Question about Nortel T7316E 2-Line Corded Phone
Feature **266344 doesn't work on Nortel 7316E
We have an 8 year old Nortel system in our office which no current member of staff knows the codes for... Our IT department (we're an outlying office of a local authority) no longer supports our kit, and we're low down the list for an upgrade. We need to change the date and time. I've tried all of the standard methods listed on this site, and hunted out feature code lists elsewhere on the internet. Unfortunately, when I enter Feature **266344 (feature **CONFIG), nothing happens, no password prompt - nothing. Ditto for **SETUP and **ADMIN. **USER does produce a password prompt (which no-one knows the password for)... I've tried the Feature *983 / *985 methods for resetting passwords, but both of those codes produce "Invalid Feature" errors... Any idea where I go next with this? Cheers in advance
SOURCE: Changing the time on a Nortel networks phone
Feature **time (type out time on the dialpad.)
Posted on Apr 17, 2008
  • 1214 Answers
SOURCE: Can't get into admin mode
Have you tried downloading the manual to see if there is a way to reset the master admin code? If what you tried didn't work, maybe it's easier to go back to square 1.
But be prepared, a master reset may render the system useless until various operating perameters have been re-entered.
Posted on Jan 24, 2009
  • 9 Answers
SOURCE: Nortel 7310 voicemail will not reset
You dont have the EXT of mailbox 222 assigned to ext 222. Go under F983 press mbox press chg press 222 press ok press next it was say EXT: see what ext is assigned to put in 222 press change enter 222.
If it tell you that 222 is already assigned you have to find the mail box it is assigned to. Usually involves checking every Mbox starting with 221
Hope this helps.
Posted on May 21, 2009
SOURCE: voicemail and password
I would unplug power to the voicemail, then restore. Wait 10 minutes and then do the same to the phone system.
What you are trying to do is reinitialize the voiecmail, if you dont know what you are doing you will do more harm than good.
Posted on Jul 20, 2009
consultel1
  • 860 Answers
SOURCE: how do i change the names that are on the display
Programming2.gif is done on 7310, 7324 and 7316 type sets.Enter programming2.gif by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming2.gif.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you want to change the name on.
Press the show key (top right arrow)
The display should say LINE ACCESS
Press the next key (bottom right arrow) .
The display should say CAPABILITIES.
The display say Name.
press the Chng soft key.
use the dial pad to enter the name. advance using the arrow soft key to go to the next letter
ex. Bill = 2,2 -> 4,4,4 -> 5,5,5 -> 5,5,5
Press the next key (bottom right arrow) to enter the name.
Press the release key when finished
Posted on Oct 16, 2009
Hello, i have a nortel 7316e and trying to reset to factory default. i am entering **7827887 and error message "startup denied" appears. Thanks Nikko
Remember to hit "Feature" first. Dialing **7827887 by itself does nothing.
EG;
1 - Feature **7827887 (STARTUP)
2 - Enter installer password 266344 (CONFIG)
3 - Change to template desired (square, hybrid, or PBX)
4 - Press NEXT to apply the template
Edit: Make sure you have access to the phone pool as admin and that there are no restrictions set on the phone itself. The same thing was happening to others and was detailed here
http://www.tek-tips.com/viewthread.cfm?qid=983869
Feb 23, 2017 | Nortel Computers & Internet
Hi We have a Nortel T7316E phone system. Staff
Programming is done on 7310, 7324 and 7316 type sets.
Enter programming by pressing the feature key followed by **266344 (with the handset in its cradle).When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
Enter extension number you want to change the name on. (i.e 202)
Then press the show key (top right arrow)
The display say Name(Traci).
ex. Winston = 9 -> 4,4,4 -> 6,6 -> 7,7,7,7-> 8-> 6,6,6-> 6,6
Sep 05, 2013 | Panasonic KX-T7730 Corded Phone
How to disable the speaker on the phone
On most older nortel systems you can use the feature,*,6 buttons to adjust the ringer type, along with type you can set the volume by using the up/down volume buttons.
Jun 21, 2013 | Nortel refurbished 7316e phone
Trying to set the time on the phone but i dont know the password
Try feature **8463 (time) or feature **266344 (config). Either way, changing the time on a Norstar system must be done using a display phone. Using a M7310, M7324, or T7316 the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
1.- To enter programming mode press "FEATURE" and "* * 8 4 6 3" or "* * 2 6 6 3 4 4"
2.- Enter password (default = 266344) - display should read "Terminals & Sets"
3.- Press "NEXT"(bottom right arrow) 5 times - display should read "Time and Date"
4.- Press "SHOW" (top right arrow)- display should read "Hour:___"
5.- Press softkey "CHANGE"
6.- Enter hour - display should read "AM OK or Change"
7.- Select AM or PM
8.- Press "NEXT"(bottom right arrow) - display should read "Minutes:___"
9.- Press softkey "CHANGE"
10.- Enter minutes
11.- Press "NEXT"(bottom right arrow) - display should read "Year:___" 12.- Press softkey "CHANGE"
13.- Enter year
14.- Press "NEXT"(bottom right arrow) - display should read "Month:___"
15.- Press softkey "CHANGE"
16.- Enter month
17.- Press "NEXT" (bottom right arrow)- display should read "Day:___"
18.- Press softkey "CHANGE"
19.- Enter day
20.- Press "NEXT" (bottom right arrow)
21.- Press the Rls key
Aug 16, 2010 | Nortel T7316E 2-Line Corded Phone
How to move my ext# to a new phone location Nortel t7316E
The system has a built-in feature called "Set Relocation", which will allow you to move your phone to another active telephone jack in your office and the extension number, voicemail box, and all features will stay with your phone.
Have your system administrator turn on Set Relocation, or check your Norstar administration manual for programming details. Or, you can call your telecom service company and have them send a technician.
May 14, 2010 | Nortel Norstar 16-Line PBX Speakerphone
How to get voicemail from another phone nortel 7316e I am trying to get my office messaged from my cell.
If your trying to get your messages from another nortel set in the office press your open voicemail button or feature 981. The left soft key below the screen should say OTHR. press the soft key the screen should change to LOG: enter in the mailbox number followed by the password and #.
If your trying to get your messages remotely, call into the office and when the auto attendant answers, press ** followed by your mailbox number password and #.
Nov 02, 2009 | Nortel T7316E 2-Line Corded Phone
Nortel 7316e: Need to change the auto attendant
To enter viocemail administration, press Feature 983. if your system has 2 digit intercom #s your password is 120000 if your system has 3 digit intercom #s your password is 1020000. once you have entered the password you will see 3 selections you can make .use the three soft keys under the display and select AA (auto Attendant). next press greeting and greeting again. next it'll ask for the greeting number your probably working with greeting 1. press record to start and ok when finished. dont forget to save the greeting or it will be deleted if you exit early. hang up when finished
Oct 27, 2009 | Nortel T7316E 2-Line Corded Phone
How do i change the names that are on the display on a Nortel 7316e
Oct 16, 2009 | Nortel T7316E 2-Line Corded Phone
Need Caller ID displayed on Nortel StarTalk Flash/M7310
A question: -> does your phone ring? -> what software are you running on the system? If you know this will help a little in giving you more information. There is a Feature that you can dial if your phone rings... when there is a call coming in, dial FEATURE 8 1 1 You can even make this a button rather than dialing this feature code everytime: -> Feature * 3 -> press the button that you want to program -> dial Feature 8 1 1
Jul 16, 2009 | Nortel T7316E 2-Line Corded Phone
Change extension number on Nortel T7316E model
Well ~ eagleeigh731 has it mostly correct, do what he said to do and get into the programming --> find SYSTEM PRGRAMMING --> hit next until you find CHANGE DNs--> OLD DNs (this is the old extn#) 222 then type in NEW DN 431--> then hit the end or release button.
Voila your new extension is now there... to check dial FEATURE 0 then press the intercom button, the new extension should be there.
Mar 17, 2009 | Nortel T7316E 2-Line Corded Phone
Nortel T7316E 2-Line Corded Phone Logo
233 people viewed this question
Top Nortel Lands Phones Experts
David Burbee
David Burbee
Oloyede Monsuru
Computer Repairing
Computer Repairing
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
