Question about JVC Televison & Video
JVC NV-50D502 turns off, won't turn on sporadically - even when cool
Shuts off by itself. Will be able to turn on again-- later, but usually not right away. Even when not on for a long time
Arpi
  • 326 Answers
SOURCE: TV will not stay on?
Hello, Hopefully We can help you determine if your lamp has failed. The Most obvious way to determine if you need a lamp is to do a Visual Check of your Lamp. Most of the time the Lamp will have blown and the filament burned. It will also usually be fogged up badly. Sometimes though the lamp will fail and look fine. Hence the blink code test. Todays Televisions Incorporate Blink Codes to be Used by both the Customers and Sevice Technicians. These Codes vary from Brand to Brand. We have compiled a list of these Blink codes in hopes that it will help you determine if Indeed you need a lamp. We say Blink Codes because when there is a failure within most televisions the Front LED Lights will Blink in some form of pattern. It maybe just your lamp light or it could be All of your lights. http://www.alltvlamps.com/samsungtest.htm
Posted on Apr 23, 2007
  • 22 Answers
SOURCE: TV Turns off and on
How long since the last time the bulb was replaced? It sounds like the bulb is overheating and triggering a safety shutdown.
It's probably in need of nothing more than a good cleaning (open it up, clean off the boards with a can of air) and *may* be time to replace the bulb.
Posted on Nov 13, 2007
  • 1153 Answers
SOURCE: Mitsubishi VS-50707 shuts down sporadically
you can do a self-diagnosis test by pressing the menu and input/device button on set for 5 sec and see what error code it gives you. Count the blinks followed by a short pause then more blinks. This is the error code.
Posted on Mar 10, 2008
what if the pic doesnt stay on long enough to run the test? Mine doesn't stay on more then 15 seconds before it powers off. This happens everytime now.
HELP and THANKS
Posted on Apr 07, 2008
SOURCE: When turn tv on, it shuts off and power light
I have the same power issue (3 blinks) that you provided a solution for. You mention you have step by step proicedures. How can I get them?
Brian
bcecil@bellsouth.net
Posted on Jan 17, 2010
Computer shuts down
Make sure Windows Update is turned on. For Windows 7, Vista, and Windows 8 there are Updates that resolve some hardware glitches such as the one you are experiencing.
Apr 03, 2014 | Dell (6F858) Cooling Fan
My 1997 Subaru Impreza won't turn over.
here is a trick ...jump it off and unhook + batt cable if car shuts off alternator if stays on replace batt
Aug 16, 2012 | 2002 Subaru Legacy
Our tv won't turn on light blinks a couple minuate and then turns read again and lamp light flashes red
A possible bad lamp if not replaced recently or removed and at least examined. What is model number and what have you tried so far?
Apr 19, 2012 | Sony Televison & Video
When i turn it on it shuts off 3 seconds later, what do i do?
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on; or it may turn on but produce no audio to the speakers.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Sep 16, 2011 | JVC RX-9010V Receiver
The air conditioner cools the room but it shuts of. The power light doesn't come on while unit is on. Can I replace the plug?
"The air conditioner cools the room but it shuts of." -- Temperature reached, but does not turn back on automatically? Stops short of reaching temperature? Shuts off for a period, but will come back on only to shut off again later?
Most importantly, how do you get it to turn on again?
"The power light doesn't come on while unit is on." -- If the unit is on and the power light is not, then the power light must not be operating (is burnt out).
Actual answer: "Can I replace the plug?" -- Of course you can.
What is causing you to feel that the plug needs replaced?
:o).
Jun 04, 2011 | Daewoo DWC-056CL Air Conditioner
I have a tape which I'm anxious to play to convert to a CD, but it just won't play ! It will fast wind both ways but on play just shuts off. (It hasn't been played for a long time) It does...
If you wind the tape by hand (with a pencil or screw driver etc.)is the tape easy to turn or move from one end to the other with out any binds? If not It may be wound unevenly, smacking it down on a flat surface a few times on each side will usually free it up. Hope this helps.
May 17, 2011 | Audio Players & Recorders
I have a Jvc Rx-6040b Receiver this morning i tuned it on i got no display 3or 4 seconds later it shuts off so i unplug it for awhile.Then later today i tried it again and the same thing happened.. anyone...
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
May 08, 2011 | JVC RX-6040 Receiver
CD player shuts itself off as soon as you turn it on
I had the same problem. The F1001 fuse was blown, it is a 1.6 amp, 125 volt fuse, GMA type.
Dec 09, 2007 | JVC FS-S57 CD Shelf System
Televison & Video Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
