Question about Samtron 76df 17" CRT Monitor
Monitor loses resolution
I have Samtron 51s monitor bought in 2001, which has stopped working properly. When I switch on my monitor, colours and resolution are OK. But after some time it starts flickering, colours get all wrong, and images look like being taken using thermal scan. Thank you.
  • Anonymous Dec 23, 2007
    I have exactly the same problem. It sometimes corrects itself after the monitor has been switched on for some time, but then reverts to its off colour mode. It seems to do it in vertical bars. At one time it had a red bar about 2/3 of the way across the screen. I changed all the electrolytic capcitors on the main board and on the PSU & it stopped doing that. Now it has pink streaks and wrong colours at full saturation.
Retres line in pictur
Posted on May 24, 2008
When I switch on my computer, Windows XP start loading and then my Samsung Samtron 45Bn monitor's screen goes blank and the green light keeps flashing every 0.5 secs.
It sounds like your video is set to the wrong resolution. Try booting into safe mode by pressing F12 at the start of the boot process. If you get into windows that way, then adjust the display to something you monitor can display like 1024x728@32bits. The monitor can only display a certain amount of pixels and if you set the video card to high you will lose visual. Hope this helps.
Mar 19, 2011 | SAMTRON 55V 15" CRT Monitor
My monitor resolution colour is changed to pink.
Check the data-cable between the computer and the monitor, and try a different cable.
Or, try connecting the monitor to a different computer, to see if the video-card in your computer is not working correctly.
If necessary, replace the video-card.
Colours on your monitor are produced by "mixing" the 3 "primary" colours: red/green/blue in various proportions.
Or, if part of the monitor that produces one of those 3 primary colours has stopped working, then the resulting "mix" will have too much RED/PINK. Fix/replace the monitor.
May 29, 2010 | SAMTRON 55V 15" CRT Monitor
I hve a sansung 48 v monitor. the screen is very much redish
CRTs use 3 "guns" to mix the 3 "primary" colours (RED, BLUE, GREEN). One of the other guns has stopped working, leaving the RED gun as the "dominant" colour.
Spend $30, and buy a pre-owned 15" LCD monitor.
Or, spend $100, and buy a new 17" LCD monitor.
May 26, 2010 | SAMTRON 55V 15" CRT Monitor
I am trying to clone my lapptop image with a samtron 73.v and the samtron seems dead :-( It says Test Good but does not work
Most laptops have three video-settings:
* output only to internal screen
* output only to external monitor
* output to both internal and external
Select the appropriate video-setting.
Set your laptop's screen-resolution to 800-by-600 by 60Hz -- a resolution that should be compatible with any 15" Samtron monitor.
Dec 26, 2009 | SAMTRON 55V 15" CRT Monitor
Samsung samtron monitor does not work
Please check whether the power cable is properly inserted...
The power button of this model fails with time.You need 2 press it tightly and hold it till the LED is on....
try this...
Hope this helped...
Dec 21, 2009 | SAMTRON 55V 15" CRT Monitor
Resolution problem with xp
Here is a link to the instructions for resetting the resolution for your monitor: Resolution/Refresh
If you need other information about your monitor please look here
Mar 31, 2009 | SAMTRON 55V 15" CRT Monitor
Getting my samtron to work on my cctv
Not all DVRs have WORKING VGA output. I used to work for Nuvico, and we had 2 different versions for DVRs. Ones with VGA connection. The other with non-working VGA connection. VGA port itself does not guarantee. Some DVRs also have DIP switch in the back. You can simply toggle between composite or VGA output. Ones with DIP switches often require reboot, and from my experience these do not work well with VGA monitors. Also... Make sure VGA monitor support low resolution. Stand-alone DVRs' native resolution is either 600 or 800 horizontal lines.
It will help alot if I know the model of DVR/CCTV
Jan 17, 2009 | SAMTRON 95P 19" CRT Monitor
I have the SAMTRON 56 V 14" COLOUR MONITOR .
change the eprom (A41dDC) after connect pc then switch on monitor
sushil91077rajbanshi@rediffmail.com
Sep 04, 2007 | SAMTRON 78DF 17" CRT Monitor
Samtron 94v 19nch problem helpppppppppppppppppppppppppppppp
If it's still under warranty I would call for repair service. It sounds like typical internal power supply trouble that needs electrical troubleshooting.
Jan 10, 2007 | Samtron 96BDF 19" CRT Monitor
Samtron 76df 17" CRT Monitor Logo
182 people viewed this question
Top Samtron Computers & Internet Experts
William Miller
William Miller
pankaj rautela
pankaj rautela
Richard Lilja
Richard Lilja
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
