Question about IBM "Portable (22P7196) 40 GB Hard Drive
New harddrive not working
Just bought it from reliable looking company off ebay plug in, light turns green. initially recognised by windows, then says problem during installation. cannot locate drive in my computer, disk management or device manager help please
  • 432 Answers
The drive probably needs to be formatted.
Posted on Jul 02, 2007
Sumvision egem external hdd
more often hardware compatibility issue, try using different usb cable first,
Mar 18, 2014 | Apple Computers & Internet
Boot device not found
1) BIOS Setup states no harddrive found? Remove all power. AC adapter (Charger), and Battery. Remove Harddrive. Press Power On button in, hold in for 10 seconds, let go. Do this procedure 2 more times.
Reinstall Harddrive, and then Battery. Hook AC adapter again.
Harddrive recognized now?
You press the Power On button. This in turn presses against the Power On switch. The power is initialized. First chipset to receive power is the BIOS chipset. The Basic Input/Output System program is initialized. BIOS LOOKS TO SEE WHAT DEVICES ARE INSTALLED, does a Ram Memory count, and hands the computer over to the Operating System.
This is what I am basing the above on.
2) Not to knock sellers on Ebay, as I have found a few that are decent.
However the motherboard could be bad.
Harddrive controller could be bad.
Southbridge chip of motherboard chipset,
(CPU = Processor),
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
3) Don't E-slap me, but you were wearing an ESD wrist strap, with it's alligator clip attached to a good ground source; when replacing the motherboard, correct?
Please post back in a Comment.
Regards,
joecoolvette
Mar 15, 2013 | Computers & Internet
My laptop does not recognise my external harddrive
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.
Then restart computer then check.
Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4
if still no luck
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Apr 26, 2012 | Seagate FreeAgent Pro 1TB External USB...
Rocstor external harddrive disappears from desktop. Why?
hope this helps
Mar 05, 2012 | Rocstor Storage Rocstor Rocpro 225 500 GB...
Western Digital Harddrives // Win Vista two separate harddrives with same problem - once plugged in, lights on harddrives turn on, computer beeps but, doesnt recognize the hard drive. WinVista...
Uninstall the WD drivers, then, leaving the WD drives attached to the computer, reboot the computer.
Here is something else to try: Driver Booster by Iobit.
11 Free Programs That Will Help Update Drivers in Windows
And take a look at the software for your drives at the Western Digital site.
Aug 10, 2017 | Olympus Computers & Internet
I have to reload all drives etc but harddrive dont work i have bought a external harddrive but unable to get this to work as pc is not recognising it how do i get my recovery disc to work
remove harddrive from computer make it external by casing it then keep for scanning, if any virus found then remove it.place the **** to pc then install window XP again, then it will detect
Jun 18, 2009 | Computers & Internet
I have a dell inspiron 5000e that won't power up. the battery is dead but the adapter works. after pressing the power button the left light beneath the screen turns a solid green and the center light...
As per the symptoms given by you it seems like a motherboard problem. Follow the steps on the link below and it would suggest what part needs to be replaced.
http://tinyurl.com/6xxv4h
thanks
proton
Aug 02, 2008 | Computers & Internet
Usb problem
no fear. sorry to say that your usb flash is done for. extracting the information can be done, but it is a specialized job and thus will cost a small fortune. getting it repaired is fairly simple but the information inside might not be attainable due memory chip damage. does your fash disk power up (as in does the light on it flash when plugged unto the USB port)?
babyvalkyrie. your problem is slightly different. what you need to do is log onto the bios menu during startup if the bios recognises the the HDD then you can try to re-install windows on it, but during setup you will have to formatt your harddrive fully (formatt using the long formatt not the quick formatt. also use the ntfs formatt. If your bios does not recognise your HDD then you will just have to replace it.
May 17, 2008 | Samsung 1TB SATA2 7200RPM 32MB HD103UJ 334...
Computer
First check all connection.Then format the operating system and reinstall it.
Apr 10, 2008 | Computers & Internet
Harddrive is not recognised by my Mac OSX (10.4.8)
When you reboot and hold down the option key, does the drive show up during that initial process? Is the weird noise more like clicking or more like a high-pitched whirring? If the drive has been damaged on a hardware level (causes too numerous to list... age, power fluctuations, being knocked over or dropped, corrosion, poor workmanship...) and won't show up at all, it is probably now a paperweight. There are a couple of utilities available to troubleshoot disc problems for Macs. The most popular are Disk Warrior and Tech Tool Pro. They can often "see" a disc that Disc Utilities misses, and assist you in copying the data from the drive. This process is important to be cautious with, however, since your drive is making noises it should no longer be considered reliable and the best hope is to retrieve your data and then get a new one or have yours replaced [if it is under warranty].
Aug 12, 2007 | SmartDisk Crossfire Desktop (xf160f) 160...
IBM "Portable (22P7196) 40 GB Hard Drive Logo
180 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
