Mitsubishi WS-55807 TV
My Tv has red light (color) out of focus..I've tried tuning the lance but it's not the problem in the lance..it's something else..don't know what..do you?
Your TV has three picture tubes which are aligned to properly converge the projected light beams on the screen. Each picture tube projects a single color of Blue Green or Red. During production your TV was carefully adjusted to properly align these colors. As a feature you have the ability to adjust these colors.thats called convergence.If you don't have a manual to show you how to adjust you can find one here http://www.mitsubishi-tv.com/support.html
Mar 03, 2010 | Mitsubishi WT-46809 46" Rear Projection...
I think the color bulbs are going out. I called
3D pic?Ur convergence it dead.U know how to solders?Tries these websites for convergence kit.Use replaced what in the convergence kit. Tv repair World.com,or Tvrepairkits.com.
Dec 14, 2009 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi problem
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
  • Screen looks 3D
    Colors don't line up
    One or more colors can't be adjusted when using the convergence menu.
    Screen is bowed or warped.
    No Audio / No Video
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 25, 2009 | Mitsubishi WT-46809 46" Rear Projection...
T.v
The first thing you need to do is to take away the color completely, then you adjust the hue until you get the picture looking like a black & white tv, like the old shows that were broadcast in black & white.
Then you can gradually add the color. And thats it your done!
Jul 19, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Blue Gun non-responsive
blue crt gun is dead... it has to be replaced. Check carefully the gun neck if theres a crack or damage, I'm suspecting  an overheating yoke ( a bunch of wires around or embracing the crt gun's neck), if theres a sign of overheating, you need to replace the yoke too, not doing it, your new gun will suffer the same fate of the old one, wasting your money.
Oct 29, 2007 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi WT-46809 46" Rear Projection Television Logo
120 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
