Question about Philips Office Equipment & Supplies
PHILIPS magic 3 with PFF 553 invalid card - Philips Office Equipment & Supplies
USER MANUAL FOR MAGIC CHEF TOASTER OVEN TB12-2 670NEEDED PLEASE
I couldn't find your manual on Magic Chef's site - are you sure you copied the number correctly?
This one is Magic Chef
https://www.homedepot.com/catalog/pdfimages/d0/d05d469c-4da9-4599-8169-eb36b34df629.pdf
Magic Chef Customer Service will probably be able to help you and can be reached:
Customer Service: 800.688.1120
Canadian Customers: 866.587.2002 Magic Chef Customer Service
553 Benson Road
Benton Harbor, MI 49022
Is it like this one? Many are made by the same factory and are badged to the seller.
http://useandcares.hamiltonbeach.com/files/840148700.pdf
Dec 14, 2017 | Magic Chef Ovens
Tip
Hidden service menu
some faxes, such as Philips primo / magic 3 have hidden service menus.<br /><br />There in menu 97 submenu CARD TEST 1 you can turn off the plug-n-print card such as PFA331. now you can spool back the inkfilm for reuse and sell your unspent chip card at ebay.
on May 11, 2011 | Philips PPF-531 Plain Paper Thermal...
Tip
Disable chipcard check and print forever
to do it, press and hold START 4 sec.
press STOP/START 3x over
enter MENU 97 , scroll (arrow right) to CARD TEST 1
enter 0 (zero) to turn it off.
press OK.
PHILIPS magic 3 with PFA331 inkfilm plug'n print
Mine come up with replace ink film when I do this how can I get past?
May 10, 2011 | Philips Office Equipment & Supplies
I want to stop my philips magic 5 "replace inkflim from flashing. I'm not able to access my messages or send faxes. I dont have a replacement inkfilm. Thanks
the fax hackers are still researching the method to disable plug-n-print chipcard in magic 5 series. magic 3 series has been solved in hidden service menu.
This means you need to buy a new inkfilm with new chipcard included. sorry.
Apr 04, 2011 | Philips PPF-531 Plain Paper Thermal...
I have a Magic Chef refrigerator. Model# CTN1511GEW Serial# 10381240ZB, It wont stay running. The freezer is staying cold but the bottom part is not. Been about 3 days not working properly. I can turn it...
your rtc overload contactor on the units compressor body is making that snap noise,you need a new overload,remove the spring wire that holds it to the compressor,unplug the rtc overload and capacitor and get a new one and reverse procedure to in stall
Jan 16, 2010 | Refrigerators
I need a manual to know how to use my older Magic Chef toaster oven. It bakes, boils, and toast. Model # EH 10200A (628)
553 Benson Road
Oct 09, 2009 | Magic Chef Toaster Ovens
Philips magic 5 classic
it comes without a card and only enough roll to "get you started" when you buy a new roll it has a new card with it
Jul 31, 2009 | Philips Magic3Voice PPF585 Printer
The handle on my daewoo microwve over the range model#KOT-210UW broke off and was looking for a new one - can you help - Its about 14 years old?
I would contact either Magic Chef or Daewoo for a new part, if it is still available after so long.
I would try these numbers, plus any they might recommend:
Daewoo
877-393-2725
800-553-4355
800-323-9668
Magic Chef
888-775-0202
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 19, 2008 | Microwave Ovens
73 people viewed this question
Top Philips Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
