I have just reloading my operating system and now the laptop won't recognise the external monitor.
    Scholar:
  • 136 Answers
Try this:Shut everything down, plug in the external monitor then turn the monitor on and only in the end turn the laptop on.
Posted on Oct 26, 2008
Dell laptop latitude e4300 - screen goes blank after starting Windows
Windows files are corupt or the hard drive has issues, try and reload operational system if disc is available, have the hardware checked if unable to load.
Oct 26, 2012 | Dell Latitude D630 Notebook
Factory reset acer aspire 5315 gone wrong
I think you need to reload windows with a operating system disk. Most times the Factory Recovery discs don't work.
Get a windows operating system disk and just reload windows. The disk must match the Certificate of Authentication (COA) sticker on the bottom of her laptop. In other words, don't use a Windows XP Home operating system disk if the COA sticker says Windows XP Professional or you'll never be able to activate windows.
May 06, 2012 | Acer Aspire 5315 Notebook
Windows won't start at bootup. Instead the fan turns on.
It sounds like your operating system has failed. Your best bet would be to use a working computer to burn a new install disc / backup disc / repair disc and then reinstall your operating system, or if possible repair it.
Have you tried plugging the VGA output into an external monitor and turning it on? Maybe your screen has just failed, if it does output to an external monitor.
You can get it into external mode if you boot it up with an external monitor connected, a USB mouse connected, and a USB keyboard. Boot up the machine (plugged in!) and close the lid right away, and it should automatically kick over. If not, try windows key and P at the same time, once the machine is "running"
Aug 14, 2011 | HP Compaq 2530p (KS094UA) PC Notebook
I have a video splitter and I'm not getting anything on my monitors. The splitter says active and the monitor appears to recognise the splitter but doesn't show any images. Is there something...
an extended desktop
click start control panel display change display settings adjust resolution this may vary depending on your operating system you should a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes
hope this helps
May 08, 2011 | GrandTec GVC-1000 (gvc1000) VGA Video...
Laptop Monitor Problem - I have a Toshiba Satellite Laptop. I had a system crash and I think I may have had a second problem with my monitor on my laptop showing, it went black and flickers on and off. ...
Possible disconnect of the wiring harness from the LCD to the motherboard? Might just need a new screen, but always check the simplest first. Flickering may imply faulty wiring or a lose connection in my opinion.
Mar 02, 2011 | Toshiba Satellite A135-S4467 Notebook
HP zv5430us laptop has no video. Blank
The laptop has a built-in video card and the video RAM uses part of the main RAM.
First, re-seat the RAM modules and if the laptop still does not boot up normally then remove the RAM and get it tested at your friendly computer repair shop.
If the RAM is OK then connect an external monitor to the laptop, power up the monitor first and then the laptop. The video data should divert to the external monitor automatically, if you do not get any video image on the monitor then the video card in the laptop is faulty and a motherboard replacement is required.
A replacement motherboard may not be a cost effective solution and If it was me, I would put my money on a new laptop. I would then remove the hard disk and insert it into an USB adapter case and use it as an external USB hard drive.
Mar 22, 2010 | HP Pavilion zv5430us (PR466UAA) PC...
Cracked VGN NR32M sony notebook screen
if it has a plug for bga ...than it will work with an external monitor...most laptops are working just fine with external monitor..
Sep 08, 2009 | Computers & Internet
Acer Extensa 5420 lockout
I believe your windows is corrupt.
Try to reload your operating system, i have seen the windows corrupted and cause problem like yours.
If you have usb mouse (external), use the usb mouse and you can check in device manager,
I believe you will see many "!" mark on the drivers.
so solution is reload the operating system.
Good Luck
Oct 07, 2008 | Computers & Internet
HP dv9000
 Hello jarkk, I believe your problem is with your backlight inverter. the hard drive should be installed for this process of checking it on an external monitor. with the hard drive removed it will not boot to the operating system. with the drive in, use the external monitor. if the monitor works when plugged into the external monitor plug, this will eliminate a bad video card. if the screen is still black on the laptop screen, replace your backlight inverter. the last case cenario is to make sure your backlights are not burnt out.
Sep 11, 2008 | HP Pavilion dv9000z Notebook
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
