Question about Canon EOS-1Ds Digital Camera
Problem with Flash
I have been using the Canon 580EX flash and for some reason it would not work on my Canon Eos-1DS. It works on my Canon 20D just fine. I haven't used my 1DS for a while. Any suggestions?
Friend here in UK had the same problem and fix it by doing this.
  1. Remove the flash from camera.
  2. Have the firmware updated of camera,can be downloaded from Canon website,using the camera's serial number to activate the download.
  3. Extraxt the downloaded software on CF Card via card reader.
  4. Do firmware update on Canon via Meu settings.
  5. Make sure you have the battery fully charged
  1. Reset all custom functions,
  2. Switch it off and remove the battery.
    Wait five to ten minutes and put the battery back.
  3. Switch on take picture.
  4. Put flash on and take picture.It might work now.
  5. Do you custom functions and see if it's working.
  6. If not take bothto a dealer or Canon repair shop.
Henning
Posted on Aug 29, 2008
Canon Speedlite 580ex ii - won't work with camera
Caroline, you should try to set the camera on "M" and the flash in 2nd curtain flash sync.
Or set flash in ATG wireless IR ETTL Slave modes and pop-up the flash on Canon EOS-70D.
Truly,
atdlee@netzero.com
Feb 08, 2014 | Canon SPEEDLITE 580EX TTL Flash
My 580EX clicks when I turn it on... the Wide Angle shield is totally in. Plus it is set on ETTL but the Zoom - - mm and the rectangle box is flashing... it will not respond to any buttons pushed or the...
Jack, place the flash on the camera.
Then do the following:
1. Load up Canon EOS Utility software
2. Connect camera with USB Cable to computer
3. Turn on camera
4. Click on EOS Utility
5. Click on flash setting
More help send to my email.
atdlee@netzero,com
Jan 17, 2014 | Canon SPEEDLITE 580EX TTL Flash
Canon 550 ex speedlight - flashes okay. Won't sink with 60d (tried different cameras at dealer - same problem) Camera is okay .
Bruce,
Try these steps:
1. Set camera to manual2. Set shutter to 1/60
3. Set aperture to F5.6
4. ASA/ISO 200
5. 550EX on hotshoe
6. Do not set on slave or master
7. Turn on flash
Display must shows, ETTL.
If that doesn't work, you have to use the flash on manual.
Some of this model will not work fully on ATG Canon EOS-1D C, ATG Canon EOS-1D X IR, Canon EOS-1D X/60D/T4i because this flash is over 20 years old.
Unless you would want it to be modified by me.
But that can be costly when you can get the 580EX II for less than $425.00 USD.
atdlee@netzero.com
Jan 01, 2013 | Canon Speedlite 550EX TTL Flash
Canon 580EX II Flash is not firing??
It could be the bad bulb. You need to replace the entire bulb assembly. Canon Speedlite 580EX II MYK Camera Camcorder Repair
Apr 22, 2017 | Canon Cameras
How to use it?
Congrats on your flash purchase. To pruchase a copy of the instructions manual, I would suggest the infamous ebay. There is currently a copy available by this seller: http://cgi.ebay.com/Canon-Speedlite-540EZ-Instruction-Manual-Orig_W0QQitemZ220318470163QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item334c011013#ht_818wt_1166
Alternatively, check out this mir site for information regarding the buttons and capabilities: http://www.mir.com.my/rb/photography/hardwares/classics/eos/EOS-1n/Flash/Canon_540EZ/index.htm
Hope this helps.
Andrew
Apr 16, 2010 | Canon SPEEDLITE 580EX TTL Flash
I have a canon rebel camera,i also have a canon 20d. I am using the 580ex 2 flash but is not getting the correct result,lot of underexposures in doors.What settins should I be using on the camera and...
I had the same problem with a 400d and 580exmkii however the problem seemed to disapear when i used a white plastic flash defuiser over the unit.(available from stores or ebay) also note this model produces a lot of underexposure and some brand of batt heat up very quickly. For indoor set to camera to manual and flash to ettl. Best of luck.
Aug 11, 2009 | Canon Speedlite 580EX II TTL Flash
I have used the Canon Creative 3 program for quite some time, but now have Windows vista and it won't load. Can it be updated for that operating system/
Canon Vista compatible software now available ...with added support for some cameras, but not older ones. Go here: http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct and navigate to your camera model and select "Drivers/Software" link. RAW Codec for Vista and updates to Zoombrowzer and DPP are available for the following: EOS-1Ds Mark II, EOS-1D Mark III, EOS-1D Mark II N, EOS-1D Mark II, EOS 5D, EOS 30D, EOS 20D, EOS 400D DIGITAL, EOS DIGITAL REBEL XTi, EOS Kiss Digital X, EOS 350D DIGITAL, EOS DIGITAL REBEL XT, EOS Kiss Digital N
May 04, 2008 | Computers & Internet
Won't Work As Slave With Canon EOS 400D
Speedlites with the suffix "EZ" are never compatible with the digital EOS line-up. All models that do work are named "EX" (420, 430, 550, 580EX et al.)
Apr 03, 2008 | Canon Speedlite 540EZ TTL Flash
Canon SPEEDLITE 580EX TTL Flash Problem: Flash will not stay in ETTL mode
u can use the H sync button only with the camera set in semiautomatic or manual modes, it dosent work in AUTOmatic modes
Oct 23, 2007 | Canon SPEEDLITE 580EX TTL Flash
Flash stopped workin as master in wireless mode?
Hi Joelgue,
Now, go to a real camera store and bring your equipments with you.
Say to them:
I have a Canon 580EX Flash and wanted to know if you have the Quantum Turbo Battery with the Adapter Cord for my 580EX?
Ask to see if you can test them out.
This adapter does not go into the 4AA battery hold but to the flip out cover, AC Adapter. You need to plug it into the flash.
Press "On" from the Q battery, then set flash to "Master" on camera and other EX to "Slave".
Turn all three on(1st flash, 2nd flash and camera.
Do not press shutter button but press the pre-flash(pre-auto lock/flash) on camera body. On the EOS-1Ds Mark III has "*".
Both flashes should come on.
Now, press the camera shutter using "ETTL Modes" and look at the image from the LCD screen...is exposure correct?
Address to this address from now, please: atdlee@netzero.com
PS: You did set both flashes into same channel and with no exposure adjustment, right?
May 25, 2007 | Canon SPEEDLITE 580EX TTL Flash
Canon EOS-1Ds Digital Camera Logo
112 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
