Question about Mitsubishi WS-55809 55" Rear Projection Television
Mistubishi Convergence/video display problem
My Mitsubishi has a convergence problem as well as video display issue. It powers up fine and shows inputs and channel display on screen. It also has sound. But not getting any diplay video from either inputs and anntena signal. Blue screen shows when you select other inputs such as DVD, DTV etc. Already replaced STK convergence ICS. I as other member was able to get tv signal and raster by removing GENE-CONVERG board. I even swapped GENE CONVERG board from no success. Also convergence is bowed at top and right. When attempting to select Advance Convergence to show ADvance screen Adjustment, It does not come on. When Attempting to adjust convergence it does not move on either ere or blue convergence. . Any assistance is greately appreciated.
  • 899 Answers
Also check resistor values on the chips and resolder the tuner as this can cause problems as they heat up , then replace any electrolitic capacitors in the video circuts selector ic
i will be back to see what you get
electech
Posted on Oct 26, 2008
Tv powers on, has sound but no picture. All three lights are working & will show the input display but distorted. I would like to do the repair myself but am not sure if this is a convergence issue or...
Even if a convergence problem exists you should still have a picture, a bad one but a picture----call the menu up with the Mitsubishi remote and select convergence and then advanced---a grid of lines will appear in green---got dramatic red and blue showing and you have a convergence issue.
Do that first----presuming no hookup is ok (try a dvd player) the set does have the OPTION menu(can tell you how to get there) that is based on a 4 digit number code--may have that for this model or not).
It will not correct any convergence problems but will do a hard reset of the set back to factory original.
Let me know what you find---it sounds like 2 problems exist.
Nov 07, 2012 | Mitsubishi WS-65905 65" Rear Projection...
My mistubishi WS-65713 73 inch tv's colours are off. There is mostly blue and green and some colours are non existent like red and yellow. What is the problem?
Sounds like a convergence problem which is common in these sets
This model uses two of the stk394-250 convergence output devices or chips.
Both would have to be replaced.
Mar 12, 2012 | Mitsubishi WS-65813 65" Rear Projection...
Projection TV Convergence problem
go to the Mitsubishi service center to solve your problem
Jun 20, 2010 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi WS-55511 convergence problem?
No,need to diagnose.It a 100% convergence problems.Convergence problems very easy diagnose.The picture look like 3D,colors lines don't lines up.Fuzzy,out of focus.Convergence controls don't work to lines up any colors cross.The tech is cheating u if he said cost $125 to diagnose.If u know how to solders u could fix this convergence problems about $100.U can buy a convergence kit at Websites Tv repair World.com,Tvrepairkits.com.The shop everythings fix parts and labors only $300.
Mar 16, 2010 | Mitsubishi WS-55511 55" Rear Projection...
65" rear pro. Convergence IC Repair
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 18, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi ws 65819
Ur power board ic converter it dead.
Ur Convergence board is bad going to die to.
Both must change.
Aug 15, 2009 | Mitsubishi WS-65819 TV
Auto convergence no longer works on Mistubishi WS-55807
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Red/Orange looking picture
You can see some more examples and find a fix here
Jun 12, 2009 | Mitsubishi WS-55807 TV
Convergence issue
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 06, 2009 | Mitsubishi WS-55805 55" Rear Projection...
The most likely cause is shorted convergence chips and possibly a few pico fuses.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 26, 2008 | RCA P56923BL 56" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
115 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
