Question about Honeywell Programmable Thermostat Heater
Honeywell thermostat The fan on our upstairs AC/heating unit has been running now for several hours despite turning the AC/heat switch to the off position
  • melissa_slp Oct 26, 2008
    Thanks for the tip. It happened when it was in heat mode. I actually turned it to fan mode for awhile and then back to auto mode and the fan turned off. It was very warm here today so did not need AC or heat. I do not know what tstat to man means....sorry.
  • 359 Answers
Make sure not turned on @ tstat to man ,also were you in the heat or cool mode when this occured .
Posted on Oct 26, 2008
Have installed a new Honeywell thermostat. The fan does not turn off even when the room has reached the desired temperature. I originally replaced th ethermostat because the old one the fan ran forever and...
Most T-Stats have a On / Auto on a forced air system. On means the fan will run all the time even if it is not calling for heat. Auto only runs when calling for heat. Does the fan turn off in the auto mode at all? To test it...BE SURE THE FAN IS IN THE AUTO MODE ON THE T-STAT... Turn the thermostat all the way down and keep it there for appox 15 mins. If it is wired properly and the fan limit is set properly the fan should turn off. If it doesn't it is not the thermostat were the problem lies.
Most forced air units have a fan / high limit switch. There is a setting on the switch for the fan to turn on and a setting for the fan to turn off or it has a setting and a differental switch for it to turn off/on. Example - the fan comes on when the temp in the heat exchanger reaches 110 degrees F and will shut down at 95 degrees F after the thermostat is satified...this would hav a differental of 15 degrees F. It may be set to low and the fan continues to run long after all of the heat has been removed from the heat exchanger. This in turn will cause cool air to be coming out of the registers.
Mar 09, 2011 | Honeywell CT87B ROUND HEATING&COOLING...
I have a Rheem heat pump and a Honeywell thermostat. I let my air filters get too dirty, and they restricted the air flow so the system shut off. I have replaced the air filters but the upstairs doesn't...
You may need to replace the furances high limit switch. This is located abvove the burrners with the top frot door off. It has two wires going into it. The furance probably was cycling on this switch which automatically resets it self. The thermal dics wears out and starts to trip at lower temperatures. You can temporally jump across the switch and check the furances opreration but do not leave this switch jumperd because it is a safty.
Feb 06, 2011 | Honeywell Heating & Cooling
My thermostat when prgrammed and set on "auto" mode kicks on heat when temp drops below set temperature. The problem is that after warming up to that does not shut the fan off. ...
I have a honeywell TH8320U thermostat and American standard Air handler with heating unit put in. THE thermostat works fine with the ac and follows the programs I have set. However the heat is a different story. The thermo clicks on to follow program but the unit does not run. (auto settings) If I place the thermo in heat and turn it to on I get heat?
Dec 08, 2010 | Honeywell Programmable Thermostat Heater
New thermostat..have heat but not A/C help....
What are you setting the thermostat to when you turn on the AC , if you turn on the AC and the house is warm you will need to turn the AC down to a lower setting before the the AC will start up.
Mar 14, 2010 | Honeywell Electronic Programmable...
I have a blinking snowflake icon on my air conditioner, my air will not work. My heater will work fine but the air will not come on
When the snowflake is blinking the thermostat in in a delay mode designed to protect your compressor. If it does not stop blinking in 15min the stat is bad otherwise something is wrong with the AC
Sep 26, 2009 | Honeywell Electronic Programmable...
The thermostat turns the heating unit off and the fan continues
check your furnace filter to make sure the furnace is not over heating. what brand of furnace do you have and how old is it?Have you changed filter to a different kind last time you changed it?
Jan 16, 2009 | Honeywell Programmable Thermostat Heater
High Electrical bill - Appears to be heatpump problem.
Sound like there are running on emergency heat which is elrctric.Have the system checked out buy a local heating and cooling company. Have they checked the filter and changed them.
Jan 14, 2009 | Honeywell Electronic Programmable...
Need to know which terminals run what
Had similar problem, continuous fan, turn off power, then won't start up. Replaced thermostat, no change. The main controller board in the furnace went bad. What was weird was that it happened in the summer, while the heat was turned off. One day I noticed that the fan was running. The thermostat was in the off position, and I had to shut off power to the furnace to make it stop. I forgot about it till heating season came along and it wouldn't start up. The preliminary blower would start, the gas would click on, it would light, then quit. After tracing and checking the various safety switches, etc. it became apparrent the main board was bad. I found one on ebay, replaced it, [a simple job, unplug, a few screws, replug] and it's been working fine..good luck, John
Nov 07, 2008 | Honeywell Focus 6300B 5-2 Days...
Heating & Cooling Logo
426 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
