I'm looking to purchase a Used Gerber Envision 375 Control Board #P75041A
2 Suggested Answers
joecoolvette
  • 5660 Answers
SOURCE: How do I install a gerber 21-375 Toilet? It came
The Gerber Ultra Flush Back Outlet toilet, that uses 1.1 Gallons of water to flush?
Just like any common toilet. Install the tank to the bowl of the toilet, set the toilet, install the flush mechanism in the tank, attach the supply line.
1.MAKE SURE you put the two plastic U-shaped spacers on the back of the bowl!
2.Install the round rubber gasket in-between the tank and the bowl.
3.Set the tank down on the bowl. Make sure you have the round gaskets that go up under the bolt heads, then insert the two bolts into the tank, and through the bowl. NOT installing these will cause a leak!
Tighten these bolts down, until the nuts are JUST touching the tank. (There is a flat washer that goes under each nut)
DO NOT tighten one bolt all the way, then tighten the other bolt!!
These bolts MUST be tightened evenly. Tighten one turn on one bolt, then go to the other bolt.
DO NOT overtighten, or you will break the bowl, and/or the tank!
Make sure your toilet flange on the sewer pipe is in good repair, and clean, from the old beeswax ring. It can be messy, even using gloves. Use a flat painters stick to help remove the old wax ring. Scrape off into a old can. The wax thin residue on the floor and flange is fine.
Set the new wax ring in place, remove the plastic liner that comes with the ring. DO NOT leave that thin plastic liner! It's just to install that wax ring!
Install the bolts that hold the bowl to the floor, or reuse the old bolts if they are in good repair.
Tighten EVENLY, and don't overtighten! You can crack the bowl.
Now install the toilet mechanism in the tank.
Here is a 1 Page, Tank to Bowl Installation Guide from Gerber. It is a PDF file. Let it download ALL the way before looking at it.
http://gerberonline.com/fileLib/Toilets%20Ultra%20Flush%20IS.pdf
Should this direct link not work for you, here is the page it came from,
http://www.gerberonline.com/Catalog.aspx?categoryID=2204&itemID=3514
It's on the right side -> Installation Instruction (PDF)
Posted on Jul 02, 2009
I have a 42" Envision Flat Screen. It shows the image on the TV didn't look like this yesterday. It showed shadows in magenta, yellow and white. The setting are set to the factory settings.
T'Con board fault. Replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 06, 2015 | Envision Televison & Video
Had been taking several attempts to get it to come on. Sometimes had to unplug and retry. Now only says "Scan TV". Is repair likely to be more expensive that what set is worth?
Sometimes heat is a real big issue with LCD monitors, over time it causes fractures and circuit breaking in the chips and pops off a few capacitors. It is likely that your control board has a couple bad capacitors and/or components that have failed yet have not removed the display capacity. So your T-Con board is likely not the issue.
When searching online use your monitors make model and production date and include "Main Control Board" so you can find products that are for your unit.
Searching Ebay and Amazon are common places these units will be sold and run anywhere from 5$ to 200$ depending on your monitors grade.
Source:
http://www.ebay.com/sch/i.html?_odkw=Envision+driver+control+board&_from=R40&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.H0.XEnvision+main+control+board.TRS0&_nkw=Envision+main+control+board&ghostText=&_sacat=0
Mar 06, 2015 | Envision 19" Widescreen Flat Panel LCD...
Will my Envision 19" monitor,
You will need to set the display resolution and vertical sweep rate on the computer to something the monitor can handle. The monitor works best at 1440 x 900 at 59.8 Hz vertical rate. If your laptop's graphics chip doesn't have this setting (available settings are listed in the Display control panel), then look on page 19 of the monitor's owner's manual to find something that matches a resolution listed in the control panel.
Sep 21, 2011 | Envision Computers & Internet
My laptop LCD screen is FUBAR and in order to use my computer I have hooked it up to an Envision 19" LCD Monitor. If I start Windows Vista in Normal mode , it does not recognize the Monitor. Pressing...
I would go ahead and boot into safe mode where you say it does work and then take a look. See how it detected it...ie look in device manager and see if it picked it up by it's true brand/type etc. Check the settings both of the display and on the envision itself. Check the resolution selection. It's probably picking it up as a lower res. but when it boots into reg windows may be trying to run at full res and perhaps that's what it won't do. Check to see what driver it's using. It may need the specific driver from envision and not the generic driver. It could also be a bad pin on the envision itself.
If you have another computer you can hook it up to, do that to make sure the envision is working. That way you can deduce which is the problem, the monitor or the setup in your laptop.
Jul 10, 2011 | Envision 19" Widescreen Flat Panel LCD...
I need replacement cutter inserts. Where can I get them in the uk.
Hello. There is an authorized dealer located in the UK. However, they "cannot supply spares or parts for any Gerber Tool..." Since the parts you are looking for are advertised as replaceable by the Gerber Company, the cutters may not fall under the same category, so I think a phone call to these people ( 0845 0900 192 ) is at least worth a try. http://www.shop4gerber.co.uk/gerber_new.html
If they do not carry the replacement cutters, They say to "call the UK importer for repair or replacement : Please call SILVA, on 01506 406 277" - Finally, should you receive the run-around from these people, here is the link to the parent company, http://www.gerbergear.com/index.php/page/contact_us
use their contact information, and I'm positive they will be able to help. Personally, I would order in a few of these cutters, just to make all this worthwhile. Hope this has helped and good luck.
Aug 29, 2010 | Gerber Blades Gerber Legend Ultimate...
How do I install a gerber 21-375 Toilet? It came with no instructions.
Jul 02, 2009 | Gerber Blades Gerber Ultra Flush White ADA...
I turned the TV on and have sound, but NO picture, no images
Envision LCDTV & PDP Warranty
Envision Peripherals, Inc. warrants this product to be free from defects in material and workmanship for a period of one (1) year after the original date of consumer purchase. During this period, EPI ( EPI is the abbreviation of Envision Peripherals, Inc. ) will, at its option, either repair the defective product with new or rebuilt parts, or replace it with a new or rebuilt product at no charge
You can check with them here to see if they will repair your unit for free. May have to cut and paste link.
http://208.109.129.152/company.asp?EPage=company
Jun 09, 2009 | Envision L32W761 32 in. LCD TV
Gerber diesel mutipliers faulty product
return it...no one really likes on multi-tool products anyway
Mar 26, 2009 | Gerber Blades Multi-Plier 600 Needlenose
Envision EN7410e monitor
Just fixed mine. Maybe it's a few years late. Hope you guys still have the display. It's the power supply board. I've just replaced 4 bulge capacitors near one edge of the PS. They are 2x1000uF 10V, 1x470uF 25V & 1x470 10V. I salvaged my parts from an old CRT monitor. Hey you can go green with your repairs too!
Apr 25, 2008 | Envision EN7410 17" LCD Monitor
Televison & Video Logo
65 people viewed this question
Top Televison & Video Experts
