Question about RCA Scenium D40W20 40" Rear Projection HDTV
Rear input connectors
I just got this tv second hand and everything works great.....BUT, I cannot get the xbox 360 to work properly. I had all the cables plugged in, everything was working but when I switched the xbox from "TV" to "HDTV" on the back of the unit, the picture dissapeared.....???
  • jason May 11, 2010
    did you try switching it back and did it come back?
  • 116 Answers
Does it give you a "No Signal" on the screen, you may have to check the xbox and make sure you have it setup to output a HD signal. Let me knwo what you find.
Posted on Dec 11, 2008
I need some help hooking up an amp, tv, and xbox 360 together please! I have a Toshiba 46g310u TV and Xbox 360 already hooked up together using an HDMI cable. I just bought a Yamaha R-S300 amplifier,...
Many TVs have to have the optical output enabled in a set-up menu. Do you see red when the connector is disconnected (which doesn't necessarily mean that it is active, just that it is 'ON').
Have you checked the amplifier to insure that the input is working by connecting something else directly up to it? Can you test the TOSLINK converter by plugging the output into something else to determine where the problem lies. I still suspect it is in the menus of the TV.
Sep 10, 2013 | Toshiba 46G310U LCD TV
Red-white-yellow inputs don't work
what model of computer do you have, what video outputs do you have on your computer, if you have an s-video out on your computer, I would use that with the tv
Mar 02, 2013 | Mitsubishi WS-48311 48" Rear Projection...
How do i connect a xbox 360 to a philips hts 3555 and hd tv?
Connect audio out cables (L and R) from HDTV to far left audio input at back of hts 3555. Then connect HDMI output from XBOX360 to HDMI input slot on TV. Setup XBOX 360 for audio through HDMI turn TV off and then on and all should be good. It worked for me.
May 25, 2010 | Philips HTS-3555 System
I have audio but no video whyen a disc is
Turn off all devices in the video chain, INCLUDING your Xbox.
Unplug and re-plug ALL connectors, making certain that they all go in all the way.
Turn on everything.
If that does not fix it, then something is busted.
Remove anything between the TV and the Xbox and try it again.
If that does not work, either the TV or the Xbox is busted.
Try hooking up a DVD player to the SAME EXACT TV input.
If that works, your Xbox is busted, go buy a new one.
If that fails, go buy a new TV or try using another input on that TV.
Feb 07, 2010 | Microsoft Xbox 360 Console
No color on HD channel while playing xbox 360
this is sometimes due to an improper organization of the component jacks in the tv input. it doesnt sound like thats the case considering it was working before, but you might want to take a second look and make sure your colour coded component jacks are in their corresponding inputs.
Oct 05, 2009 | Bose Lifestyle 35 System
My xbox shows no picture but has sound
This might not help everybody but it might be a cheap fast solution to the "Xbox 360 no picture but sound ok" problem. I have old refurbished 360 that has had no problems at all. SInce I got it have used it with powerwave cooler attached to the back. This cooler has seperate Outputs for Vga, SVga, audio, component and av. Don't need the microsoft cable at all just standard cables. Always had it plugged in with VGA or SVGA cables and got great picture. I bought new 360 and put the old one in bedroom with old tv which only has av inputs. Got shocking picture that was unwatchable but sound was good. Tried all ways but no different. Seems the xbox plug has problems. If you get the powerwave cooler it splits the xbox output socket in to seperate outputs for everything so you can use it with Vga or Svga cables if your tv has those inputs and it should work fine. Only seems to be the standard AV outputs that have problems. Haven't tried the componet leads but I guess they might work as well. If you only have the old yellow, red and white AV inputs on your tv this wont help you but if you have the other types of inputs it might fix it. The powerwave cooler you should be able to buy for under $20 so it could be a cheap solution for this problem everyone seems to be getting lately. It works for me at least so get one and give it a try.
Jun 16, 2009 | Microsoft Xbox 360 Console
Plays dvds on xbox 360 fine, but no picture for games/dashboard
already solved it. thanks. i couldn't see the xbox settings blade because of the blank screen so switched my component cable to the tv setting instead of the hdtv setting, then i could see the dashboard in non-hd and switched the resolution to 720p while simultaneously switching the component cable back to the hdtv setting. that worked.
Jan 02, 2009 | Sharp Televison & Video
XBOX 360
Your tv could have a losse connection on the video input. Try moving it around to see if you get any picture. Either that or u need a new audio video cord for your console
Feb 15, 2008 | Microsoft Xbox 360 Console
RCA Scenium D40W20 40" Rear Projection HDTV Logo
61 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
