Question about RCA P56923BL 56" Rear Projection Television
Mistubishi Convergence/video display problem
My Mitsubishi has a convergence problem as well as video display issue. It powers up fine and shows inputs and channel display on screen. It also has sound. But not getting any diplay video from either inputs and anntena signal. Blue screen shows when you select other inputs such as DVD, DTV etc. Already replaced STK convergence ICS. I as other member was able to get tv signal and raster by removing GENE-CONVERG board. I even swapped GENE CONVERG board from no success. Also convergence is bowed at top and right. When attempting to select Advance Convergence to show ADvance screen Adjustment, It does not come on. When Attempting to adjust convergence it does not move on either ere or blue convergence. . Any assistance is greately appreciated. convergence is bowed at top and right .when attemting to reset convergence on screen menu it was gone on list menu.
  • RCA Master
  • 3,459 Answers
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix hereMistubishi Convergence/video display problem - bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Apr 18, 2010
2 Suggested Answers
SOURCE:
  • 905 Answers
SOURCE: Mistubishi Convergence/video display problem
also check resistor values on the chips and resolder the tuner as this can cause problems as they heat up , then replace any electrolitic capacitors in the video circuts selector ic
i will be back to see what you get
electech
Posted on Oct 26, 2008
Tv powers on, has sound but no picture. All three lights are working & will show the input display but distorted. I would like to do the repair myself but am not sure if this is a convergence issue or...
Even if a convergence problem exists you should still have a picture, a bad one but a picture----call the menu up with the Mitsubishi remote and select convergence and then advanced---a grid of lines will appear in green---got dramatic red and blue showing and you have a convergence issue.
Do that first----presuming no hookup is ok (try a dvd player) the set does have the OPTION menu(can tell you how to get there) that is based on a 4 digit number code--may have that for this model or not).
It will not correct any convergence problems but will do a hard reset of the set back to factory original.
Let me know what you find---it sounds like 2 problems exist.
Nov 07, 2012 | Mitsubishi WS-65905 65" Rear Projection...
Intermittant white faded picture
Since it is intermittent it will likely be hard to find but here is some general information and ideas since I have worked on hundreds of the Mitsubishi sets.
If the issue was with just one of the 3 tubes the screen color (background) would change--so not that.
These sets are prone to Glycol issues (coolant leaking from the tubes) but since once that happens it does not take time or even come back that is not the issue.
This set has 3 hidden menus--
One: advanced Convergence adjustments that can be saved.
Two: Adjustment menu(keep out of that one!)
Three: Option Menu
That menu allows a hard reset of the entire set that sets all settings back to factory.
The convergence is not affected and it has been known to cure all sorts of odd issues like no sound, inputs not working, odd brightness and video issues, and others.
If you have labeled video inputs from 1 to DVD etc those will be removed, set will come on in air band on channel 3 so will if using cable have to switch back to it and auto program channels etc.
It essentially puts the set back to the condition setting wise that it was when new in the box.
The only reason I suspect this could help is if the set has developed some kind of processor glitch it will reset that also.
No harm can be done to try it---it requires the Mitsubishi remote and a four digit number code.
If interested I will give you a link to the full manual (free to download) and the page number with instructions for the OPTION menu entry and reset.
SD TECH
Apr 21, 2012 | Mitsubishi WS-65809 65" Rear Projection...
Certain cameras are showing the same video.
First you need to isolate the problem. Step one - make sure the video from the cameras is correct - use a monitor and check each input separate. If the video is correct, use one camera and start from input one on the DVR and check all inputs - in other words plug your camera in input 1, check for video to make sure is correct and shows up in the right place, than go to input 2. This way you check your DVR cards. If the video shows up, but in the wrong place - check the settings on the DVR - you might be able to change the physical input in the viewer.Or you might have a bad DVR.......do a search for DVR Doctors in Google - in case you need repair.
Jan 27, 2012 | Avermedia AVerDiGi SA6832E RACK 32-Channel...
Mitsubishi ws 65819
Ur power board ic converter it dead.
Ur Convergence board is bad going to die to.
Both must change.
Aug 15, 2009 | Mitsubishi WS-65819 TV
electech
Oct 26, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WD-52628 52" Inputs look like old cable scrambled channels
Change the 1000uf @16v capacitors on the FMT board that should solve your problem. You will most likely found that they have swelled. Let me know if you need further info.
Apr 04, 2008 | Mitsubishi WD-52628 52" Projection HDTV
Mitsubishi tv
I found this online somewhere and it cleared my problem.
(my problem was a blue screen that said my input was locked enter in your code using the 10 key pad. Both inputs were locked, I used the steps below and it cleared it. We are now watching a dvd for the first time in months!) Thank you Bob Waterman whoever you are!)
MITSUBISHI CS3114R
Parental Lock
This system can lock each channel or different channels on ANT A and ANT B
as well as locking each of the EXT inputs, so you should confirm what is
locked before trying to unlock.
1 On the remote, set the TV/VCR switch to the TV position
Or . Depending on which remote is being used
Press the TV mode button at the top.
2. Turn on the TV and using the SCAN buttons (or 10 KEY FAD) and the INPUT
buttons check each channel and input to establish which channels and inputs
are locked. The screen will tell you if the channel or input is locked.
3. Press the button labeled MENU. The screen will show the main TV menu.
4. Press the #5 button (channel lock option).
The screen will change to show the channel lock System Menu. This screen
will indicate that the lock system is either ON or OFF.
IF THE SCREEN INDICATES LOCK IS ON, GO TO STEP 5
OR:
IF THE SCREEN INDICATES THE LOCK IS OFF, GO TO STEP 5A
5. Press the #3 button. (SELECT CHANNELS TO LOCK option). The screen will
ask for the code number. Press the #9 and QV buttons at the same time.
Notes: The screen will change to show an information display that will show
the selected antenna and channel or input. The display is superimposed over
the picture. This display will indicate that the channel or input is either
locked or unlocked. In the lower middle will be instructions to use the
10-key pad or SCAN buttons to select the desired channels (or the INPUT
button to change antennas or select the EXT inputs). At the bottom of the
screen will be instructions on how to change the current LOCK status (if
unlocked use the ENTER button to lock, or if locked use the CANCEL button to
unlock).
NOW GO TO STEP #6.
5a. Press the #1 button (channel lock ON option). The screen will ask for a
code number. Use the 10-KEY PAD to enter a new code number (We suggest 1111)
and then press the ENTER button.
unlock).
NOW GO TO STEP #6.
6. Use the 10 KEY PAD or SCAN buttons to select the channels that are
locked, or, use the INPUT button to select the external inputs that are
locked.
7. At each locked channel or input press the CANCEL button.
The screen will indicate that the channel or input is either locked or
unlocked.
8. When all of the channels and/or inputs are unlocked, press the MENU
button again. TV main menu will be displayed.
9. Press the #5 button (CHANNEL LOCK option).
10. Press the #2 button (channel lock OFF option). The screen will now ask
for a code number again.
11. Press the #9 and QV buttons at the same time. The screen will return
to the CHANNEL LOCK MENU and indicate that the lock is OFF
12. Press the MENU button twice to return to normal viewing.
The parental lock is now entirely cancelled.
Bob Waterman, CET® #RI-28
Master Technician License #9109
Service Manager / Parts Manager
Gemini Computer, TV, & Security Alarms
(508)695-7302
(508)695-7769 FAX
geminitv@xxxxxxxxxxxxxxxx
geminitv@xxxxxxx
www.geminicomputertvsecurityalarms.com
Nov 18, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi tv
Without the code, you must get an original remote and press the "QV" and the "9" buttons together to unlock the TV.
Oct 16, 2007 | Televison & Video
Mitsubishi CS-27405 no picture but sound
your problem is the PIP board,tough to repair,can be taken out and replaced with two 10 mfd caps 50v bipolar from pin5 to 11 and from pin 7 to 9
Sep 27, 2006 | Mitsubishi CS-27405 TV
Televison & Video Logo
1,651 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
