Question about Korg KAOSSILATOR PRO SYNTHESIZER
Adjust recorded volume - Korg KAOSSILATOR PRO SYNTHESIZER
  • Yoga Raditya
    Yoga Raditya Feb 17, 2012
    if i adjusting the volume on one bank using the shift & hold bank button and the others will follow the same volume,, is there someting wrong with the settings? or utility settings?
After i record and play the cd on another player i have turn volume up
You probably need to adjust your recording volume on the recorder and not just copy the source as it is...
Mar 21, 2014 | Tascam Cd-rw900sl Cd Recorder/player
Is there supposed to be a special driver for this Labtech microphone? I am running XP and have all the volume controls active but it is not recording.
In addition to the instructions below you may need to make sure you have selected the right sound source (normally WAVE) in your recording program
Using a microphone with computer
To use any microphone with your computer you will need to enable it in control panel. The following instructions are for Windows XP but are broadly similar for Vista and Win7
Click START, CONTROL PANEL, SOUNDS & AUDIO DEVICES
Click VOICE
In Sounds & Audio Devices Properties window locate SOUND PLAYBACK box. Click the VOLUME button. Make sure that there is not a check-mark in the MUTE box against microphone in the list of devices and that the volume slider is at the top of the scale.
Make sure the MUTE ALL box isn't checked before closing the window.
Now click the VOLUME button in the SOUND RECORDING BOX. Here SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls).
NOTE if your microphone is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK. Same applies for Internal mic.
That should be it.
To adjust audio volume generally.
Under VOLUME tab adjust Device Volume as necessary. Also (under Loudpeaker Settings) click Speaker Volume and adjust slider to suit.
You might put a check mark in the box to show the volume control on the Task Bar so you can go straight to it to make adjustments in the future.
Feb 25, 2011 | Labtec Microphone Microphone
DOES NOT RECORD ANYTHING ON MY WINDOWS XP
Probably need to enable in control panel as per instructions below.
You may also need to check you have correct input device (wave) selected in your recording software
Click VOICE
That should be it.
Feb 24, 2011 | CAD Microphones GXL2200 Professional...
I recently recieved a Bush Noise Cancelling Desktop Microphone M-013NC , i've plugged it into the back of the computer and turned all microphone volume settings upto full, but when i try using the sound...
There are two separate settings in control panel for record and playback. It appears you have playback enabled but not recording - see below
Click VOICE
That should be it.
Feb 21, 2011 | Audio Players & Recorders
New microphone will not record...please advise.
There are two separate settings in control panel for record and playback - see below
Click VOICE
That should be it.
Feb 20, 2011 | Dynex Voice-Certified PC Desktop...
I installed my interface, but my recording software still isn't picking up sound from my mic
You may need to enable the microphone in control panel - see below
You will also need to check the correct sound source is selected in your recording program.
Click VOICE
That should be it.
Feb 18, 2011 | AKG Perception 220 Professional Microphone
How do i adjust the video record volume on my canon powershot sd600 digital elph"
I don't think you can. I have six different canon powershot cameras and none of them have any way to adjust the record volume. However you can adjust the payback volume, go to menu>tools>volume.
Jan 01, 2011 | Cameras
How do you set sound and volume on movie mode on model sp-560uz
Page 33 of your user manual explains how to turn on the microphone to make sure that sound is recorded when taking movie clips. You cannot adjust the recording volume. Page 35 discusses how to adjust the volume during movie playback only.
Nov 07, 2008 | Olympus Cameras
Volume loss after VCR recording
Try adjusting tracking to detent Sounds like audio heads are miss aligned . Does your unit have audio levels if so turn them up when recording. Try adjusting tracking or try patching recording unit to the tv .If it has L/R video inputs use the same deck you recorded on for playback. .
Oct 24, 2017 | Toshiba 24 24 in. TV/VCR/DVD Combo
Korg KAOSSILATOR PRO SYNTHESIZER Logo
49 people viewed this question
Top Korg Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Dennis Gutowski
Dennis Gutowski
Hardware and...
Are you a Korg Computer and Internet Expert? Answer questions, earn points and help others
