Question about York Exercise & Fitness
I have a York Fitness Inspiration treadmill that won't work - nothing on the control panel, no signs of life except a very quiet hum that proves power is going into it - have tried changing the fu
I've removed the motor housing and all wires seem connected and there's no sign of corrosion or damage.
    Top Expert:
  • York Master
  • 12,223 Answers
Dear Sir:
Please adjust the reed swtich , attached below see the diagram and adjust according. 1/8-/14" 2) Tight the ribbon cable from keypanel 3) Tight the connecto from display board vs main motor board.
Run the software calibration for easy diagnose and troubleshooting.
see my block diagram for better understanting.I fyou want to measure the motor see my personal TIPS. sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a.
I have a York Fitness Inspiration treadmill that w - 2_18_2012_5_26_02_pm.gif2_18_2012_5_26_12_pm.gif
Posted on Feb 18, 2012
vpaaf
  • 95 Answers
SOURCE: 9100 life fitness treadmill
Sounds like you need a new lower board replacement. You can get that for that treadmill by call lifefitness or sportsmith.com Please rate me good
Posted on May 01, 2009
SOURCE: my life fitness t30 treadmill ''running error''
startup error on life fitness treadmill
Posted on Jan 08, 2010
  • 3 Answers
SOURCE: i have a error reading of l5 or ls not too sure york fitness z16
The L5 message means that there is a problem with the speed setting switches. Some models have one set of speed adjusting stitches on the handlebar and another set on the console. One of them is defective and is causing the problem.
Posted on Feb 03, 2010
bwinton
  • 83 Answers
SOURCE: error 1 message on older life fitness t3 treadmill
Error 1 - Start up error. This is caused because the belt was commanded to move and the opto (speed sensor on the motor) has not seen any movement or the belts movement was interrupted prior to it reaching its commanded speed. To fix Verify opto operation in Diagnostics, Motor Test
Mode, Section 2. Verify DC voltage at connector P6 pins 1 and 2. Verify that LED 4 on the Motor Controller flashes as the motor moves. Let me know if you need any more help. Fitness Fix-It
Posted on Mar 24, 2010
bwinton
  • 83 Answers
SOURCE: Fet error message
The FET error message is caused by the driver transistor on the motor controller has shorted out. Unfortunately, the fix is replacing the motor controller.
Posted on May 07, 2010
My t3 treadmill doesn't come out of energy saving.
rese the treadmill and try again.
if the problem persist go to the MENU, and turn OFF .
God bless yo
Jan 14, 2013 | Life Fitness T3 Treadmill with TRACK...
Finding total mileage and useage hours on a Life Fitness 9500 Treadmill
unfortunately, is NOT possible, Not miles or kms in treadmills.
You have to buy the eagle eye.
God bless you
Oct 07, 2012 | Life Fitness 9500 HR Treadmill Next...
How do you calibrate a york treadmill?
yes you must read the instruction manual for software calibration.
or open the hood motor, and read the instruction attached.
or you must call to York supply for customer service and ask them where is located in case that you will not find them.
God bless you
Jul 12, 2012 | Exercise & Fitness
Life Fitness 9100HR Treadmill won't start
Typically a non start up of any electrical Exercise equipment raises alot of red flags If this treadmill will not start Check the internal fuse MAKE SURE ITS NOT PLUGGED IN!!!! UNPLUG IT FROM THE WALL
2 If there is NO Fuse and you just bought it new Return it for an exchange.
3 Check your wall outlet for less then 5 Bucks you can buy a wall outlet tester that tells you if your Outlet is good Or Bad.4 DO NOT Attempt to service this item on your own the way they make treadmills you have to have a qualified service tech come out and fix it because the risk of serious shock or death is emminent.
May 04, 2012 | Life Fitness Exercise & Fitness
My treadmill life fitness 9100HR won't start
Have you checked the drive belt @ the motor, if it is OK then check the fuse, if it is ok then the brushes in the motor may be worn out
May 04, 2012 | Life Fitness T3 Treadmill with Advanced...
My York Fitness Inspiration Treadmill won't work :(
Dear Sir:
You have a lack of power in power supply.
Attached is the block diagram for easy diagnose and troubleshooting ,see my tips for more details for to make some measure with your VOM.
Please do not by pass any c.breaker only you will complicate the electronic system.
After you see the block diagram, you can conclude if the power supply +transformer+or main mother board is faulty.
Of course ty your circuit breaker from your house, and see the ground or your outlet wall, see if there some problem to ground.
ernesto cuadra
managua, nicaragua.
Feb 18, 2012 | York Exercise & Fitness
Error 7 on my york inspiration treadmill tried reset button but still not working any ideas.
hi,
By error 7 it means that the safety is not positioned correctly. or the saftey switch inside the unit is faulty. Its a magnetic switch. When you place the safety key (its made of magnet) this switch will activate. Then only teradmill start. Check the safety key is positined correctly or not. If it is in position then you have to replace the safety switch inside the control console.
OK
Sep 01, 2011 | York Barbell Home Use Fold-Up Treadmill
E1 not ERR1 error appears on the display of diamond t300 york fitness treadmill??
Your problem might be that a magnet has fallen off. Here's an illustrated guide that will make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Jul 04, 2010 | York Yankees Bedding MLB Comforter
Life fitness treadmill display: transistor error-won't run
This error shows up if motor controller detects a failed part. This isn’t a reset-able error. Treadmill will not allow workouts until serviced.
Solution
Main motor wires/leads could be disconnected at the start of a workout. If the motor is properly connected and in working condition then the drive transistor could have failed. Check Motor Controller.
Feb 28, 2009 | Life Fitness Remanufactured Next...
Exercise & Fitness Logo
238 people viewed this question
Top York Exercise & Fitness Experts
Electro Med Services...
Tom Chichester
ray gallant
Are you a York Exercise and Fitnes Expert? Answer questions, earn points and help others
