Question about Venta Airwasher VS 207 3.7 Gallon Humidifier
My Venta vaporizer won't start and keeps on blinking
4 Suggested Answers
SOURCE: Venta Airwasher Display Light Blinking...
This has happened to me. Check the contact points in the base of the machine. Ours had some corrosion on them. I took an emery board and filed the corrosion off to clean the contact points.
Posted on Feb 03, 2009
walesarumi
  • 6993 Answers
SOURCE: Venta-sonic VS207.... starting after summer
First, make sure the humidistat isn't set too high by adjusting it to the lowest humidity setting and running it again.
Next, test the dehumidifier by placing it in a closed bathroom with a hot shower running. If you don't see water collecting/no vapor in the unit after several minutes, turn the unit off and clean all dehumidifier filters and coils.
If, after adjusting the settings and cleaning the unit, you still don't see no vapor/water collecting, you may have a refrigeration issue. This situation will have to be addressed by a qualified technician.
Good luck.
Posted on Oct 20, 2010
  • 182 Answers
SOURCE: the Venta Sonic stops working,,,,it just keeps
here is the manual that may lead you to the solution..
http://www.appliancefactoryparts.com/content/pdfs/123737.pdf
Posted on Feb 19, 2011
Steam vaporizer kaz, emites a black particules, in the tank like sort of blak ink when finish using it, is there any problem with that???
This is considered normal. It's the residue left from the water vaporizing into steam. Since it's left behind in the chamber, you do not breathe it in. Other users have said that it helps keeping these minerals in the chamber and just adding water to mineralize the water in lieu of adding salt.
Oct 05, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
How do you fill the venta humidifier I don't have
http://www.appliancefactoryparts.com/content/pdfs/123738.pdf
Fill Water Tank.
Turn off humidifier and unplug the power cord from A/C outlet. Remove tank from
base. Turn upside down and unscrew filling cap. Fill tank with clean, cool, distilled,
filtered, or tap water. Do not attempt to fill unit through Vapor Nozzle. Water temperature
should NEVER be too hot or too cold. Extreme temperatures can damage the
unit. Tighten filling cap firmly. Return tank to base and let it sit for a few minutes. For
first time use or when replacing the demineralization cartridge filter, please soak the
filter in warm water for several minutes.
Dec 24, 2010 | Venta Airwasher VS 207 3.7 Gallon...
Venta 205 no mist
Throw the unit out - it's garbage
Nov 10, 2009 | Venta Airwasher VS 207 3.7 Gallon...
Venta-sonic VS 207 humidifier. Turns on but the display just flashes lights. I had it stored all summer (followed the manual instructions) and it's the first time I'm turning it on.
I had the same problem. During the cleaning process, the white float was installed upside down and humidifier water level sensor was unable to read the float. I removed the phillips screw and inverted the float with the dark ring toward the bottm. Quick fix.
Nov 08, 2009 | Venta Airwasher VS 207 3.7 Gallon...
I have a Venta Airwasher LW24 and need a new Gear & Mounting Ring
I have been contacted by A&B Distribution abdistrsupport@gmail .com They have been outsourced by Venta to handle tech support and sales for individual direct customers. The representative I spoke to was extremely knowledgable in the product and very friendly. This is refreshing in this age. He was able to fix my clicking noise by replacing the gear that was under warranty and at the same time suppling me with the additives that I can no longer get from my local Bed Bath and Beyond store.
I am very happy with my investment.
Dr Malcome Pepper.
Jun 04, 2009 | Venta - Airwasher LW24 Humidifier
Jan 30, 2009 | Venta Airwasher VS370 2 Gallon Humidifier
Can't find the manual online VS207
I have tried looking for a manual for you but I could not find anything after a long search, however here are the contact details for venta, they should be able to send you a manual/guide
Main support number1-888-333-8218
Email supportsales@venta-airwasher.com I hope this helps
Jan 07, 2009 | Venta VS 100 Humidifier
Venta 207 digital humidifier
Caring For Your Venta-Sonic Humidifier
IMPORTANT!
Always unplug the unit before cleaning!
When to Clean Your Humidifier
 Clean your humidifier weekly or more often during heavy use, depending on your
individual water quality. Clean your humidifier before storing and after long periods
of storage.
 When cleaning the inside of your unit, keep water away from the air outlet. Exterior
may be wiped with a damp cloth when unit is off and unplugged.
Cleaning the Oscillator and Water Sensor
 Turn off the unit and unplug power cord. Remove tank from base and empty
reservoir in base. Use cleaning brush provided in base to clean off mineral deposits
and sediment from oscillator and water sensor. Do not scrape or clean with tools
that have metal parts. Be careful to not damage the surface of the oscillator.
ATTENTION: Damage to the oscillator may cause the unit to not work properly.
 The oscillator (ultrasonic transducer) is highly sensitive. Keep this important part
clean and treat gently. Do not touch the oscillator while the unit is operating.
 Do not use soap, cleaning agents, detergents, or other chemicals for cleaning the
tank and humidifier.
 After cleaning fill water tank (see instructions above) and return tank to base.
Storing the Venta-Sonic
Switch off and unplug power cord from A/C outlet. Empty remaining water from base
and tank. Clean tank and unit (see for instructions above). Make sure all parts are
thoroughly dry—allow at least 24 hours to dry. Leave the filling cap of the tank
loosened. This will keep the cap and gasket from sticking together. Pack Venta-Sonic
in original packaging and store in a cool and dry place.
You can find your manual at this link:
http://www.venta-sonic.com/pdf/vs207manual.pdf
Good Luck.
Apr 03, 2008 | Venta VS 100 Humidifier
Venta Airwasher VS 207 3.7 Gallon Humidifier Logo
299 people viewed this question
Top Venta Humidifiers Experts
Mack Baxter
Dennis
Are you a Venta Humidifier Expert? Answer questions, earn points and help others
