Question about Maytag Dishwasher
Maytag JetClean EQ Plus MDBD880AWB has very touchy sensor
I have a pretty old dishwasher It came with the house when we bought it and the house was built in 1998 so it very well could be the age of the house. I think it might have a problem with the sensor but not sure. In order to get the dishwasher to run an entire cycle, we have to prop a chair with a VERY HEAVY item on it next to the door and not walk into the room while it is running or it might stop the cycle from the lack of equilibrium in the floor. Is there a home fix for this? We don't have the money right now for a new dishwasher and I would like to try to get another year out of it if possible. Thanks for your help.
  • Laura D Jan 18, 2015
    I know I posted this almost 3 years ago but I forgot about this site. My husband fixed the problem. There is a sensor that was not allowing the washer to see the door was shut. If we put a plastic knife in the slot before starting the machine, the sensor sees the door being shut. Maybe we can get another year or so out of the dishwasher without having to replace it.Thank you for all your comments.
5 Suggested Answers
docjohn174
  • 943 Answers
SOURCE: Maytag dishwasher heavy door (broken door spring(s))?
Hi thanks for the question. to repair . bottom kick plate must be removed ,to get to the door springs .4 screws . remove them. springs on each side . replace them thanks the appliance doc.
Posted on Oct 06, 2008
  • 236 Answers
SOURCE: Maytag Jetclean Dishwasher EQ Plus MDB7100AWB
the door seal has gone better change the door surround seal also. check for case damage and obstructions aswell.
Posted on Mar 14, 2009
SOURCE: control panel lights blinking
I have the same dishwasher with the same problem, try pushing the delay/resume button, then the drain/off button. When the lights go off start your wash cycle.
Posted on Sep 21, 2009
iwillfixforu
  • 619 Answers
SOURCE: Maytag Jetclean Dishwasher EQ Plus, Model
You have debris down in the pump area. To get to the problem you will work from inside the dish washer and start by removing the spray arm and then using torx driver you will need to remove upper components of the pump/motro assembly to get to the debris. good luck
Posted on Feb 28, 2010
Maytag jetclean dishwasher eq plus
The best dishwasher soap we have found is Finish Quantum and they have good rinse aid too
Jan 24, 2014 | Dishwashers
You need to pull it out and use a wet and dry vacuum to remove any water. then check the hoses to the drain and the pump and its housing.
May 27, 2013 | Dishwashers
Maytag Jetclean Dishwasher EQ Plus - Lights flashing
either the control board or the control panel needs replacement. Most likely the latter. There is a possibility that both parts failed also. Usually water gets inside the touchpad, corroding and shorting the touchpad. Good luck
Mar 03, 2010 | Dishwashers
Our Maytag Jetclean Dishwasher EQ Plus will not turn on (MDB9150AWS) and we cannot find a repair manual to troubleshoot through the problem. Maytag does not offer repair manuals on this model. Any...
Try this. From what I have found Maytag discontinued the Repair manual but it appears that all MDB and MDC models fell under this one repair manual.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=47135
Oct 10, 2009 | Dishwashers
Control panel lights blinking
Sep 17, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Mar 14, 2009 | Maytag MDB7100AWB Dishwasher
Panel lights all flashing when trying to start a load
Try pressing delay/resume then drain/off. In some cases you might need to do delay/resume then drain/off twice.
Dec 03, 2008 | Maytag 24 in. MDB5600A Jetclean II...
I just bought a used maytag jetclean eq plus, and i can not find the plug on it? Where would it be? i looked everywhere
Hi chapper_7,
The dishwasher will not have a plug on it. It will have a small box that you will run power into. The box is usually located on the bottom of the dishwasher near the front right or left. You will open the box and install a cord, or you can direct wire the dishwasher to your home wireing. The box is usually made of metal and it has a round hole in it for the cord to run through. Good luck and I really hope this will Fix,Ya.
Mike
Sep 24, 2008 | Maytag Dishwashers
Maytag dishwasher jet clean eq plus water not filling with water
My Maytag Jetclean Flexiload is 4 years old. Upon choosing a program the timer counts down but little action is heard. Near the end of the cycle an Error message comes up. The dishes are stiil uncleaned.
Apr 23, 2008 | Dishwashers
Maytag Dishwasher Logo
104 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
