My LG wm0532hw front load washer is not spinning or draining....... No codes
Also, throwing NO codes....... I have run the QC test mode (unplug for 20 mins or so, then press the spin speed/soil level ...... Then X amount of pressing the start/pause button, to get it to do Y) In that, it will not spin or drain........... Any suggestions to help me 'narrow down' what is the problem (or did I 'lose' the pump AND something else simultaneously?)
  • Tracy Thackery Mar 30, 2012
    I ended up ordering a new drain pump and replacing it.... What it turned out to be , was HAIR in the pump.......... My DD has very long hair and it got 'wound up' into a rock like 'plug'.............. It has taught me a lesson, I will be checkin' my pump at least twice a tr to try and avoid this again........ Thank you all for your suggestions
  • 183 Answers
SOURCE: fisher & paykel GWL08 washer
faulty pcb Regards Advisor
Posted on Aug 22, 2007
  • 105 Answers
SOURCE: Troubleshooting your problem LG Washer
you may find that you need to dismantle the pump as you can get things inside the impellor area causing intermitant problem
Posted on Jan 28, 2008
SOURCE: kenmore elite h4 front load washer throwing error
I just fixed this problem in my kenmore washer today. You need to take out the three small screws on the bottom of the front panel. You will need a star shaped screw driver. The panel will fall off when the last screw is removed. After taking off the panel, you will see a large round piece in the middle that should be white; take this piece and turn it to remove the filter. Your filter is most likely clogged with small laundry items or lint and dirt. Remove the blockage and the washer will work great again. This is frustrating, so my wife and I are going out to buy some netting bags for washing small items. Make sure you have a towel under the drain before you open it.
Before doing this though, take a second and reach up under the rubber gasket that circles the inside of the washer door. Your blockage could just be in this area. Our washer had both areas blocked.
Hope this helps
Posted on May 15, 2009
  • 51 Answers
SOURCE: Stops drains and bleeps with only spin light illuminated
It sounds like you need to re programme the
machine.
With the machine plugged into the wall and
turned on and the headset turned off this is what
you do.
Push and hold down the start button, while doing that you need to then push and hold down the power button.
Hold them down for about 5 seconds, during
which time you may a series of up to 3 beeps.
Then release the buttons.
Turn the machine off and then on again followed by the start button. Allow the machine to then run the complete cycle.
This should correct your problem, if this doesn't then you may need to then look at replacing the computer panels.
Posted on Jun 14, 2009
techbuster
  • 5081 Answers
SOURCE: Whirlpool front load washer getting an error code of "F6"
f 06 is a in issue with the motor control board, check the wiring harness attached to the board.
Posted on May 21, 2010
Lg tromm wm2277hw will not spin
Press the SPIN SPEED and SOIL LEVEL buttons simultaneously to enter QC test mode and check the frequency of the water level, if the display shows 248 or more:
NO: Check the sensor switch assembly and also the pressure hose, replace either if faulty.
YES: Press the START/PAUSE button twice while in QC test mode and check whether the drum spins at low speed, this is normal.
If no reaction from the drum at all the the main PWB assembly board will need replacing.
Feb 09, 2014 | LG WM-2277HW Front Load Washer
LG WM3987HW Washer Spining very wild
I've just uploaded a service manual.
relevant info pasted below: --
Regulate a specific spin speed that generates excessive vibration and noise as follows:
1) Put an unbalance part (rubber) inside of the drum.
(this is a special weight that service people use. It clips into the drum. If you don't have it, throw in about 4 to 6lbs of damp laundry.)
2) Start the QC test mode (Refer to section 7-2).
7-2 says turn the washer off, then press 'spin speed' and 'soil level' at the exact same time. Then, while holding both buttons, press power to start "QC test mode"
3) Press Delay Wash button, then ' tst ' is displayed on lcd
4) Press the Spin Speed button repeatedly to select Extra High.
5) Press the Quick Cycle button, the spin speed is displayed.
6) Press the Start/Pause button.
7) Press the Beeper button repeatedly to set spin speed (600, 800, 1000, 1200 rpm) and check if there is vibration
and noise.
8) If there is no vibration and noise, increase the spin speed by pressing Beeper button.
9) If there is vibration and noise, rotate the Cycle selector knob clockwise to reduce the Spin Speed (reduce by 50
and 100 rpm). In case of 600 rpm, it can not reduce the spin speed.
10) If vibration and noise are reduced, press the Quick Cycle button to store (2 beep sounds).
* If you want to return to factory default spin speed setting, repeat above steps except step 9)
Jan 10, 2012 | LG WM3987HW Front Load Washer / Dryer
Lg Tromm front loading washing machine. Model # WM0532HW.I keep getting the UE and IE codes. Also makes alot of noise in the spin cycle....warranty is done....should I not bother & get another
IE: Water level (246) was not reached in 8 minutes
UE: Imbalance: Load too small, too large objects between tubs
OE: Drain problem took longer than 10 minutes to drain
FE: Overflow issue drain pump running to comp
PE: pressure sensor (sensor out)
dE: door error. open door. switch is out
LE (with a a slash in the
middle of L. Upside down F) Thermistor out
CE: Over amping Too much soap wrong soap
LE: hall sensor shorted/destroyed from sudslock
bE: Ball sensor loose connection/out of order
EE: eeprom out test mode only
PF: power failure momentary interruption of shocktricity
Service notes and manual
Jul 23, 2011 | LG WM-2277HW Front Load Washer
How can I make the water drain from my LG WM0532HW washer with an LE code. BTW- it's had the hall sensor and the main board replaced already.
You can turn the power on, and hit the spin speed button, and then start it. It should drain out.
If your still getting an LE error, and already have replaced the Hall sensor, it's most likely the Stator. If you know your date of purchase, this is most likely still under the 7 or 10 year warranty. Meaning LG pays for the part (over $100.00+),
Mar 07, 2011 | LG WM-0532HW Front Load Washer
OK I'm in deep trouble. I have an LG 2277h first I had the LE error and I read most of the posts. I unplugged and preformed QC test proceedures and then things went from bad to worse. My main problem...
Your going have to open it up. I think its the PWB ASSY, MAIN Part#6871ER1003C. Unscrew the top on the back and from the front push the top back. That will slide it back, it you see a red light on the power assembly then its not your problem but if its off then that is the part to replace. I'm ordering the part right now. Its pretty easy to unplug all the cables. I found it from 53 to 160 on the internets. You just have to shop around and call them to see if they actually have it in stock. http://media.fotki.com/1_p,ssbrgfbfrktqtddxgtqsskgwtqkq,vi/rwsbqgrbwxrqrkswwdq/1/1303472/5961857/image1927948615726646899img-or.jpg
Sep 30, 2010 | LG WM-2277HW Front Load Washer
Tromm LG front loader error code
Already answered by an expert :-
This a common problem for all front loaders. Your washer will not drain or work 'cause your outlet filter is clogged or an unusually heavy load. The small door is on the left side front bottom of your washer. Remove the door with a putty knife or thin butter knife inserted in the middle top of the access panel door. Drain the water from the filter housing by pulling the tube out of the clip and unplugging, allow it to run into a bucket while the machine is in spin only mode. This mode is acheived when the washer is first powered on press the spin button until no spin is reached then run. Run in this mode until no water is draining from the tube in the bucket. Keep the tube as low as possible. When water has stopped coming out of the tube turn off the washer and unplug from the wall. This step is important because this resets the fault. Expect some water to come out when you open the filter housing by turning counterclockwise until you can pull the filter from its housing. Clean out your filter, return to housing turning clockwise until seated and recap the tube and place in the holder, refit the cover and plug back into the wall. Fixed. You may also need to lighten the load a bit but I always try full on load anyways. If it fails again just lighten, unplug wait >1 minute then replug and run.
Thanks.
Jun 17, 2009 | LG WM-2277HW Front Load Washer
Need code/s for LG WM1832CW to have washer do a spin/drain only
1. press POWER button to turn om.
2. press SPIN SPEED button only.
3. press START/PAUSE button/
May 02, 2009 | LG WM-1832C Front Load Washer
LG front load washing machine will not spin
I am having the same problem with my washer. Go to this web site below it has a free troubleshooting guide. I narrowed my washer machine down to two parts. Stator assy or Main PWB assy.
http://136.166.4.200/contents/Laundry/WM2042/WM2042xx_Service_Manual.pdf
Oct 10, 2008 | LG WM-1832C Front Load Washer
Will not spin at all.
also the factory has determined that the main board can cause all the problem as long as the water draining out it be the main board
Feb 24, 2008 | LG WM-2277HW Front Load Washer
Lg wm0532hw front load washer
LG wm0532hw, can not turn on washer, it's not the plug, i try to reset it by unplug for 2min then plug it back. help
Dec 12, 2007 | LG WM-1832C Front Load Washer
Washing Machines Logo
57 people viewed this question
Top Washing Machines Experts
